Everything posted by chef_tim
some questins..oil pressure
chef_tim replied to PeterD's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hey Peter, my hatch back does the same thing (it's a CCR motor). I replaced the sender and it read the same. I'd suggest saving the $40 . It worries me because alot of the EA81 cars I've had read almost to the red line and then drop abit from there when warmed up. Sorry I don't have an answer, just wanted you to know your not alone. Tim -
Thank You!!!!
And he speaks "King James"...... I love the kid!!!!
Insta-tapping for 92 Loyale
chef_tim replied to amartin's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Marvel Mystery Oil is the way to go. That stuff is amazing!!! Tim -
Open drivers door, look for small plaque. It should have the manufacture date stamped on it. Tim
Hey Mick, we looked at our situation and I don't think this year is going to work. We are going to start planning now for next year so we can do both MW4 and the Castana run. Sorry man, hurts me more then you though. Have a good time and post lots of pictures. Tim
Gentlemen, we have a WINNER!!!!! I would have never seen that as it was. I'm still trying to plug it in (8 stitches across the back of my thumb don't help....lol) So, just for my own knowledge, what does "IAC" stand for, I'm assuming it is the fat hose that goes straight up and down. Thank you, thank you, thank you:D . Tim
Sorry, 97 OBW build date is Jan 97. I just got off the phone with the service tech and they said there is a second sensor. Black with yellow strip and black wire. It should be toward the front of the engine, but I'm not seeing it. I'm starting to think I may have to take the intake back off and look under it:banghead: . Keep the ideas coming, I'm going back out to look some more. Tim
The adventure begins again. I read up on the multi-meter then I tested some "stuff" ie fuses, an exstention cord, a relay. Then I got an old OP sensor with only a single blade conection, I couldn't figure out where to put the meter leads. Going back to the temp sensor, should I put one lead in the conector and the other on the sensor, in effect, making a bridge??? Sorry, got an idea and walked away for a sec. My hatch has the same type of conector and it is very accesable. I figured out I don't put it into the power lead, but I put one lead on the sensor and grounded the other one and as the car warmed up, the ohms went down, I ended up with a 4 ohm reading (.4x10). So, with that said I think I'll go check the sensor in the OB, it isn't nearly as accesable:-\ . Really kind of fun learning this stuff:grin: . Tim
Thanks Glen, unfortunatly I have no idea how to measure the resistance or for that matter any thing else you recomemded:confused: . It is true, when it comes to electronics I am a complete idiot. I have a multi-meter but about all I know how to do with it is see if the alt is charging. Could you give me some details, and I'll give it a try. I'm not sure if it matters, but the guage works the same as it did before the motor came out. Thanks, Tim
For about $200 a LUK clutch will get you a lot of clutch. I might also advise not speed shifting with 28's. You might as well just slip your clutch back and forth :-p . Tim
Hi all, got the CCR long block and it runs great. I only have one small issue. When I put the motor in the only thing I didn't hook up was the temp sensor. The cooling fans come on at start-up and it is running very rich (apx 13mpg w/the trailer) I plugged in the sensor and had Auto Zone clear the computer, code 117 "low voltage to temp sensor". the fans went off, but about 30 seconds later the fans came on and so did the CEL. I am assuming that it is the same sensor. Is there a trick to getting it to stay off??? Thanks for the help, Tim
Pug Wheels...and lug nuts
chef_tim replied to Do It Sidewayz's topic in Old Gen.: 80's GL/DL/XT/Loyales...
http://www.ultimatesubaru.org/forum/showthread.php?t=31201&highlight=doorman That's what I've done on two of mine. Never had a problem. Tim -
We're thinking of going to this. We really need to see what's up that weekend. I think it would be blast and with the OBW/pop-up, we could camp and be sure to have a car to get home in . (still alittle gun shy with the Loess Hills:-p ) Later, Tim
found an easy exhaust manifold bolt fix
chef_tim replied to dragonwingsubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I do the same thing but with 3/8 exhaust studs. Works great
