8
Just want to thank CCR (Emily) for the great job, and for helping me out and putting up with my questions I may have time this weekend to start the assembly...we'll see. Here's pics of the heads http://www.main.experiencetherave.com:8080/subaru/images/ej22t/09/default.htm Various teardown pics http://www.main.experiencetherave.com:8080/subaru/images/ej22t/
Intake manifold: Depends on the heads. You'd need to match the intake to the heads. Exhaust system: Depends on whether the heads you use have dual exhaust ports or single exhaust ports. The rest of the exhaust should fit, but may require some tweaking to get it to fit. Most of the older parts from pre 2002 are "fairly" compatible. There's some intricacies in parts, but a fair amount of stuff is swappable.
head bolt Q
Legacy777 replied to WJM's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
You can reuse the head bolts. I've talked with CCR and reputable subaru mechanics, and they don't replace the bolts. My only question is should the torquing sequence be the same as the FSM states, or something different. -
Rattling!
Legacy777 replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Does the rattle change with vehicle speed, engine rpm, or bumps? -
brakes come on
Legacy777 replied to curt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
You're probably experiencing torque bind. There is a fuse holder in the engine compartment on the passenger side near the strut tower. Put a spare fuse in there, and then drive the car. See if the problem goes away. If it does, I'd suggest changing/flushing the transmission fluid as a start. That may help some, it may not. Also, some have added LSD additive to the ATF fluid. If putting the fuse in doesn't help, the duty c solenoid could be stuck open, or there could be other problems. Regarding the height control. Here are instructions to diagnosis it. http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/AirSuspension_diag1.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/AirSuspension_diag2.jpg The blinking height light is more then likely a separate issue. -
Convert the suspension to standard struts & springs. Cheapest way to go is find a similar wagon in the junkyard, take the entire spring/strut/top mounts, and replace the struts with new ones. I'd recommend KYB GR2's, which can be had from www.tirerack.com Also, depending on the condition, you may need to replace the top mounts. I would think you could get all four complete strut setups for 40-50 bucks New struts will run you about 350-400, and new top mounts 30-45 a piece.
Do you have an illuminated CEL all the time, or did you just check the codes, and find those. If you don't have a steady CEL, reset the ECU, pull fuse 14 for 30 min. Drive the car around, then recheck the codes with the black connectors. IAC valve http://www.main.experiencetherave.com:8080/subaru/images/injectors/DCP_2470.JPG Crank sensor (thing with the wire going to it) http://www.main.experiencetherave.com:8080/subaru/images/timingbelt/DCP_2703.JPG
