December 11, 200718 yr Ok so with the increase in posts asking "can an (insert EJ motor) be put into (insert EA body)" I thought it would be good to compile a list of EJ swaps that way people can ask specific questions through PM. Here goes: Board Member: S'ko Engine: OBD1 EJ18 Chassis: 1982 BRAT Tranny: EA81 D/R 4spd Other: 5 inch lift, 5 lug swap, EA82 crossmember for Powersteering Edited December 21, 200817 yr by Qman
December 11, 200718 yr #1 Board Member: Rguyver Engine: EJ20 WRX Chassis:1983 Brat Tranny:WRX 5speed Other: STI brembos http://www.ultimatesubaru.org/forum/showthread.php?t=58869 http://www.ultimatesubaru.org/forum/showthread.php?t=79688 #2 Engine:EJ22 N/A Chassis:1983 Hatch Tranny:EA D/R 5speed with adapter Other: 6" lift and 29" /11.50 Swamper SSR
December 11, 200718 yr Board Member: Lazer Engine: EJ20g legacy turbo with vf34 turbo Chassis:1985 Xt turbo Tranny:forrester turbo with lsd rear Other: full legacy/forrester turbo drivetrain with legacy turbo brakes up front. Big front mounted intercooler, autronic ecu, etc.
December 12, 200718 yr Ultimate RX Board Member: Subarutex Engine: JDM Legacy EJ20G Chassis: 1987 RX Coupe Tranny: JDM Legacy 5spd 4.11 Other: 5 lug swap, Haltech ECU, DOMtune, 3" Exhaust, 175hp/205 ftlbs Brown Beast Board Member: Subarutex Engine: '92 EJ22 Chassis: 1986 GL Wagon Tranny: EA82 D/R 5spd Other: 3" BYB/Ozified Lift, Mrose Adapter Plate, Wiring by ShawnW, OBX header, Custom Exhaust, Etc... See link for pics...
December 12, 200718 yr My car: Engine: '92 Legacy OBD I EJ22e Chassis: '92 Loyale Wagons Tranny: EA82 D/R FT4WD 5spd Other: Mrose Adapter Plate, OBX header, 5-lug swap, RS front brakes, 200SX rear calipers current project: Engine: '96 Impreza OBD II EJ22e Chassis: 1986 GL Wagon Tranny: EA82 D/R 5spd Other: Rear disc brakes, rguyver adapter plate
December 12, 200718 yr Engine: 1990 EJ22 (OBD I) .. wiring harness by me! Transmission: 1989 RX FT4WD dualrange 3.7 w/ 3.7 LSD rearend Chassis: 1986 GL10 wagon, 4" BYB/PK lift kit Suspension: 5-lug swap - REAR: XT6 full w/ RX stepped GR2 shocks. FRONT: XT6 front control arms & front calipers, legacy front spindles, caliper brackets & GR2 struts, WRX springs. XT6 front & rear sway bars. Other: Mrose adapter plate, "corrected" strut rods (4" engine drop vs. 3" trans drop), 2.25" exhaust, XT4 power steering rack
December 12, 200718 yr Engine: OBD1 EJ22 Chassis: 1989 Brumby (same as EA81 style Brat) Tranny: Hybred EJ D/R FT4WD box Other: 2" body lift. custom front suspension arms, more Before you ask: Gearbox uses Liberty (Legacy) Dual range casing, with EA82 FT4WD centre lockable diff and EA82 1.59 to 1 low ratio. Oh, I'll also add I'm using standard EA81 dual core radiator with no dramas except when half of it got covered in mud.
December 12, 200718 yr Board Member: Matty B Engine: EJ20G, (1996 WRX) Chassis: 1989 WonderBrumby Tranny: Liberty AWD with custom low gearset. Other: 2 inch lift, 6 lug conversion, custom steering, Skid plating, VSLD, insanely bright lights, Coil over rear struts, Recaro seats, Bullbar and Rollbar.
December 13, 200718 yr 2.5 RX Chassis: 1988 AWD Rx coupe Engine: SOHC EJ251 Drivetrain: 1996 Impreza Outback AWD 3.9 transmission with converted stock 3.9 LSD Other: Drop springs, fancy gauges, eyebrows, high-tech two tone paint, and one legacy turbo seat(in progress)
December 14, 200718 yr EJ22 OBD1, dual range EA82 tranny. Loyale body, 4" lift. Using stock loyale radiator, saab 9000 turbo pusher fan running backwards to fit in engine side of fan.
December 16, 200718 yr Board Member: Suberdave Engine: Early 1996 JDM WRX EJ20G Chassis: 1988 GL-10 Wagon Tranny: JDM WRX 5spd 4.111:1 with LSD Rear Diff Other: 5 lug swap, Catless uppipe to 3" TBE, 225.5hp/210 ftlbs, Tien Flex Coilovers w/ EDFC, Huge FMIC, Nissan rear E-brake, Wilwood 4pot calipers with 12" crossdrilled slotted rotors, RX body Kit, ECT... [/url] Board Member: Suberdave Engine: 1993 EJ22 Chassis: 1987 GL-10 Wagon Tranny: RX FTSWD Difflock D/R 5spd Other: 6lug hubs w/ Nissan wheels, 26" Wildcat EXT's 3" BYB/Ozified Lift, Police push bumper, ECT... Check out my webpage for more pics -=Suberdave=- http://www.suberdave.com
December 16, 200718 yr Board Name: LPGsuperchargedBrumby Engine:EJ18 Carb & Dizzy on LPG(propane) Transmission: Rx FT4WD 5SP D/R Chassis: '92 Brumby Other: custom DOJs, homemade adaptor plate and a one piece driveshaft.
December 17, 200718 yr Alright I'll bite ENGINE OB1 EJ22 TRANNY 5 speed D/R with adapter CHASSIS 1987 GL wagon OTHER 2" spring lift,Wiring by Noahdl, agressive snow tires on 15" redrilled chevie steelies...
December 22, 200718 yr ENGINE: OB1 EJ22 with cone air filter & Diamond Coil Pack TRANNY: 5 speed D/R 4WD with M. Rose adapter plate and Jerry's kit CHASSIS: 1982 GL Hatch OTHER: 14" Peugeot Wheels - JDM Fender Mirrors - Volkswagen VR6 stereo Antenna - H4 Headlights - Turbo Rear Disk Breaks - Hella Horns - A-Style Push Bar with Lots of lights - 2.5" Straight Back Exhaust with a Borla Muffler - 1993 Legacy Seats - Custom One Piece Drive Line - Pioneer Premier Stereo and Speakers - 1980 Toyota Celica 5sp Shift Knob - Shaved all Emblems and Trim off and filled in - Dark Window Tint - Custom Painted Satin Black - Hood Pins - Optima Battery Relocated to Rear of Hatch - Toyota Clinometer - Passing Light (in the grill) - Original to the car Subaru Rubber Floor Mats - I also put on a fresh set of Bumpers & ENGINE: EA81 with custom intake manifold and weber carb TRANNY: 4 speed D/R 4WD CHASSIS: 1978 BRAT OTHER: Brush Guard with lots of lights - EA82T Exhaust Manifold to relocate muffler into the spare tire area and exit out the driver’s side fender - Pug Steelies with Super Swampers - I also pulled all bumpers, steel panels and interior out.
December 22, 200718 yr Board Member: ManYaiK Engine: 1992 EJ22 Chassis: 1987 GL Wagon Tranny: EA82 DR4WD (converted from 3AT 4WD) Other: Mrose Adapter plate, 14" Peugeot Alloys, 2.25" catback exahast w/ Mangnaflow Muffler
December 25, 200718 yr SHELL: 1992 subaru sedan ENGINE: 1991 EJ22 Transmission: Hybird, EJ Front case halves, ea82 internals and tailshaft TRANSFER CASE:1983 Datsun HI LO DIFFS: Front 4:11 open REAR 4:11 open (soon to be lsd) WHEELS&TIRES:31.1050 mt with toyota alu wheels LIFT KIT: 8" custom homemade with tie bars
December 28, 200718 yr Board Member: Sister7 Engine: EJ20G from 1993 JDM WRX Type RA Chassis: 1987 "RX" turbo coupe Tranny: JDM 4.11 5spd Other: Built by Suberdave.
January 4, 200818 yr body: 82 brat dl engine: 91 ej2.2 transmission: 5 speed hybird part time wheels: 15" 505 alloy peugot rear brakes: turbo rear disk brake setup ty-top campertop rear seats almost rust free factory roll bar
January 12, 200818 yr Body: 79 Brat Engine:odb1 ej22 Trans: 3.90 5spd d/r Other: 3" body lift. 83 wagon front x-member, a-arms, power steering, brakes, 81 wagon rear torsion tube. Rear disks, welded rear. Six lug hubs, 15" nissan steelies...
January 14, 200818 yr Body: 83 GL-10 Turbo wagon Engine: 93 EJ22 Trans: 3.7 RX trans and LSD rear diff (soon to be 3.9 D/R from 88 SPFI Wgn)
July 16, 200817 yr Author body: 87 RX Coupe engine: 92 ej22T transmission: fulltime 5 speed D/R RX tranny 3.7 w/rear LSD wheels: 13" Captain America wheels WRX TMIC 3 inch downpipe Soon to come hood scoop.
July 19, 200817 yr Board Member Zap Body 84 Turbo Coupe Engine 92 Legacy 2.2 turbo Transmission Legacy 4.111 Suspension 4/3 lift by SJRLIFT.com Wheels 15X6 Superlites Tires 215/75/15 BFGoodrich MTs Other Not quite done yet. . . almost.
July 24, 200817 yr Board Member: Crockettbrat Body: 1984 Brat Engine: OBDI EJ22 Transmission: 5sp d/r with LS Diff Suspension: 4/3 SJRLift Wheels: 15" alum pugs Tires: 215/75/15 Firestone Destination ATs
July 24, 200817 yr I feel like I missed the memo... Board Member: ballitch Engine: OBD1 EJ22 harness, MY96' Impreza engine Chassis: 1986 GL wagon Tranny: Stock D/R 5 speed. Other: 5 lug swap, using xt6 knuckles, along with the normal 5 lug rear stuff. 02-03 WRX rims and tires, 02 WRX struts and springs. Gr-2's in the rear w/ honda accord springs. (horrible, I know) ~Josh~
August 2, 200817 yr Board Member the_postie Body 88 ea touring wagon Engine ej22 Transmission owner built fwd 4eat.4.111 converted to 4.44 ,wrx tt vtd rear transfer added,4.44 vlsd rear diff. Suspension combination of 2" and 4" front and rear Wheels 14x6 speedys soon to be 15x6 Tires 27x8.5 nankangs soon to be 215/80x15
