8
You should have it checked out by an AC shop. You can also check the wiring going to the compressor, and various other AC components for wire that's rubbed through, etc. You may also want to unplug and plug in the connectors at the compressor, pressure sensor, etc. There might be a bad connection somewhere.
Simple answer is you can't take the clutch off, you need to replace the whole compressor. Yes you need discharge the system to replace the compressor. I'd really recommend taking it to a shop. AC work is one of those things that even for someone with all the equipment is a little tricky. Spend 30 bucks or something for a diagnostic. A shop should at least be able to give you an idea of what might be wrong, and costs. If you take it to a shop, report back on what they say. Some shops like to just replace everything for lots of money.....which isn't necessary.
