Everything posted by john in KY
XT6 Transmision onto 3.0R engine
Requires an adapter.
what makes a ea82t engine die?
I put 100K on a turbo wagon running 12 pounds of boost along with other modifications. Never had a problem with it. When I sold it the young man that bought it managed to destroy the front differential.
93 TURBO WAGON RADIO POWER QUESTION
john in KY replied to Subi81's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOne wire will always be hot as it is the "memory" wire otherwise you would lose all the presets everytime the car is shut off.
1992 Subaru legacy starter problems
john in KY replied to Blueashtaylor's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy guess is adding a starter relay will solve the problem. Plenty of how to do on the net.
Master cylinder bingo
oops.
Yes, the turbo models. The XT and XT6 models used the same stuff.
Anybody run cylinder walls like these on an ea81?
Recently saw 40 over pistons on eBay.
Just a guess but the different diameters may have to do with rather disc brakes all 4 wheels or just in the front.
EA82T XT 4SPD auto.
I have never seen a part time AWD 4EAT. My 85 XT had the 3-speed.
Brat sat for four years :(
Same thing happened to me. In my case it was a 225 Mopar that had sat for 20 years.
91 Legacy LSI 4EAT question
john in KY replied to SUBARU3's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck the linkage under the car. Have someone move the shifter and verify that whatever thing the rod connects to moves through its range. That whatever fan-shaped thing may have failed and check its wiring harness. I have a FWD 4EAT from a 94 model with 84K miles that has been sitting in a shed the last 20 or so years. PM me if you should become interested in it.
Advice on 1988 XT-6 Automatic, sitting 18y in garage.
I just happen to still have the ignition switch with key for this.
Cranks and wont start
The coil bracket has to be grounded. Make sure the bolts holding it to the body are tight. Also insure the wiring harness for that little transistor whatever riveted to the coil bracket is plugged in.
Pull a spark plug and test for spark. Just ground the body of the plug. May have a weak coil.
Is this EA82T head junk?
Can always be welded.
fireworks display on the dash - tranny troubles?
john in KY replied to abstoler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy guess is a low voltage condition.
1991 Subaru Legacy AT Possible Torque Bind
john in KY replied to Brooklin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't think, based on what you have stated, that the transmission is the problem. Rotate the tires front to back and note if anything changes. Any idea how old the tires are?
First road trip in my 2004 Forester XS
john in KY replied to log's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck coolant level and go for it. Do't over think this.
- Car wont start after intake gasket job/fuel lines
Wont start
As far as I know, this model does not use an ECU. If the no-start condition appeared immediately after changing the plug wires, I would double check you got the firing order correct. How in the world did you note the coil was wired backward? The coil may have a short. Replace it with a known good one.
No power to my ignition coil
- No power to my ignition coil
Why was the distributor replaced? Have you checked the positive side of the coil for voltage? "And the coil to starter is good." Makes no sense to me. The coil and starter are stand alone parts.- 05 LL Bean Outback - Not charging
john in KY replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBatery/altertnator outputs easy to test. I'm thinking maybe the problem is the alternator is not being spun fast enough.- (UPDATED pics and vid) Help! Newbie with 1994 EJ22 in van. Won't start. Skipped a tooth??
john in KY replied to SubVAN's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOther thought: AFM. - No power to my ignition coil
