98 imprezia transmission problem
Legacy777 replied to whittles's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's possible the transmission fluid temp sensor is bad.
tat-tat-tat-tat goes my turbo @ max psi
Legacy777 replied to Jutboy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would get a hand held vacuum pump, just hook it to the actuator nipple, and make sure the actuator holds vacuum, and it's actuating all the way.
Replacing radio on a 97 Legacy with no ashtray
Legacy777 replied to lhrocker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbump
Adding to stickys... sensor replacements/cleanings
Legacy777 replied to eagleb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can add to the new gen sticky compilation if you want. Just follow the format for posting. http://www.ultimatesubaru.org/forum/showthread.php?t=51554 I will not add a bunch of separate stickies though.
Legacy777 replied to Jutboy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave you checked to see if your wastegate solenoid is good?
EJ22 Shudders when taking off
Legacy777 replied to Phizinza's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre you sure your engine & trans mounts are secured and good? What condition was the clutch when you did your swap? And when you say slow speeds, are you referring to slow engine speeds, slow driving speeds....or both?
fuel pump noise
Legacy777 replied to nickb21's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it's just louder, I wouldn't be super worried....grinding noises are never real good though.
4eat - 5mt swap
Legacy777 replied to lbmuck's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLet me know if you have any questions.
Oil capacity of '07 H6 engine
Legacy777 replied to Chuck Mahnke's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI just changed the oil & filter on my GF's 05 H6 Outback. Yeah it took close to 6.5 qts to get it to the full line. Subaru used to list the oil capacity including the filter....but it looks like they may have stopped doing that, or screwed up.
Wiper size for 2003 Legacy
Legacy777 replied to lhrocker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo, from the bosch site, the 03 has 22"/20" wipe blades.
Window Tinter in NJ
Legacy777 replied to yarikoptic's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbump.....may want to try the meet & greet forum or off topic
92 Legacy running extr. rough. Failed smog
Legacy777 replied to salewit's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, I'd suggest checking the ECU for codes, instructions can be found on my site with the link posted above. I'd also suggest replacing the coolant temp senser. Does the car run any differently when cold vs. when warmed up?
Looking to buy some new kicks for the OBS
Legacy777 replied to mellow65's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbump
Drum to Disk conversion on 2WD '92 Legacy?? yes,I searched.
Legacy777 replied to moosens's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXActually the first gen legacies were a lot more "plush" or refined then the impreza line....and even some of the second gen legacies. Subaru cheapened things in the mid-90's to cut costs.
2000 OBW ISV (possible)
Legacy777 replied to nomoaudi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's possible the idle air control valve is sticking. On the newer models they are on the throttle body, and can be removed & cleaned pretty easily.
air flow
Legacy777 replied to BIGBLUE1212's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRemove the air snorkel in the fender. That will help the air flow into the engine, and is a lot easier then drilling a bunch of holes in your airbox.
99 2.2 Timing Belt Idler with a Flange???
Legacy777 replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHmm....they must have changed things in 98 or 99. My 97 OBS still has the metal timing gears and standard idler pullies.
95 legacy MT input bearing question
Legacy777 replied to xzachtli's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre you sure it's not just the throw out bearing? I'd suspect that before the input bearing. If you were to replace the input bearing, I'm not sure whether it would need to be pressed on or not. Here's a scan of the main shaft...not sure if it helps http://main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/MT_main_shaft_assy.jpg
Nice LADY in Seattle needs help
Legacy777 replied to xoomer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd suggest posting in the WTB forum
storage compartment door Outback
Legacy777 replied to Scruffy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf noone knows on here, you may want to try www.legacygt.com/forums
Got a pic of the CTS location on a '96 2.2??
Legacy777 replied to moosens's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsent you a reply. check out these pics http://www.main.experiencetherave.com:8080/subaru/images/injectors/
97 legacy tps issue
Legacy777 replied to river rat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou may want to check the connector and wiring, and or clean it with some electrical cleaner.
Radiator for 94 Legacy Alpine?
Legacy777 replied to Sonicfrog's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd recommend an aluminum one with plastic end caps. I don't know of a dual core one for the non-turbos. If you find one please let us know, as I'd be interested!
Looking for Bay Area Mechanic
Legacy777 replied to Sirlono's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou may want to post in the meet & greet forum too.
90 legacy check engine light
Legacy777 replied to aartod's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere's another way with the connectors http://www.surrealmirage.com/subaru/engine.html
