Everything posted by subiemech85
check your choke or cold enrich system
So many fuel lines. Why?
subiemech85 replied to subystomper's topic in Old Gen.: 80's GL/DL/XT/Loyales...
you are referring to the vapor separator under the hood wix 33201 the wix is crystal clear http://www.wixfilters.com/filterlookup/PartDetail.asp?Part=33201 top line from carb vapor return one line from "tank" supply in one line to "carb" out the fuel pump mounted by the rear crossmember is not an issue, fairly protected there should be a filter before the pump I like to install a clear filter about 1' before the carb, current one happens to be mr. gasket 9747 http://www.mr-gasket.com/ProductDetails.aspx?MajID=220&MinID=2204&productID=327&txtSearch=9747 it has saved me atleast once, due to cruddy tank, remove and shake to clean -
they are nice when well cared for usually the ea82t goes bad due to operator error swap in a manual tras or 4eat if you go for the manual trans swap, you will also need the matching front drive shaft, as there is 120mm difference in length please post more pics of the digidash I have a nice '86 gl10 crust brown 5spd 4wd, with digidash I had to swap in a ea81 to replace the ea82t the previous owner left water in the block and froze
my wife drove my wagon and........ snap
subiemech85 replied to thermalsurfing1's topic in Old Gen.: 80's GL/DL/XT/Loyales...
there is NO FRAME, just BODY, unless you add subframe have a good look later when it's warmer and brighter, and take pictures -
you could be starvig for fuel tank pickup and fuel pump inlet strainer could be plugged BTDT ATTN: DUDE my ea81 has more power than the clutch can handle
Block heater/tank heater/radiator hose heater?
subiemech85 replied to opus's topic in Old Gen.: 80's GL/DL/XT/Loyales...
yes ok be sure to use a t-stat with a juggle pin STANT SUPERSTAT works great best way to drian block is to remove drain plug in head, 14mm socket -
Cold snap = Massive amounts of water in the Oilpan!
subiemech85 replied to pwjm's topic in Old Gen.: 80's GL/DL/XT/Loyales...
does this mean you have LSD??? -
harbor freight has a metric set includes 14 and 17 http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=98229 cornwell recommended as it was the shortest due to limited access Mac is a nice medium length bit -
bad alt can make tachometer go :banana:s
http://www.ultimatesubaru.org/forum/showthread.php?t=27068&highlight=block+heater or SEARCH for subiemech85 block heater -
I'll check what is in stock, fairly sure it's luk, but not sure which one is which now have been out shopping all day :-\ you could call me AFTER 12pm, as I need to catch up on zzzzzz
not suggesting you stole from it, but that it looks alot the same I am considering converting one to 4wd using toy rear axle and subaru ea81 engine with ea82 trans vwcaddy http://www.4crawler.com/VWpickup.shtml someone has swapped a subaru engine in already, which made me start to wonder
86 subaru wagon gone crazy
subiemech85 replied to brubru24's topic in Old Gen.: 80's GL/DL/XT/Loyales...
fuse link fuses alt. -
removing slight surface rust from cylinder walls?
subiemech85 replied to mcbrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
CRC 5-56 and a finger keep the jar of beans sealed to prevent sprouting -
2 row radiator adventure
subiemech85 replied to Frank B's topic in Old Gen.: 80's GL/DL/XT/Loyales...
WRONG and WRONG!!!!! non-turbo MT and 4wd 5-speed 38.495 kw 131,341 BTU/h 590 x 322 x 16 23.23 x 12.68 x 0.63 AT and 4wd dual-range 45.822 kw 156,339 BTU/h 645 x 322 x 16 25.39 x 12.68 x 0.63 TURBO 47.683 KW 162,688 BTU/h 645 x 322 x 16 25.39 x 12.68 x 0.63 according to '85 FSM 2-5 p. 5 pub. G130BEA -
EA82 Cam Case Idea - maybe crazy **UPDATED**
subiemech85 replied to stephenw22's topic in Old Gen.: 80's GL/DL/XT/Loyales...
please update!!!!! -
it's not a freeze plug!!!!! for ea71 and ea81 the plug is on the front of the block to the left of the crankshaft for ea82 the plug is on the bottom of the block below the oil fill tube use a 14mm bit to remove the plug is 36mm thread BTDT on ea71 ea81 ea82 -
My BRAT is stuck in a 5 foot drift
subiemech85 replied to bheinen74's topic in Old Gen.: 80's GL/DL/XT/Loyales...
10 or 12 for locknut 12 or 14 for adjuster visegrips and pliers to avoid twisting cable I have several clutch kits collecting dust -
the one in the link is OVERKILL and has NO PUMP I have yet to find one with a pump 400W block heater works great
