* * * * * 6 votes
7282 replies to this topic
#5076 dennyt
dennyt
    USMB Regular
  • PipPipPip
  • 60 posts
  • Seattle, WA
Posted 10 January 2013 - 03:53 PM
My '94 Loyale received its 248,000 mile upgrades:
Replaced exhaust Y-pipe and mid-pipe with RockAuto parts to get rid of a heat shield rattle, which also gave me more power - stock cats must have been plugged up.
Replaced rear wheel bearings
Installed rear disk brakes from junkyard
Installed polyurethane bushings on rear swingarms (saw thread on this forum)
Installed new KYB GR2 shocks and struts all around. Found p/n's on this forum. Oddly enough, the front left was $7 and the front right was $50 on Amazon.com.
Installed Spring Rubbers in rear to boost spring rate and keep the car off the bump stops when fully loaded. Resulted in about a 1" lift in the rear. P/N 917250-075 required some trimming and a hammer to fit in the stock coil springs.
Replaced front tie rod ends and ball joints
Replaced front right axle - the inner CV joint was cooked by the old cat
Found the FR lower control arm bolt hole in the subframe was ovalized from hitting a curb. Loose and rattling & full of rusty water. Filled it with JB-weld, we'll see how that holds up :)
Nice new Rain-X winter wiper blades, totally worth it after dealing with crappy blades forever
Fixed oil smell in cabin by replacing cracked PCV hoses, PCV valve, and oil filler cap which was loose
Replaced valve cover gaskets
Fixed heater leak between A/C evaporator and heater core. Whenever the heater fan was on, cold air would blow out of the glove box area. Added a bunch of weatherstrip around the duct and re-fastened the duct clamp which was loose. Also patched up a duct hole a mouse had chewed through.
Replaced timing belts (much easier without covers!), spark plugs, and wires
Added weatherstripping to body side of all door seals and re-glued some door seals that had been torn off after freezing to the car. Applied a bunch of silicone spray to all of the seals.
Lubed all locks and latches.
Fixed driver's door rattle - missing rubber ring on door latch. Gorilla tape.
New iphone holder for the dash and 2-foot right-angle aux cable, non-retractable. Listening to audiobooks on my commute rocks!
LED dome light bulb and installed a hatch-area LED dome light this spring.
Installed some awesome General Altimax Arctic snow tires!
Posted Image
This is a lot of work for an old car, but I love it, because it's a better car now than when I bought it 115K miles ago. I'm still waiting for the clutch to go so I can install the dual range tranny and reseal the engine.
Thanks to all who contribute to this forum - I wouldn't have done half of this work without the inspiration and technical details I find here!
Edited by dennyt, 11 January 2013 - 12:35 PM.
#5077 l75eya
l75eya
    Almost has it all figured out
  • 2,371 posts
  • Hoboken, NJ
Posted 10 January 2013 - 05:04 PM
This is what dreams are made of. :drunk: haha, Awesome job. Do you have pics of your car up in the my rides section?
I like seeing well taken care of roo's.
Makes what I did to my GL really pale in comparison.....;
I changed my oil. @ 70k ;)
Posted Image
#5078 jonas
jonas
    Subaru Nut
  • 1,209 posts
  • Oakridge
Posted 12 January 2013 - 02:00 AM
Hit 200k on the Brat!
#5079 1-3-2-4
1-3-2-4
    Subaru Mike!
  • 3,792 posts
  • Greenwich
Posted 12 January 2013 - 09:37 AM
I'm really thinking about getting those General Altimax Arctic tire week after next, my A/S are almost bald and with the weather hardly much of any snow here in the Northeast I figure these should run ok..
I had the firestone winter force tires on when that car got totaled I was thinking about getting those again but might swing for the General Altimax this time.
#5080 987687
987687
    Rally Suby!
  • 4,262 posts
  • Northern Maine
Posted 12 January 2013 - 10:32 AM
Winterforces absolutely rule, but it's not snowing very much. I've been fine on my outback running crappy half used all seasons. I live in an area it's not plowed much. A day or two after the storm it's stuck and I drive the lifted GL with winterforces. But after everything is plowed a bit, I'm fine with the outback. Next time it needs tires I'll just do good all seasons, they're fine for a DD if you're in an area that gets plowed out.
#5081 1-3-2-4
1-3-2-4
    Subaru Mike!
  • 3,792 posts
  • Greenwich
Posted 12 January 2013 - 05:09 PM
My job requires me to be to work as long as the highways are open and not shut down, and that means moving out of my spot before the plow truck comes, I had no issues when I had the legacy and winterforce in 10" and it wassnt a outback.
#5082 Radio Flyer
Radio Flyer
    New User
  • PipPipPip
  • 32 posts
  • Yakima, Washington
Posted 13 January 2013 - 01:15 PM
Base-lined her: Oil + filter, timing belts, tensioners, fixed leaks, new tires, front drive axles, replaced steering bellows, PCV valve, spark plugs, removed and cleaned EGR valve, Reset EGR light on dash. Feels like new. Now for a new radio...this old Hitachi unit is garbage.
#5083 aba4430
aba4430
    Eat, Live, Breath Subaru
  • 360 posts
  • Pace, FL
Posted 13 January 2013 - 05:21 PM
This is on a 08 OBS - Yesterday, changed plugs (NGK Laser Platinum), air filter (Sub OEM), main drive belt (Sub OEM) and AC drive stretch fit belt (Gates Micro-V stretch fit). Today, replaced oil and filter (Castrol Edge and Bosch Distance Plus). Need to do brakes, flush brake fluid, and replace coolant soon. Will swap out cabin air filter tomorrow, and pick up a gallon of Subaru LL (not super blue) coolant for the coolant flush. Car has 49850 miles and chugging along nicely.
Completed coolant flush with Subaru LL coolant. Used 4 gallons of DIW to flush out 4 separate times. Next time will use something like this:
http://www.amazon.co...ds=coolant lift
You get slightly over a gallon out when draining the radiator, but it gets old - adding DIW, getting the engine hot, draining and repeating etc. With the airlift device it would have been much simpler/faster. Also added a bottle of Subaru (Holts) conditioner. It is a brown, rust colored suspension with off white colored flakes. If the Subaru engineers say it is OK, will not argue. Replaced cabin air filter; now to do a brake fluid flush, and possibly replace pads.
#5084 newsoobdude
newsoobdude
    Subaru Nut
  • 645 posts
  • helL A/ NorCal Foothills
Posted 13 January 2013 - 06:15 PM
Doing a Weber swap on my 82 BRAT and getting ready to take it for a drive soon. Waiting on the IM gaskets from Subie to show up to I can reinstall the IM after pulling all the extra hard lines off. Then it's time for a frame install if all goes well :headbang:.
#5085 Dj Syco
Dj Syco
    New User
  • PipPipPip
  • 37 posts
  • Snellville, GA
Posted 14 January 2013 - 12:03 AM
Cleaned then Painted my wagon Army Green Chalkboard.
Posted Image
Edited by Dj Syco, 14 January 2013 - 12:11 AM.
#5086 Loyale 2.7 Turbo
Loyale 2.7 Turbo
    The Mighty "BumbleBeast"
  • 7,528 posts
  • Roatán, Honduras.
Posted 14 January 2013 - 12:16 AM
Nice Green Paint! ... There is another Member's Subaru painted in Similar tone Green...
#5087 Cyfun
Cyfun
    Mud Baby
  • 484 posts
  • Billings, MT
Posted 14 January 2013 - 12:31 AM
Posted Image
Omg, is that the paint you can literally write on with chalk? That'd be so cool!
#5088 Dj Syco
Dj Syco
    New User
  • PipPipPip
  • 37 posts
  • Snellville, GA
Posted 14 January 2013 - 12:35 AM
yupp. They used to only have black, but I really wanted to do army green. So my friend showed me that they did different colors. Total cost of the tape, rollers, paint, and paint mix was 31 bucks. Going to buy a pack of chalk and hang it from the front or rear tow hook and let people have fun at meets and such.
#5089 rpholz
rpholz
    Subaru Fanatic!
  • 641 posts
  • Concord, NC
Posted 15 January 2013 - 07:08 PM
Awesome! Curious to see how it holds up.
#5090 mrcpelayo
mrcpelayo
    New User
  • Pip
  • 2 posts
  • Hayward, CA
Posted 16 January 2013 - 01:08 PM
rebuilt my hitachi 2brl carb, DCJ 306, on my 74' DL. still running a little sluggish, gonna replace the spark plugs and see if that does anything with the way it sluggishly gives power at the beginning of any throttle demand. or should i just take it to a carb. guy and have them tune it right? lol anybody know where i can get a driver side inside door handle for my subi?
#5091 Haight
Haight
    USMB Regular
  • 281 posts
  • Seaside, OR
Posted 16 January 2013 - 03:44 PM
Pick n pull
#5092 theredteg
theredteg
    It's All We'll Drive!
  • Pip
  • 3 posts
  • Denver, CO
Posted 16 January 2013 - 06:48 PM
Just fabbed up a turbo scoop on our 85 Turbo Brat. Scored a turbo hood from a 92 legacy from a junk yard and retro fitted it to our 1985 Brat. Next project is to put the intercooler in...
Posted Image
this is how we found her in a field in Fort Collins, CO
Posted Image
the start of the scoop build
Posted Image
Posted Image
in the paint booth
Posted Image
primer, ready to paint
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Final product with the scoop completed.
1985 Brat D/R 4 Speed with an 83-84 1.8 Turbo motor swap A.K.A The Panda
Just for fun -
Cheers!
#5093 l75eya
l75eya
  • 2,371 posts
  • Hoboken, NJ
Posted 16 January 2013 - 08:14 PM
That looks fantastic! Wonderful work. I gotta learn how to weld!
Also the video, chirped 2nd! hahaha :headbang:
#5094 Stubies Subie
Stubies Subie
    Subaru Fanatic!
  • 408 posts
  • Colton, Oregon
Posted 16 January 2013 - 08:32 PM
Got hubcaps for the legacy today, thanks GD and Ed, now we got some covers for them steelies we got on the car
#5095 indigowarpz
indigowarpz
    New User
  • PipPip
  • 16 posts
  • Eugene, Oregon
Posted 18 January 2013 - 04:44 PM
tinted my windows yesterday. i mean.. paid to have them tinted as i know hardly anything about diy tinting. have to wait to roll my windows down :banghead:
#5096 91_EJ_22
91_EJ_22
    New User
  • PipPipPip
  • 76 posts
  • lakewood, wa
Posted 19 January 2013 - 04:43 PM
So last night did my oil Chang. My hood pins my fuel filter and my new thrush muffler and it sounds great
#5097 Subruise
Subruise
    Official Party Pooper
  • 1,568 posts
  • pierce county
Posted 19 January 2013 - 06:17 PM
i recently picked up a set of i pikes for my lifted loyale. i miss my winterforces, and the werent even studded. i just got a screamin deal on my new tires, old fronts were smoked. kinda had to/
#5098 1-3-2-4
1-3-2-4
    Subaru Mike!
  • 3,792 posts
  • Greenwich
Posted 20 January 2013 - 06:23 AM
I miss mine too since they had about 100% thread left when my car got totaled :mad: but oh well.. I decided to go with the general altramax winter tires this time since everyone says they are a little bit better unstudded then the winterforce..
I will soon find out.
#5099 TomRhere
TomRhere
    Certified BRAT nut!!!
  • 4,600 posts
  • Hillsdale, Mi. USA
Posted 20 January 2013 - 07:12 AM
Attempted to repair the clock in the '88 Wagon. No joy, burnt resistor. Pulled clock from the '92 Wagon's dash, same resistor was burnt. Bummer.
When I dropped the glovebox down on the '88 to get to the connector for the clock, I found a receipt for payment of repairs. It was laying on top of the A/C housing.
No mention of work done, but total was $549.20, paid to Luttrell's Auto Center in Walla Walla, Wa., paid on 12/14/06.
Thought that was pretty cool.
#5100 1982gl4
1982gl4
    1000+ Super USER!
  • 1,468 posts
  • Worcester, VT
Posted 20 January 2013 - 08:50 PM
Painted the front of the hood on my outback because of a bug deflector that has been long gone, I also repaired the rear quarter that had started to rust. Almost ready to sell it so I can get back to some of my other projects.
