8
studdering
Legacy777 replied to davidv's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Can you make the studdering happen if you go in a parking lot and do circles with the steering wheel at full lock? If so, you might want to try putting a fuse in the FWD fuse holder to disable the AWD temporarily. If inserting the fuse makes the problem go away, that should tell you right away it is the AWD system and not something else. If the studdering is still there, then it could be something like tie rod ends like Jamie mentioned. -
studdering
I'm assuming you have an automatic? If so your experiencing binding in the AWD system of the transmission. First thing I always suggest is to replace the transmission fluid. If that doesn't help, we can go from there on suggestions. Do a search on torque bind and you'll find some more information. -
First thing I'd suggest is replace the CEL bulb. You could be spitting in the wind and going a completely wrong direction. If the ECU can give you some info on where to look, why not use it. My suggestion would be to check your MAF sensor. I had a very intermittant problem for over a year where I'd be driving along on the freeway and the car would just lose power. I'd put it in neutral and rev the engine to bring it back. Most of the time that would work. Some times it didn't. Also if I was just driving around town or low rpms, the car would usually just stall.
The thing you need to remember is that the transmission uses this gear oil as well as the differential gears. Each requires a different set of needs for lubrication. If you put the 75w140 in there, shifting will probably become more difficult since the gear oil is thicker. I'd stick with what the manufacturer recommends.
