30
Everything posted by Turbone
Back on the road again This time it feels much better, but I still have the high idle issue. Who can tell me where the reed switch is on the inst panel? I cant find anything in my 86 FSM, I need something newer. Heres a few pics of the work I did this round. Stripped the intake and cleaned it Cut off the heatshields around the headers. Had to on one side, just to get the nuts off the head Cut off the mounting points for them, ground them down and sprayed with hi temp paint. Almost ready Also had a broken engine mount, got that fixed. A lot of you know I'm pretty anal about cleaning stuff, I've gone thru several wire wheels using my cordless drill. I just bought a new one, this time from Home Depot. The sucker was stiffer than a .......... you know. It kept grabbing on edges and getting loose, a few times raking my arm. I ended up making a gauntlet out of a jean pantleg and duct taping it to my arm. But it doesnt work if you dont wear it Also had a couple of issues when I went to start it. It wasnt starting so I pulled the plugs to check for fuel. Number one plug looked like this I gapped them and put them in after the heads were on, so I have no idea how it happened :-\ Then I wasnt getting any fuel. Tracked that down to nothing in the tank:rolleyes: The gauge showed 1/4 tank, so thats another one that made me scratch my head.
1989 RX Turbo - running like crap - need help
Turbone replied to T-Bagg86's topic in Old Gen.: 80's GL/DL/XT/Loyales...
How did you have it checked? I have one from my old setup. -
Any luck with Brat calipers on rockauto?
Turbone replied to renob123's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You have vented rotors, right? If they were the wrong ones, they would not have fit. -
ECM compatibility? and label translation please
Turbone replied to Frank B's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I believe he fixed his problem. Make sure you check post dates before replying. This one is 4yrs old. -
Well, you've had 2 days to try our suggestions. Is it still running bad? -
Vented are .70in and solids are .49in -
Thanks for the offer Dave, but I had a spare set already. They will probably be coming off again in several months......I have plans
How much new gas have you run thru it? Timing could be a issue as well. Make sure all the ground wires in the engine compartment are clean and tight, as well as the main harness connections. -
It did cause a timing issue, but it happened after I fixed a lot of other stuff and had it running good. I'm not sure how it happened, but I was on a 50mi run to a breakfast and wasnt being hard on it. It overheated right when I pulled into the parking lot and I filled it with a gal of water before hitting the road again. It was running rough at idle, but fine when the boost kicked in. It got progressively worse and I parked it. That was almost a month ago. When I installed the new t-belt I didnt notice if the pulley was loose, I didnt remove it either. I'm waiting on HG/intake gaskets right now, but in the meantime I'm doing my usual "cleaning"
Ok, had to pull the engine due to rough running and leaking oil out the HG's. This is what I found on the passenger head camshaft. I put a new t-belt on it before the install and didnt notice anything wrong with it. But at least I have another head to replace it
EJ22's are a dime a dozen, finding one with low mileage is just a tad harder. Finding a good EJ22T is another story I wasnt really looking, but when the deals came around I jumped on them. $300 for a long block and harness, plus some other stuff to go with it. $300 for a cut harness, ready to go. Also got a bunch of other stuff with the deal, which I sold and recouped some $. My flywheel I already had (XT6) and I did some trading with Scott to get it redrilled. The adapter plate I traded a set of EA82 rear discs for. Misc other stuff I got, but doesnt add up to $1k total. I have waaay less in this build than my previous EA82T, and I'm already collecting parts for building a hybrid engine (300hp+) Wheel and deal baby
So Really, how many started a ej swap and never finished it
Turbone replied to bheinen74's topic in Subaru Retrofitting
Wheres Caboobaroo? In his defense tho, he hasnt quit. Its just taking forever. -
With only 97k on the clock, I dont think he's going to have any issues for quite a while. Especially if he does some preventative maintenance. Granted, I wouldnt have forked out that much cash for it, but you clowns really need to get off the EA82T hate wagon. I hope you 2 come to WCSS12, I'm going to bring a bag of lemons so's you can sit at a table and suck on em
BRAT Meet **post your photos**
Turbone replied to Fenix747's topic in Meet n' Greet. Your USMB Welcome Center
Heres the vid I took of Chinook Pass. Lots of snow still up there. -
Dude, a speeding tic? :-\ I dont think I've ever driven that slow on a 300mi drive Cops were every where More pics! Took these with my cell... Everyone else make it home ok? Twitch? Fenix? (I know you only lived about a mile away, lucky) Got some vid of Chinook Pass, need to get it edited and uploaded. -
Pics or it didnt happen
More... Had a good time, the weather cooperated and the roads werent toooo bad. -
Well, Bill never showed either :-\ Had some problems, I'll let the guys that had them explain it all. I'm just going to post some pics Hope their not to big -
See you guys at 10am in E-Burg, I'm all ready to roll. -
Talk to Corky, he's bought from a local importer guy. He also has bought stuff at auctions.
