Turbone
Administrator
    30
Everything posted by Turbone
  1. I go to a meet every Wed night and a few more during the month. This is from last Sat at the place I used to work at. This is the Wed night meet. I was the first one there and everyone parked the other way
  2. You can probably send him a email thru the CL ad. http://denver.craigslist.org/cto/3860571275.html Kind of weird that it has a WA plate in the rear and a OR plate on the front, but the ad is for Denver (Sunnyside is in OR)
  3. Maybe put a inner sleeve in the tube?
  4. Broke the 3rd speedo cable in 6mo in my RX Just bought a new one off Rockauto, hope it last longer
  5. For now, everyone use the nasioc link. I'll try and get it transfered to here soon. http://forums.nasioc.com/forums/showthread.php?t=742063
  6. Bump from the dead! In reply to bluto, I'm lovin it! I installed a fuel cut defender and have increased boost to 16psi. The only issue I have now is the clutch, it slips bad when hitting boost in 4th and 5th gear. Time for a stg 2 clutch! Then the trans will probably grenade and I'll have to build something or buy a stronger trans I have another project I'm about to begin, so work on the RX will be on standby.
  7. Could be that the axle you got isnt in too good of shape. Make sure the axle nut is as tight as you can get it (150ftlbs)
  8. Welcome to USMB. Did you see where the cable is supposed to attach to the trans? Its on the right side (passenger) of trans, you will see a hole where it threads into. Your shuddering could be due to the bad cv or it could be a tire out of balance. Cheaper to find out if the tire is balanced, then go from there. I dont think the clutch has anything to do with the shudder from take off as the axle swap did work for a short period.
  9. Glad to see everything worked out.
  10. Hey Torxx, you ever finish this? Got mine done a few years ago, you dont know what your missing!
  11. Hopefully the hose connections are correct also
  12. Pretty sure your right about it being knock sensor
  13. Should work, did you compare the pics with yours?
  14. x2 to the above. Having a loose nut on the wheel may have also damaged the splines in the hub, which has happened to me before. Torque on the wheel nut should be around 150lbs+/-
  15. If the clutch was on wrong you would not have been able to mate up the PP to the flywheel. Are the spring clips still attached to the lever and throwout bearing? Sometimes they will come loose during install. You may also need to adjust the cable nut so it has tension.
  16. Dont rattlecan it, go plastidip. It can be peeled off later and then painted correctly with the color you want. https://www.dipyourcar.com/
  17. Accel coils are notorious for failing within a year of use. I use a MSD on my Brat.
  18. Yes,a coil can start to act dodgy for a while before going out. The car will run like crap and when the coil overheats, it will quit working and the car wont run. Then after it cools off it will start again. Wash, rinse, repeat.
  19. Easiest way to reset the ECU is to disconnect the battery for 20min or so. What about the coil, done anything with that? I've had a few go out on me with EA81T's and EA82T's.
  20. Instead of tearing things apart and throwing money at it, I would try timing it by ear. See if you can get rid of the backfire first, then make a few runs in it to fine tune it. Advance it till it starts to knock, then back it off 3-4deg. If this doesnt get rid of the miss/backfire, I would pull off the valve cover to #2 cyl and check the exhaust valve springs.
