What have you done to your Subaru this week/lately?
1 Lucky Texan replied to pz99's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTDIL - humor is serious business!
Battery not charging.
1 Lucky Texan replied to bratlife's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMuch lifetime warranty stuff is slapped together with minimal attention to quality and the customer becomes the 'final QC'. They can win by the law of averages but 30% or w"ever of their customers may lose. And when a problem is happening to you, it's happening 100% of the time.
Suspension improvements for Subaru Loyale
look for a cracked spring? I've read once of a weird failure where the two broken ends would match back up after separating.
New Factory Fenders for '02 Legacy L Wagon
you might consider posting at subaruoutback.org also.
Cancel Post
I occasionally have to edit one to say "nevermind" , you can try that.
RockAuto.com Discount Code - Expires July 5, 2021
thanx, I may need to use this soon.
1 Lucky Texan replied to bratlife's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou do have options, used alt from wrecking yard or LKQ or car-part,com . DB Electric or Maniac have alts and maybe kits for rebuilding. At one time, Subaru offered some fairly inexpensive alternators for certain older year models....someone else will recall details on that.
1 Lucky Texan replied to pz99's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJonathan, any practical way to get something into the tank thru the pump's hole to knock the dent mostly back out without dropping it? I donno, a long wrecking bar or even some wood or aluminum you could hammer on the end of?
Were to go next?? P0301 Cyl. 1 misfire
1 Lucky Texan replied to Popeye.Tom's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyep, waste spark. if a coil is bad, it affects cylinders in these specific pair-combinations; either 1&2 OR 3&4 . does the car start just as quickly after sitting overnight (or for several hours) as when starting after just a few minutes? Wondering if that one injector is 'leaking-down' .
2005 2.5 Vin B code Engine head gaskets and timing belts
I think it's like generaldisorder said, the engines are already maxed-out. I think partly because they have to be; AWD presents about 20% frictional loss compared to 13% for 2WD. Doesn't mean the engines are slouches because there's no room to get much more from them, heck, they get used in homebuilt aircraft. They general design of them IS getting a little old though. And other makes of cars often get engine swaps to get more power. Some folks have found wrecked WRXes or other turbo models and swapped-in the engine or engine and drive train. Or done H6 swaps.
You cam make your car more fun to throw around the corners. You might free-up a pony or 2 stripping weight from the car. But there's nothing more to be had from the engine you have.
Curious observation
I found this; https://mechanics.stackexchange.com/questions/38966/air-trapped-inside-threaded-blind-hole-vs-hole-integrity
Curious observation
Maybe the sealant out-gasses when it cures?.....anyway, interesting observation. (I thought those bolts got oil on them, not sealant???)
Curious observation
depending of course on 'if/how quickly' a seal is formed by the threads, there could be pressurized air at the bottom of any 'blind' hole right?
Funny Story
1 Lucky Texan replied to 3Pin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdecades ago, I had a friend at work take a look at a malfunctioned VHS player I had. Figured it need a drive belt or something.....he said he forced an eject routine and about half a piece of buttered toast came out. yeah, kids. I've also heard, in very old houses with those old-style locks on the doors, old coins are often found inside. yeah, kids
Interchangeable small and large oil filters
1 Lucky Texan replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo experience really. But in the past, I had done some reverse look-ups and saw where our soobs share some filters with quite a few hondas. And, I think I also found where my 2 cars can interchange.
Cabin Air Filter
1 Lucky Texan replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf Mahle makes them, theyd be ok. Just istn't a critical item.
Cabin Air Filter
1 Lucky Texan replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcoolant low in radiator or overflow?
HELP - DOHC Crank and Cam Seal change and now will not start!
1 Lucky Texan replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIACV hose knocked loose at the intake?
Cabin Air Filter
1 Lucky Texan replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXconsidering we didn't do too badly without them for 90+ years, I'd either get the cheapest, fab one from some kinda filter material (did that a coupla times back when there weren't aftermarket choices) or do without. If you suffer excessively from mold, pollen or other allergens, you may of course need to shop carefully.
'96 Legacy clutch replacement any good videos?
gah, missed that.
check separator plate on rear of engine for leakage - metal plate likely OK. IF it's plastic, replace with metal. (I think 96 would be metal - guys???)
buying 2010 Forester
1 Lucky Texan replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXshort answer, no, not from what I've read.
99 Legacy 2.2 dies at times, no Codes set?
1 Lucky Texan replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsome crank sensors from the 90s will crap-out when hot...
1 Lucky Texan replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTRy shifting into neutral before stopping. Maybe TC lock-up not releasing?
