Everything posted by subiemech85
BTFT: disconnected the wire for the brake fluid level sensor
wesley willis " as does my hatch. it's quite useless, unless you want your rear window wiped, of course. " what else would it do, slice cheese? "nope, the only Soobies with rear wipers were most of the wagons (all EA82 wagons) and the EA82 coupes" didn't the dl skip this option? 4-door sedan has rear wiper, '85 fsm book 2, section 6-2 p. 49-50 adjustment, etc :-p
why can't i find my radiator ground wire?
subiemech85 replied to skinnyhb's topic in Old Gen.: 80's GL/DL/XT/Loyales...
ea81 series has a radiator ground wire from radiator to radiator support ea82 series does not have a radiator ground, but it is good to run one from thermostat housing to back side of radiator look for a hidden locking clip -
ea81... HELP GRRRRRRRRRR
subiemech85 replied to scrap487's topic in Old Gen.: 80's GL/DL/XT/Loyales...
coil already listed in origional post -
BTDT: fix = swap distributor -
"any info would help" back at you! front crank seal?
EA82 Radio Questions
subiemech85 replied to SyntheticBlinkerFluid's topic in Old Gen.: 80's GL/DL/XT/Loyales...
clarion no idea remove plastic side panels -
http://www.aviajournal.interami.com/sections/journal/arh/magazine/20012eng/st3.shtml worth a read, based in russia
Haynes and Chilton's for Loyale
subiemech85 replied to bgd73's topic in Old Gen.: 80's GL/DL/XT/Loyales...
they both SUCK! ONLY WAY TO GO IS D-CHECK REFERENCE BOOKLETS I have complete set from 1983-1990 -
after fixing the exhaust leaks, I decided to take it out to see what it can do max speed 90 @4.5k '89 rx ft4wd d/r dif unlocked high range no wind ambient temp 45* unifilter intake 89 octane 10% ethanol otherwise stock shouldn't it go faster??? my '81 vw rabbit pickup diesel with ?50 hp goes 90, speedometer stops at 85
New stainless turbo header
subiemech85 replied to BoostedBalls's topic in Old Gen.: 80's GL/DL/XT/Loyales...
easy way to remove crossover pipe is to hammer in the mounting tabs, raise front of car, remove whatever is still holding, let left side fall down, rotate, twist, slide, duck mine fell off one time for me -
headgasket diffrences
subiemech85 replied to erik litchy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
stone -
No Accel Coils, No schucks
subiemech85 replied to djbroadus's topic in Old Gen.: 80's GL/DL/XT/Loyales...
mine is on it's third vehicle I must have gotten lucky, 8140c, had it about 3 years '85 wagon '84 brat '89 rx -
EA71 Intake manifolds
subiemech85 replied to mcbrat's topic in Historic Subaru Forum: 50's thru 70's
so: what are the results ?? I have ideas clouding my mind -
does this involve a bellhousing from a d/r brat with fat case ea71? I'm interested in recipe NOW!
do the "wd40 test" spray some wd40 onto a white paper towel, high quality like "rags in a box" then rub the paint and see if it shines up works like a charm!
this time with INDUSTRIAL ENAMEL the rust keeps spreading, stripes were rust-oleum, paint looks kinda crappy, cracking will probably keep the color scheme with gloss white body, aluminum for the gray bits, and MF red for the stripes, and a gloss black hood current paint http://www.ultimatesubaru.org/forum/showthread.php?t=44427 paint supplier http://vansicklepaint.com/mntvsinden.html about $20 a gallon at the farm store any idea how much paint would be needed? coverage is approximately 400-450 sq. ft. per gallon
looks like someone overdid it with the black I say it needs some stripes and lettering as I am looking at the VanSickle color palate for industrial enamel
What would you pay for this?
subiemech85 replied to Subieguy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I bought my '85 wagon with h alloys for $50, similar condition http://www.cardomain.com/ride/471729/1 -
the scoop http://www.ultimatesubaru.org/forum/showthread.php?t=33749
hood came from SOA, still has part # tag no clue where the cf scoop came from, but it works it's a cf scoop, you nit wit and the rx is mine, happily leaking oil, coolant, exhaust, hibernating until the snow
Historic Subaru Forum (3 Viewing) Any topic discussing Subaru models older than 1979 (1981 for Brat), or vehicle restoration techiques for any model or year Subaru. Older Generation of Subarus (16 Viewing) If your Subaru was built after 1980 but before 1990 or is a Loyale, Justy, XT or XT6 please post here. since the build is 11/79 doesn't it belong in old gen? it's an ea71 maybe there should be a category of TRANSITIONAL eras :-p
is the filter in the secondary air cleaner replacable?
