lift and tire size combo pics...
I used this in a PM, and thought it might be a good sticky. Feel free to add pics. I will eventually take all the pictures and use them in a rehosted page...
post pics and description of lift and tires only. other stuff WILL be deleted.
3" lift, pug 15" alloys, 205/65r15, just a slight roll at back of wheel well in front...
same lift, with 195/70r14 tires.
same lift, 205/70r14 tires on genuine subaru alloys...
3" lift, 14" pug steels, 27x8.50x14 BFG All-Terrains. slight trimming of rear of front wheel well...
same vehicle with same size tires, but BFG Mud Terrain.
same wagon with 225/70r14 ATs, and a different Brat with 4" lift, and the 27x8.50x14 BFG Mud-Terrains.
same wagon, but with 4" lift, 27x9.50x15 Swamper SSRs on 15" chevy/toyota wheels (high offset). still haven't beat enough to stop rubbing....
Brat with 5" lift and 27x9.50x15 swampers on same wheels as above.... lots of trimming/bashing, and tied down in pic....
same Brat with complete customs suspension, toyota axles, lots of trimming, and 315/70R17 (35") all-terrains.
Comparison to Blue Brat from above...
  • Replies 78
  • Views 208.4k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • 1985 GL Wagon 4WD   6" JAW Lift (6" Suspension, 4" Body) 235/75/15 Maxxis Bighorn Tires 29x9.5x15" (Roughly) 15x7" Allied Daytona Wheels With 4.5" Backspacing 6 Lug Conversion
  • 2" SJR lift with 27x8.5R14 (General Grabber AT2) tires, 14" Pug steelies. No rubbing unless you're at the extremes of the suspension, but I've also hammered my front fenders quite a bit.
  • 3" rear /4" inch front - lift and 27 inch tsl swampers oh yah, and superlite 15x6 rims:banana:
Posted Images
2" lift. 205/75/14 tires on alloy pugs.
No bashing, it's a tight fit, but no rubbing.
I do have a load, so that's probably lowering it a little bit more than when there's no boat on the roof
Edited by 987687
No lift, but some people are interested in what fits without one, so here are 205/70/14s, with no lift, no bashing, and an ever so slight rub on the fender at full lock compressed suspension.
195/75/14s don't rub at all. The wheels are off of an older Dodge D50 (I think.)
Dan
31x10.5 15's Pugs! 9 inch lift a little cutting & trimming needed... maybe a little right behind the front tires.... when off the road
Edited by 88Subi4x4
6" lift, 15" re-drilled yotas, 29"x8.50" bias swampers, and 235/75 wildcat EXT's.
Front radius rods sleeved and extended 1.25".
FRONT: Removed valance below the bumper. Front of fender folded in. No (zero) cutting/bashing behind the tire, only rub ever so slightly at full lock when seriously off camber/stuffed.
REAR: Minor bashing in the front of the wheel arch, removed factory mudflaps. No rubbing at all, ever.
here is mine I went 4 7/8 with the front to get it level 4 in the rear
27 in ssr swampers little cut to front of rear and alot of bashing to the firewall and cutting rear to front fender
should have went six still hits at full lock four wheeling
No lift, Lot's of trimming 205/70/15 tires on redrilled narrow offset toyota wheels.
6" lift, 265/70/16 They are bit too big for anything but the sand dunes.....I went back down to a 235/75/15 for better gearing offroad.
  • 1 month later...
recent2.jpg?t=1294138717
recent.jpg?t=1294138717
6 inch (started out as a 4) with 30x9.5 cooper discoverer stt 15's
Edited by CHIM
photo's didn't link correctly
8" Lift
30X9.50X15 Buckshot mudders
slight trim in the rear of the front fenders and Rolled the pinch weld
2" lift
226/60/16
cut the front side of the fender but only needed a nip off the corner
2" lift
27X8.50X14 wild cats
no cutting
Jeff
Edited by one eye
  • 3 weeks later...
Just for giggles, this is my 93 Legacy with ~2" lift from Forester struts and 185/70/14s. New tires coming soon.
With Falken Radial A/P 205/75/14
Edited by SubaruFred
  • 2 weeks later...
2" Lift on the front and 3" lift on the rear with 205/75/14 on mazda 6lug redrilled
1998 Subaru Outback Limited 5mt
2004 KYB Subaru Forester struts & springs
HighGuys 3 inch lift
215/70/16 General Grabber A/T2s
16X6.5 Steel Wheels
Rubbed on the lower edge of front fenders so massaged to fit
Edited by newsoobdude
^Nice ride! I've got a '96 and was curious about doing a lift and bumper kinda like that. Is this your daily driver? How much did all of it cost? And are you satisfied with the result?
1995 legacy L
99 OB struts (KYB GR2)
99 FOR springs in rear
94 SVX springs in front
27x8.5 14" General Grabber AT2
I want one of those bumpers for my 90 legacy wagon. They're fricken sweet. Where did u get it from. I wonder if i can mod it to fit my car or if it will just bolt in, that would kick rump roast :headbang:
  • 1 month later...
swapped 98' outback struts with a little pinch weld modification in rear very little plastic inner fender rub at full lock while suspension is maxed out and some inner fender rub when jumped. 28x 8.50 r14 super swamper tsls also have a set of 205/70r15 snow tires with no rubbing at all.
photo.php?fbid=104772626262589&set=a.104772622929256.7970.100001895568725&theater
photo.php?fbid=129751387098046&set=a.104772622929256.7970.100001895568725&theater
how did you get the toyota axles on the brat. i am planning something similar with my 95 legacy and would like any tips i can get.
mudrat in Eugen, OR
This one wouldn't fit the first gen legacy, but he'd build you one that would!!
http://www.oregonoffroadsubaruclub.org/mudrat_index.html
86 gl wagon 6"SJR lift + coilovers for 05 outback 5bolt conversion with 5x4.5 adapters. 17x9 cobra style wheels powercoated red. 2656517 blizzaks.
Same car with 6" SJR lift without coilovers, chopped bronco2 springs installed into stock clearanced struts. was on before I went to the smaller tires above because the transmission could not handle the rubber. 33x12.50R15 bridgestone dueler MTs american racing baja 15x8 6 bolt.
moms legacy with otback struts. stock wheels 1857514 cooper ats.
Edited by roostema4328
  • 1 month later...
9 inch lift
31x10.5 R15 (not to aggressive but a lot quieter then my old tires)
-4.jpg[/img]
  • 2 weeks later...
Very neat.
How do these cars handle (especially the older GL's) around town? Do they feel unsteady when you hit something like a bump at hwy speeds?
My 86 kicks around alot but I would think that 27-33" tires would absorb alot more than the little 13" tires I have now.
  • 1 month later...
3 inch lift all round
27 inch tyres on 14 inch scorpion rims of correct offset.
Some guard trimming on the front when I had desert rat rims.
Now some rubbing at full lock on chassis rails up front, only near the firewall though.
Honda civic front springs in the rear :D
Pics:
Cheers
Bennie
Edited by Zap
