Everything posted by subiemech85
not this time I had a nice crack under the seal area , the together part was no larger than a small screwdriver, luckily it didn't blow out no more dribble
please help me with my cv joint
subiemech85 replied to seth3030's topic in Old Gen.: 80's GL/DL/XT/Loyales...
to remove a rear axle, first remove the roll spring pins, using a 3/16 ROLL PIN punch, one for each end then disconnect the dif side, then disconnect the wheel side -
brakes, front and rear done by subiemech85 also assisted in installation of points and condenser eyesore, empty your pm box, or become a usmb donor, $3 well spent!
that's what the 3x expanding foam and filler metal is for the old thermostat was 160* torxxx, did you drill a vent hole? still not as warm as it should be, but the book spec 140* cooler than coolant doesn't mean crap
change thermostat to 195* install coolant heater the radiator drian cock was broke, amazingly it held test drive 120* air out ac vent temp guage stayed at 1/2 the old thermostat is good, so is the new one, I boiled them the air sitll seems too cool will others please report the temps?? that would be helpful
custom aftermarket loyale mirrors???
subiemech85 replied to SkankinPickle's topic in Old Gen.: 80's GL/DL/XT/Loyales...
looks too rounded -
fan comes on, that system is on spec coolant maintains level, jsut below the level plate only about 1/4 of the rad has custom air flow controller
CV axle grease leak question
subiemech85 replied to pmichaud's topic in Old Gen.: 80's GL/DL/XT/Loyales...
that's why there is a '"LIFETIME WARRANTY" -
that is one of the links I posted, motormite, found in parts stores "HELP" section
it being a brat with no ac, the recirc puts the air where I need it, helps to keep the windows clear too the 195 thermostat, gasket, coolant heater and drain plug are on the list napa had a special, buy a thermostat, get a free thermostat gasket would the 180 thermostat be causing the trouble it seems to warm up just fine but when I go down the road, it drops
what is the temp of the "heat" that comes out of the ac vents? what is the temp guage at? mine is 100* at 1/4 bur!
how much camo $ why do I only see wheels and glass?
yes, my cock dribbles :-p
*/- time for a trans swap the ea81 4 d/r sucks the ea82 85 d/r is so much nicer
Wherring noise from wheel
subiemech85 replied to subestyle18's topic in Old Gen.: 80's GL/DL/XT/Loyales...
it may be a rear axle sounds like grinding all the time when moving if you have to clutch to shift into 4x and the noise disappears, it's an axle in the rear, btdt -
How rare was a "awd" ea82t wagon
subiemech85 replied to pwoens's topic in Old Gen.: 80's GL/DL/XT/Loyales...
when worrying about rust, use the rule of fist if your fist will fit, fix if your head will fit, fix first -
to much gear oil ....?
subiemech85 replied to moshem74's topic in Old Gen.: 80's GL/DL/XT/Loyales...
there are two dipsticks for the autobox one has gear oil with a distinct odor this one is for gear oil the other is for the transmission fluid it is supposed to be red, and have no offending odor it may help if you drill a small hole for both the hi and lo marks for each dipstick the engine oil dipstick has holes for easy checking of the level -
yes, sending luck and you already have the base color a hatch does suit you going for 5spd d/r? viscous or clutch pack lsd?
Front/rear main seals
subiemech85 replied to Mendodave's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the nice thing about the ea81 pulley is it pops off after the bolt is removed very common problem and simple fix mine left a line on the top of the oil filter, not anymore! -
a bolt won't work it's tapered and designed to seal properly without additional sealer http://www.motormitedormancatalog.com/item.wws?sku=61114&mfr=MOTORMITE&cookieID=1E31DBFG61E31DBLRL&clientid=motormitedorman&clientid=motormitedorman or http://www.motormitedormancatalog.com/item.wws?sku=61116&mfr=MOTORMITE&cookieID=1E31DBFG61E31DBLRL&clientid=motormitedorman&clientid=motormitedorman or http://www.motormitedormancatalog.com/item.wws?sku=61118&mfr=MOTORMITE&cookieID=1E31DBFG61E31DBLRL&clientid=motormitedorman&clientid=motormitedorman or http://www.motormitedormancatalog.com/item.wws?sku=61123&mfr=MOTORMITE&cookieID=1E31DBFG61E31DBLRL&clientid=motormitedorman&clientid=motormitedorman or http://www.motormitedormancatalog.com/item.wws?sku=61141&mfr=MOTORMITE&cookieID=1E31DBFG61E31DBLRL&clientid=motormitedorman&clientid=motormitedorman now all you need to do is find a place that has one, oriellyauto.com good luck!
Need addresses for wedding invites
subiemech85 replied to Flowmastered87GL's topic in Meet n' Greet. Your USMB Welcome Center
saturday most computers have a calendar :-p -
minnesotas got subarus!
subiemech85 replied to archemitis's topic in Old Gen.: 80's GL/DL/XT/Loyales...
1. stock y-pipe 2" all the way back to a glasspack in the stock location followed by a 2" tailpipe sound and performance is good 2. check fuse and grounds 3. buy a pcv valve from subaru, the others are junk -
troubleshooting alternator
subiemech85 replied to jwikan's topic in Old Gen.: 80's GL/DL/XT/Loyales...
you have two separate problems 1. the volt guage going up and down is "normal" there is an insufficient wire that feeds the ignition circuit that goes bad over time 2. have the alternator tested if you acquire a replacement alternator, have it tested, even if it is new or rebuilt -
just put the grey heads on the blue engine save the blue make grey the donor is the lsd viscous?
HELP section of auto parts strore, or radiator shop unscrew to drain and remove it is definately threaded drian cock replace to cure the leak it is supposed to have a tab to hold as you screw the thermoswitch is for the fan ground to turn on
