Turbone
Administrator
    30
Everything posted by Turbone
  1. Would be a good idea to register over here - http://subaruxt.com/forum/viewforum.php?f=1&sid=230f82ae140967de3052a23bb0d3c6ef
  2. http://www.ultimatesubaru.org/forum/showthread.php?t=88249
  3. Are you looking for parts? If so, this can be moved to the appropriate forum.
  4. So thats where we are all meeting on Sun at 10am?
  5. I was taught to use this in school, I have 2 tubes of it atm. Altho I havent replaced one myself yet, I have had 4 replaced in the last 5yrs. A 86 T-Wagon. My 89 RX. A 88 XT. And a 92 SVX, this one cost the most - about $230.
  6. Theres more to it then just slapping on a few parts before you can start it. Have you got a new water pump? How about a rebuild kit for the oil pump? (about $30 from the dealer) New timing belts and tenshioners? You may not need all of it, but the peace of mind of having these parts replaced and not having to go back and do it down the road is nice. If you want to test it to see if it starts and runs, you need all that on. But the radiator and alternator dont need to be hooked up. Yes, you can run it for a minute without water. But thats it. Do you know the procedure for installing the timing belts yet?
  7. I know the rear suspension can get mis-aligned, but I dont know what components need adjusting. Contact Caboobaroo, he's our resident alignment specialist. He aligned the rear on my RX.
  8. I'll see if I can find some. Shot of the rear bumper after I got the car.
  9. Its better to mount the EA rails to the seats than try and figure out how to attach stuff to the body. I installed some Legacy seats in my 84 Brat this way and all I needed to do was move one of the rails using a couple of steel plates. And I'm moving this to Retrofitting.
  10. I think I've seen that Hatch somewhere else before, maybe on the other side of the Mtns. I may have some parts for that Noah.
  11. Please go into your profile and turn your PM's on. That way you can be contacted and given instructions on how to post here.
    Your post is now in the right forum.
    http://www.ultimatesubaru.org/forum/showthread.php?t=112405
  12. Is the plastic on the bumper also melted? I ask this because my 89 RX was like what you described. But it was from running the engine so hard and low on oil it eventually threw a rod out the top of the block. But before that happened, it also melted a lot of the plastic in the area around the muffler and inside the rear compartment. The PO may not be telling you the entire story for sure.
  13. Pull the snorkus off the throttle body and dump a little gas in it. See if it wants to fire. If it does, then the inj or fuel lines could be plugged.
  14. Anything ever done by Block has been posted here....more than once
  15. http://www.ultimatesubaru.org/forum/showthread.php?t=112256
  16. Legally, you cant junk a car here in WA without a title. But that doesnt mean its not possible. If you know the wrecker, he might take it and immediately crush it. But thats a worse case scenario. Hopefully the car will show up soon, in one piece.
  17. Leave it be, Subaru said a long time ago that it was ok to run them that way. If they were bigger, they would need to be welded or pinned.
  18. Caboobaroo is working on this right now in his 86 RX*. He's having problems finding the right setup for the x-member as his body style is a little different, it used to have a AT in it. He had to have a driveshaft made also.
  19. Upgrading to XT6 swaybars helps a lot also.
  20. My technique is to use my Makita cordless, a 3in buffer pad, a squirt bottle with water and a bottle of Griotts glass polish. It takes me 10min a light.
  21. I think 96 was when it went to OBDII, I could be wrong tho. And it does have 2 02 sensors, one on each cat. I've never had to replace one, but I have removed the exhaust system before and know it can be a beotch. A good place to get accurate info is at http://www.subaru-svx.net/forum/
  22. Glad you had a uneventful trip, dont go and melt on us out there....alright?
