Everything posted by subiemech85
If I put in Dual range Do I change Rear Diff?
subiemech85 replied to Suzrub's topic in Old Gen.: 80's GL/DL/XT/Loyales...
it's a matter of matching numbers "normal" lsd is 3.7 if you have 3.9 trans, there are some 3.9 lsd available, or you could convert one yourself -
it's more like the little red wagon became tw5.5, runs in the family
Front calipers banging around
subiemech85 replied to Flyscooby2's topic in Old Gen.: 80's GL/DL/XT/Loyales...
missing bolt holding the caliper mounting bracket, BTDT on the REAR!! -
cool! is that the one I saw in progress at open pantry with bex?
Anyone ever replaced their key's battery??
subiemech85 replied to Numbchux's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the junk yard -
New toy, '89 RX(pics)
subiemech85 replied to Free Range's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I WANT YOUR BODY!! Free Range" Eh its just a toy, when it breaks it will get parted, unless somebody really wants it sans diff and trans..." shall we make a deal? /begin hijack/ when the ambient temp was +4f, the "heater" sent out +4f air good thing I had my harbor freight 12v "heater" to warm one had at a time this was the last chance, from now on it's my '81 diesel wabbit pickup /end hijack/ -
I replaced the key in it pulled it from a xt6 for the rx -
What's this for and why's it leaking fuel?!? pics
subiemech85 replied to 211's topic in Old Gen.: 80's GL/DL/XT/Loyales...
here's another time when the SEARCH function is your friend http://www.ultimatesubaru.org/forum/showthread.php?t=18903 -
Amber Door Lock Light?????
subiemech85 replied to N8NQU's topic in Old Gen.: 80's GL/DL/XT/Loyales...
"can somebody tell me how to turn it off?????? " lock the doors, crawl out the windows :-p -
Vortex XT window washers.....
subiemech85 replied to waimaks's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the hose goes from the tank to the windscreen sprayers the sprayers may be installed on top of the bonnet or on the plastic tray, or both! -
'89 rx should be 5spd d/r ft4wd 3.7 could be auto how's the body, rust?? does it have HEAT???? -
Anyone suxxessfully installeda mechanical..
subiemech85 replied to Mykeys Toy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
how many times do we have to say SEARCH http://www.ultimatesubaru.org/forum/showthread.php?t=12912 1/8-28 bspt for ea82 1/8-27 npt for ea81 -
MUST SEE RARE JUSTY CLUTCH lol
subiemech85 replied to JustyPimp's topic in Old Gen.: 80's GL/DL/XT/Loyales...
and I want a clutch that won't burn up at the next mud fest! :-p -
The best 50 cents I've spent.
subiemech85 replied to fj401968's topic in Old Gen.: 80's GL/DL/XT/Loyales...
then buy it back a year later for more than you sold it for -
I pulled this one out of a '86 mitsubishi "dodge raider" it has oil pressuer in bar and psi, goes to 8 / 110 and a volt gauge 8-16 much more suited for my vw rabbit pickup I'll have to put the tercel one in my rx I've taken in on easy trails
dad keeps saying you're going to blow the engine if you keep driving it like that I keep thinking I'm not running enough boost to do that brian, what was the final verdict on yours?
it's all about the DEER I don't look for them, I look for their eye reflection I put in the silverstars and run with 3 lights may have to add a passing lamp
Stubborn oil pan gaskets!!
subiemech85 replied to TheSubaruJunkie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
FIRE! will either burn off the gasket, or soften it so it can be scraped off -
where exactly is the leak? if it is the tank leaking because of a crack, the tank can be easily replaced it should be about 1hr labor, new tanks can be bought from northern radiator supply in MN if nothing is broken, you can try to re-crimp, large straight jaw vise-grips work well the gasket may also be bad check the drain plug
ea81 name that part, oil control device
subiemech85 replied to subiemech85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
turns out it is a "single roll" frantz oil cleaner sure is hard to cut ss braided core hydraulic line with wire cutters -
Recall on Fuel Filters (Wix,Napa,Carquest)
subiemech85 replied to SubaRube's topic in Old Gen.: 80's GL/DL/XT/Loyales...
to prime the system the easy way, connect the green connectors to make the fuel pump cycle -
Offroad Bumper Group Buy AA
subiemech85 replied to Shadyirishmen's topic in Products for your Subaru
interested if it has front and rear 2" reciever hitch -
I second that opinion unless it's a diesel
purolator is not affected, they're all I ever use -
how would I go about putting in an inline thermostat? I am thinking put together 2 housings with a thermostat in the middle why? because the ### doesn't have a thermostat, the housing is held together with silicone and a hoseclamp
