Everything posted by subiemech85
removing ea82T head
after a bit of practice, it's easier than finding a jack
Roll pin breakage Help
according to fsm broken roll pin = 25 spline axle on 23 stub
removing ea82T head
NO!! IT'S NOT NECESSARY have removed and installed while everything is in position, on 2 cars
What Other Cars.....
dcj306 http://www.ultimatesubaru.org/forum/showthread.php?t=36561&highlight=dcj306 approx 73-80 subaru http://www.ultimatesubaru.org/forum/showthread.php?t=93344&highlight=walker
Loyale HVAC Controller Vacuum Woes - Solved!
hate to say it, but told you so
A little help if you could....
MilesFox is basically the know-it-all of the best lego's ever made in japan also refer to subaru drive and endwrench
Fixes and up keep or upgrades?
go to a yard and find SOA mats, you will be glad you did air horn SUPER-LOUD! harbor freight item 40134 should fit behind grill use roof rack cross bar to mount
ea82/ea82t t-belts and seals
yes
considering a `78 wagon
IF it has automatic, it has EA81 IF it has EA81, it has automatic it is either late gen 1 or early gen 2 designating vehicle by engine type is a bad idea, considering an XT aclyone sp?? had EA71 stock in some countries drawbacks are few, mostly just old parts hard to find the wheels will fit
will ea82 dist work in ea81??
will ea82 dist work in ea81?? I have available BOTH '85 carb AND '86 turbo - hot wire ea82 dist available what would need to be swapped? this is for my gl-10 turbo wagon repower with ea81 engine with ea82 carb and intake
Ok So my carb is bad :(
drain coolant remove airbox remove float chamber cover remove brass jets and plugs remove all remaining screws remove carb remove drain plugs, and jets behind the plugs if you turn carb upsidedown, a VERY small ball will fall out, remember where it goes scatter all parts around, find them, and throw them in the rubbish bin, install webber, adapter, and choke
try it and "see" what happens defrost could be heat if you still have issues, I can see how mine is set up later
you can use the "center" screw and clip-nut from the fuse box to replace the crappy one all "visors" I have seen come standard with writing in white ink on the bottom edge, left side, looks to be jap. character I did mine in the well lit and warm garage, 70*f and harbor freight led light the light is super awesome, and works great http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=94668
you did not guide the plastic in the right direction, angle left side down and to the rear did you forget to remove the screws from the controller before removing the "visor"?? no need to remove the screws to hold in the fan switch, all connections can be disconnected easily when moving the visor, you flipped the "virgin" switch you should have seen 4 hoses marked 1 2 4, 3 is not labeled, think son of 666 in japanese mythology
head removal
use PLASTIC splitting wedges for trees AFTER REMOVING all offending fasteners
ThreeBond Super 1215 replacedment 3M 08672 UltraPro
ThreeBond Super 1215 replacement 3M 08672 UltraPro 3M 08670 T-3 replaced by 3M 08672 UltraPro http://solutions.3m.com/wps/portal/3M/en_US/3MAutomotive/Aftermarket/Products/Product-Catalog/?PC_7_RJH9U5230GE3E02LECFTDQCEK3_nid=GS5BZV8F3GgsQ5D2V4SCM0glGSPPD8819Qbl also available at NAPA :banana: :banana:
Differential
or it could be another black sheep, similar as used in ea71 powered gen2 wagon, built 11/79 approx. will check spec. book and car on friday.
convert 5spd d/r 3.9 to 3.7 ??
and now I'm considering the posibility of converting 3.9 d/r to 3.7 d/r with front lsd as a bonus I really want the LOW 1.59 is is possible, and what parts are required from what donor?
feel free to call me then as I can walk you through every inch of the system
Denver mad scientists - transmission lab: Lab ingredients/forumula FOUND!
not that noone wants to buy it, but the shipping would probably be too expensive to send my way and now I'm considering the posibility of converting 3.9 d/r to 3.7 d/r with front lsd
in picture 2 you should have the junction block as I described, but you only have the rubber tubes that lead to the servos A/C/Fresh Air is manually controlled by a lever to the left of the steering wheel, also by a thumb wheel for the right side vent we are not talking about the same system, the servo controlls recirc for max ac when ac button is pushed in all the way your system does not match because parts are missing did you remove the dash panel? what did you find??? the resin tubes go from controller to junction block if you want, call me and I can walk you through it! 515 577 5120
1978 Brat! Help
and when you're done with the reliable ea71, send it to me I'll check the engine spec book friday when I get back to my weekend home
New here...
the boomerang is back http://www.ultimatesubaru.org/forum/showthread.php?t=72520&highlight=boomerang http://www.ultimatesubaru.org/forum/showthread.php?t=47780&highlight=boomerang McBrat keeps sending it out just search for boomerang or mountain grizzly
which tire will do me better in snow
norwegian vikings
heat / A/C out of the main dash vents is the "default" mode you need black "resin" plastic spaghetti straws to join the rubber tubes in the second pic at the junction block remove the dashboard trim, screws behind defrost, off on the right side, top and bottom corners, also for the left side, 2 screws under visor, and 2 screws under bottom edge be careful as all is fragile first one I had was rigged so it had constant defrost read here for more info: http://www.ultimatesubaru.org/forum/showthread.php?t=6915&highlight=constant+sucking
