EJ swap who's who
Ok so with the increase in posts asking
"can an (insert EJ motor) be put into (insert EA body)"
I thought it would be good to compile a list of EJ swaps that way people can ask specific questions through PM.
Here goes:
Board Member: S'ko
Engine: OBD1 EJ18
Chassis: 1982 BRAT
Tranny: EA81 D/R 4spd
Other: 5 inch lift, 5 lug swap, EA82 crossmember for Powersteering
Edited by Qman
  • Replies 97
  • Views 91.8k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • kingbobdole
    kingbobdole
    Owner: Zem Body: 1984 GLF Coupe Hardtop Engine: 97 Impreza OBS EJ22 Transmission: 97 Impreza OBS AWD 3.9 with VLSD 3.9 rear OBD2 compliant, scannable, super clean emissions. Custom trans mount,
  • Body: 1986 Subaru BRAT   Engine: EJ25D block, EJ22 single port heads, Delta Cams (torque grind), Stainless steel UEL headers, Under drive pully, K&N drop in filter, JDM EJ25D injectors, Forester
  • My car: Engine: '92 Legacy OBD I EJ22e Chassis: '92 Loyale Wagons Tranny: EA82 D/R FT4WD 5spd Other: Mrose Adapter Plate, OBX header, 5-lug swap, RS front brakes, 200SX rear calipers   current p
Board Member: Lazer
Engine: EJ20g legacy turbo with vf34 turbo
Chassis:1985 Xt turbo
Tranny:forrester turbo with lsd rear
Other: full legacy/forrester turbo drivetrain with legacy turbo brakes up front. Big front mounted intercooler, autronic ecu, etc.
Ultimate RX
Board Member: Subarutex
Engine: JDM Legacy EJ20G
Chassis: 1987 RX Coupe
Tranny: JDM Legacy 5spd 4.11
Other: 5 lug swap, Haltech ECU, DOMtune, 3" Exhaust, 175hp/205 ftlbs
Brown Beast
Engine: '92 EJ22
Chassis: 1986 GL Wagon
Tranny: EA82 D/R 5spd
Other: 3" BYB/Ozified Lift, Mrose Adapter Plate, Wiring by ShawnW, OBX header, Custom Exhaust, Etc...
See link for pics...
My car:
current project:
Engine: '96 Impreza OBD II EJ22e
Other: Rear disc brakes, rguyver adapter plate
Engine: 1990 EJ22 (OBD I) .. wiring harness by me!
Transmission: 1989 RX FT4WD dualrange 3.7 w/ 3.7 LSD rearend
Chassis: 1986 GL10 wagon, 4" BYB/PK lift kit
Suspension: 5-lug swap - REAR: XT6 full w/ RX stepped GR2 shocks. FRONT: XT6 front control arms & front calipers, legacy front spindles, caliper brackets & GR2 struts, WRX springs. XT6 front & rear sway bars.
Other: Mrose adapter plate, "corrected" strut rods (4" engine drop vs. 3" trans drop), 2.25" exhaust, XT4 power steering rack
Engine: OBD1 EJ22
Chassis: 1989 Brumby (same as EA81 style Brat)
Tranny: Hybred EJ D/R FT4WD box
Other: 2" body lift. custom front suspension arms, more
Before you ask: Gearbox uses Liberty (Legacy) Dual range casing, with EA82 FT4WD centre lockable diff and EA82 1.59 to 1 low ratio. Oh, I'll also add I'm using standard EA81 dual core radiator with no dramas except when half of it got covered in mud.
Board Member: Matty B
Engine: EJ20G, (1996 WRX)
Chassis: 1989 WonderBrumby
Tranny: Liberty AWD with custom low gearset.
Other: 2 inch lift, 6 lug conversion, custom steering,
Skid plating, VSLD, insanely bright lights,
Coil over rear struts, Recaro seats, Bullbar and Rollbar.
2.5 RX
Chassis: 1988 AWD Rx coupe
Engine: SOHC EJ251
Drivetrain: 1996 Impreza Outback AWD 3.9 transmission with converted stock 3.9 LSD
Other: Drop springs, fancy gauges, eyebrows, high-tech two tone paint, and one legacy turbo seat(in progress)
EJ22 OBD1, dual range EA82 tranny. Loyale body, 4" lift. Using stock loyale radiator, saab 9000 turbo pusher fan running backwards to fit in engine side of fan.
Board Member: Suberdave
Engine: Early 1996 JDM WRX EJ20G
Chassis: 1988 GL-10 Wagon
Tranny: JDM WRX 5spd 4.111:1 with LSD Rear Diff
Other: 5 lug swap, Catless uppipe to 3" TBE, 225.5hp/210 ftlbs, Tien Flex Coilovers w/ EDFC, Huge FMIC, Nissan rear E-brake, Wilwood 4pot calipers with 12" crossdrilled slotted rotors, RX body Kit, ECT...
[/url]
Engine: 1993 EJ22
Chassis: 1987 GL-10 Wagon
Tranny: RX FTSWD Difflock D/R 5spd
Other: 6lug hubs w/ Nissan wheels, 26" Wildcat EXT's 3" BYB/Ozified Lift, Police push bumper, ECT...
Check out my webpage for more pics
-=Suberdave=-
http://www.suberdave.com
Board Name: LPGsuperchargedBrumby
Engine:EJ18 Carb & Dizzy on LPG(propane)
Transmission: Rx FT4WD 5SP D/R
Chassis: '92 Brumby
Other: custom DOJs, homemade adaptor plate and a one piece driveshaft.
Alright I'll bite
ENGINE OB1 EJ22
TRANNY 5 speed D/R with adapter
CHASSIS 1987 GL wagon
OTHER 2" spring lift,Wiring by Noahdl, agressive snow tires on 15" redrilled chevie steelies...
ENGINE: OB1 EJ22 with cone air filter & Diamond Coil Pack
TRANNY: 5 speed D/R 4WD with M. Rose adapter plate and Jerry's kit
CHASSIS: 1982 GL Hatch
OTHER: 14" Peugeot Wheels - JDM Fender Mirrors - Volkswagen VR6 stereo Antenna - H4 Headlights - Turbo Rear Disk Breaks - Hella Horns - A-Style Push Bar with Lots of lights - 2.5" Straight Back Exhaust with a Borla Muffler - 1993 Legacy Seats - Custom One Piece Drive Line - Pioneer Premier Stereo and Speakers - 1980 Toyota Celica 5sp Shift Knob - Shaved all Emblems and Trim off and filled in - Dark Window Tint - Custom Painted Satin Black - Hood Pins - Optima Battery Relocated to Rear of Hatch - Toyota Clinometer - Passing Light (in the grill) - Original to the car Subaru Rubber Floor Mats - I also put on a fresh set of Bumpers
ENGINE: EA81 with custom intake manifold and weber carb
TRANNY: 4 speed D/R 4WD
CHASSIS: 1978 BRAT
OTHER: Brush Guard with lots of lights - EA82T Exhaust Manifold to relocate muffler into the spare tire area and exit out the driver’s side fender - Pug Steelies with Super Swampers - I also pulled all bumpers, steel panels and interior out.
Board Member: ManYaiK
Engine: 1992 EJ22
Chassis: 1987 GL Wagon
Tranny: EA82 DR4WD (converted from 3AT 4WD)
Other: Mrose Adapter plate, 14" Peugeot Alloys, 2.25" catback exahast w/ Mangnaflow Muffler
SHELL: 1992 subaru sedan
ENGINE: 1991 EJ22
Transmission: Hybird, EJ Front case halves, ea82 internals and tailshaft
TRANSFER CASE:1983 Datsun HI LO
DIFFS: Front 4:11 open
REAR 4:11 open (soon to be lsd)
WHEELS&TIRES:31.1050 mt with toyota alu wheels
LIFT KIT: 8" custom homemade with tie bars
Board Member: Sister7
Engine: EJ20G from 1993 JDM WRX Type RA
Chassis: 1987 "RX" turbo coupe
Tranny: JDM 4.11 5spd
Other: Built by Suberdave.
body: 82 brat dl
engine: 91 ej2.2
transmission: 5 speed hybird part time
wheels: 15" 505 alloy peugot
rear brakes: turbo rear disk brake setup
ty-top campertop
rear seats
almost rust free
factory roll bar
  • 2 weeks later...
Body: 79 Brat
Engine:odb1 ej22
Trans: 3.90 5spd d/r
Other: 3" body lift. 83 wagon front x-member, a-arms, power steering, brakes, 81 wagon rear torsion tube. Rear disks, welded rear. Six lug hubs, 15" nissan steelies...
  • 6 months later...
body: 87 RX Coupe
engine: 92 ej22T
transmission: fulltime 5 speed D/R RX tranny 3.7 w/rear LSD
wheels: 13" Captain America wheels
WRX TMIC
3 inch downpipe
Soon to come hood scoop.
Board Member Zap
Body 84 Turbo Coupe
Engine 92 Legacy 2.2 turbo
Transmission Legacy 4.111
Suspension 4/3 lift by SJRLIFT.com
Wheels 15X6 Superlites
Tires 215/75/15 BFGoodrich MTs
Other Not quite done yet. . . almost.
Board Member: Crockettbrat
Body: 1984 Brat
Engine: OBDI EJ22
Transmission: 5sp d/r with LS Diff
Suspension: 4/3 SJRLift
Wheels: 15" alum pugs
Tires: 215/75/15 Firestone Destination ATs
I feel like I missed the memo...
Board Member: ballitch
Engine: OBD1 EJ22 harness, MY96' Impreza engine
Chassis: 1986 GL wagon
Tranny: Stock D/R 5 speed.
Other: 5 lug swap, using xt6 knuckles, along with the normal 5 lug rear stuff. 02-03 WRX rims and tires, 02 WRX struts and springs. Gr-2's in the rear w/ honda accord springs. (horrible, I know)
~Josh~
  • 2 weeks later...
Board Member the_postie
Body 88 ea touring wagon
Engine ej22
Transmission owner built fwd 4eat.4.111 converted to 4.44 ,wrx tt vtd rear transfer added,4.44 vlsd rear diff.
Suspension combination of 2" and 4" front and rear
Wheels 14x6 speedys soon to be 15x6
Tires 27x8.5 nankangs soon to be 215/80x15
