john in KY
7
Everything posted by john in KY
Subaru 360 Starts, Runs then Dies
john in KY replied to brus brother's topic in Historic Subaru Forum: 50's thru 70's
Don't know how the oil and gasoline is mixed on this engine but almost sounds like lack of cylinder lubrication is the problem. -
I've had axles that absolutely would not move in the hub until that beveled washer directly behind the axle nut was first removed. Once the washer was removed the axle most of the time just moved freely. Go figure.
Gettin' back into it- EA82T 4EAT
john in KY replied to 4x4_Welder's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If you know or it looks like either the engine or transmission has been replaced then the internal transmission pump has most likely been damaged and the transmission is junk. Easy test is to pull one of the ATF cooler lines and crank the engine. No ATF then it is the pump. Linkage is no more then a cable. Don't toss the transmission Xmember because it is unique to the 4EAT. Real good chance this also has the LSD in the rear. Once owned a 90 turbo wagon with the 4EAT. Nice combination. -
Just reuse the XT6 strut. The XT6 knuckle, where the strut mounts to, is actually thicker by about an 1/8" than the Legacy k nuckle. If you enlarge the top mounting hole you can even use the Legacy camber bolt.
E-brake may just need adjusted which can be done by turning a nut under the transmission hump. Also have some front rotors and calipers I saved from an XT if you want to go use. PM if interested. Also a bad MC can cause this problem. Heated fluid which expands can not return to the MC so it goes the other way and pushes against the caliper piston. More heat, more "push" and eventually the front brakes losk.
Something not right here. No 85 XT came with the 4-speed auto.
Fuel pressure regulator ruptured. Pull the vacuum line, looking for gasoline. Fuel injector stuck wide open. My money on the FPR.
1988 GL wagon rust issues
john in KY replied to glh1975's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Can't be repaired. The suspension mounting surfaces have rusted away. -
Drain the gasoline and change the fuel filters before doing much of anything else.
Sube nearly dead, please help :(
john in KY replied to nickbalcombe99's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Blown fuse? -
My Coupe Made the Rock Auto Newsletter.
john in KY replied to Bucky92's topic in Old Gen.: 80's GL/DL/XT/Loyales...
http://www.pullapart.com/Inventory/SearchDetail.aspx -
Wonder if there is some way the ignition timing could be moving around on you?
HELP! No Spark..new coil as well!
john in KY replied to Deener's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Can't just look at the fusible links and determine they are good to go. Remove them and give each a good tug. More then once I have seen them fall apart with a tug. -
Probably not your problem but the coil bracket has to well grounded. That "condensor" receives a small voltage from the ECU and ramps it up enough to fire the coil. May as well check the fusable links and look at the back of the ign switch. -
94 loyalle motor in an 1992 SUBARU SVX AWD????
john in KY replied to A6D9's topic in Subaru Transplants
It won't. Actually ER33 engines aren't that expensive. Just not a demand for them.
