Everything posted by mattocs
Thanks for the info, guys. I didn't see that kit with the Aisin water pump when I was looking. I'll probably end up ordering that one. I'm going to order my own seal puller and gear puller. It'd be about $30 for both, and i'll use them again, so they will be nice to have. I was going to buy the three pack of pullers from Harbor Freight, but I might just order a single 4" or 6" puller that is of decent quality and a real brand for $15 or so. I've used a screw driver and mallet to get sprockets off shafts at work in the past...but I had always had more room to work with. Hrrrm. I didn't think about pushing the seal in to far. Now i'm concerned about that. Maybe i'll take a toothpick or something and try and measure the depth of the old seal before I remove it. Now I need to order my kit and pullers, and wait for a Sunday that my cousin is available to give me a hand and that the weather will cooperate. Thanks again!
I recently purchaced a 1995 Legacy L (159k, EJ22, auto). I planned on doing the timing belt, water pump, seals, etc. sometime in the next few months. A water pump leak that came about last week has moved those repairs to sometime in the next few weeks. I'm comfortable with setting the belt, installing the water pump, and doing the idlers and etc, but my concern are the cam and crank seals. I was going to purchace this to get the seals out: http://www.amazon.com/Lisle-58430-Shaft-Type-Puller/dp/B000FPYW4K Anyone have a suggestion on a better seal puller? Also, any recomendations on which size gear puller to get to remove the pulley? Is it easy enough to do without a gear puller? And last, any tips on getting the seals in? What about finding a piece of tube or pipe that is the same size as the seals to push them in evenly with? Is there an easier way? I am probably going to go with the timing kit from Mizumo: http://www.ebay.com/itm/90-97-EJ18-EJ22-Subaru-Impreza-Legacy-1-8L-2-2-GMB-Water-Pump-Timing-Belt-Kit-/260925954274 It comes with the seals. I know if they are not the brown OEM type to get rid of them and go to the dealer for the good ones. I'm still not set on that kit. I might go with the similar one from the Import Experts, also on eBay. Thanks!
well....
mattocs replied to 95legwagon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Hole or bad seal? Scrub it, degrease it, and JB Weld it? Good luck! -
I picked up a 95 Legacy this past weekend that had some TB. I drain/filled three times with Valvoline MaxLife ATF and the problem went away. It got better and better each time I drained and filled it. I will probably do a drain and fill every oil change to keep the fluid fresh. Do a search for Duty C solenoid. Parts will run you $100 or so, and shouldn't take more than a few hours to do, and the transmission does not need to come out of the car. I've never done it, but I've been reading on it the last few days.. Seems pretty easy. Good luck.
