February 5, 200917 yr Here's mine, I obviously have different headlights now. They aren't great, But they have a cage built around them for protection. I still want to get some more on my Push bar
February 5, 200917 yr for now, getting at least another pair for the bumper, as well as some floods off the basket.
February 6, 200917 yr My brothers old wagon, thought it might be fun to add some more lights! And my brumby before I sold it, a 165 rectangle Hella mounted behind the petrol tank for rear lighting and two 12v fluro tube mounted to the side of that support beam under the car below the seats. I also ran two 165 rectangle spotties on the bullbar and the quad lights used 100w H1 on the inners and Narva +50's H4 55/60w on the outters. So much light the road signs were blinding.
February 6, 200917 yr Phizinza, did you just french the whole headlight bucket onto the radiator support and then cut openings in the grill? Looks cool!
February 6, 200917 yr 2 on the front tow bar, 4 on the front of the rack, 2 on the back of the rack. I used to have another 2 on the sides of the rack, but I took those off. Here is the control panel I have a 4 gauge wire from the battery going to a custom separate fuse panel below the glove box. Every pair of lights has a switch, a relay, and its own fuse!
February 6, 200917 yr Even though mine's just a thread over, figured I'd post anyway... Might get some more this weekend since everything is put back together...
February 6, 200917 yr Aux backup lights tucked up under the handle. Wired into the rear defrost switch as my defrost lines are gone off the window anyway. (I have a remote power port wired to a toggle on the dash that has a little 12V heater mounted in the back to defrost the window, can also use the port for air compressors, ect.) Edited February 6, 200917 yr by TeamCF
February 6, 200917 yr I've got fog lights off a newer ford ranger with 100w blue bulbs that I trimmed up and recessed into the grill, and a PIAA wiring harness/switch w/ relay. And if I ever buy/build a basket roof rack I have spot lights to put on.
February 7, 200917 yr Phizinza, did you just french the whole headlight bucket onto the radiator support and then cut openings in the grill? Looks cool! Heres a link to an old page about it
February 7, 200917 yr Here's Sophia with her Lightforce 240s sporting blue filters, which increase contrast so you can tell the difference between the snow on the road and the snow in the air. And the cheap floodlights on the back bumper, wired to either come on manually or with the stock reverse lights. And here's Roxanne (RIP), with the Lightforce 170s, as well as rack-mounted floods and spots.
February 7, 200917 yr I've got fog lights off a newer ford ranger with 100w blue bulbs that I trimmed up and recessed into the grill, and a PIAA wiring harness/switch w/ relay. And if I ever buy/build a basket roof rack I have spot lights to put on. Nice bumper! Did you fab that yourself?
February 8, 200917 yr Phizinza....I'm LOVING the rock light setup. never seen 'em on a subie. MysteriousXTC....awesome bumper. seriously impressive fab work there! FYI, the corner lights on the blue wagon were re-wired. the orange, side-facing ones as parking lights, and the white, front-facing ones as turn signals. which is why they're off. Edited February 8, 200917 yr by Numbchux
February 8, 200917 yr Nice bumper! Did you fab that yourself? Thanks. Yes I did. I have one on the rear also.
February 11, 200917 yr I can put about 650w shining forward...my poor alt! http://www.ultimatesubaru.org/forum/album.php?albumid=54&pictureid=356
