subiemech85
Everything posted by subiemech85
  1. nice what's the wing from? / mounting? I started arc welding today, just making beads and starting arcs, will also learn gas and mig shortly
  2. I'm planning on a campsite for fri and sat nite, prefer to sleep in wagon due to tent could fit in wagon when assembled!!, and I'll go for a shower 10th or 17th does not matter to me "rabbit season: duck season" repeat as necessary
  3. it goes nowhere, except your bucket of parts, remove it the drain is a hole in the front of the air box which pic could you not open? iirc, you can remove the componets marked with red
  4. trashwagon 7 read about it here: http://www.ultimatesubaru.org/forum/showthread.php?t=12732&highlight=trashwagon it's for real
  5. you could disconnect the line how you would do a a bleeder valve IIRC drum brakes $10 for the hydraulic part
  6. topics include amc eagle, propane conversion, and subaru leone page is russian http://www.autoreview.ru/new_site/year2002/n22/4wd/1.htm
  7. from what I know, roadranger "solo" clutch kit is the way to go if they make one for the car, no idea because most are for the big otr trucks Usually remanufactured is NOT worth the trouble you want a ceramic disc with dampening springs xl is usually NOT worth the extra money you spend for the FEW cents you save in grease ez pedal was designed to reduce the effort to accommodate the women drivers, and the weak ones by messing with the spring rates and angles a solo clutch can "break" by not self adjusting, but can be easily fixed with wd40 and the special tool
  8. I'm always here, but I haven't been out to figure out the system due to the rain all day, hope the weather holds out long enough tomorrow
  9. 1. don't drive while raining 2. roll up window while raining 3. remove gutter trim 4. water resistant tweeters 5. remove tweeters 6. lifetime warranty tweeters 7. cheap tweeters 8. reposition tweeters 9. duck tape over tweeters
  10. search for window removal there are two ways to attach and remove the windwo according to the mounting method peel away the metal trim and knife the glue "hammer"
  11. http://www.towerhobbies.com/products/fuji/fjig0064.html I saw this critter, and was amazed and the lineup http://www2.towerhobbies.com/cgi-bin/WTI0097p?MANUFACTURER=FJI
  12. there's also an engine for model planes post 600, good nite, pics later
  13. the idle adj screw is on the front, by the ps pump on the left
  14. turbo hg is made of asbestos, others are not, according to the fsm
  15. state park sticker is a thing of the past, it was in the 80's active camping plan on about $/nite only tent spots, remote, at preparation canyon state park
  16. is there a way to wire up the ac elctric fan so that it has automatic control and manual with a flip of a switch?
  17. what gives? are 91k images necessary? what browser do you use? I tried 1x, opera, netscape, and ie, no luck same issue with your website
  18. I have noticed that your pics do not download completely after over 13 minutes of downloading with broadband test speed of 467kbps and it's annoying nice color
  19. for the support I felt like using the legal limits of flames and argues instead of making a mess elsewhere
  20. I don't use any things that you speak of, I just "tweak" cars and computers I know what I talk about, and have a hi degree of respect and knowledge on the board, and in real life there's 4 subarus on this road where I live, and one is mine no smoke, drink, whatever :madder: :argue: :madder: :argue: :madder: :argue: :madder: :argue: :madder: :argue: I started this post after archemitis, and finished after bushbasher, not seeing that bushbasher had posted I'd like to see a pulley clutch system lol Hes not on crack he's just creative. I dont get the adding ceramic disc part though I'm creative combining necessity, opportunity, and experinence ceramic disc is something I have thought of a long time http://www.roadranger.com/products/clutch/clutch_solo_md.htm shows 3 pad ceramic solo http://www.roadranger.com/products/clutch/clutch_ep2000_epplus.htm is the ez pedal http://www.roadranger.com/products/clutch/clutch_solo_hd.htm shows solo 6 pad ceramic http://www.roadranger.com/products/clutch/clutch_solo_xl1552.htm shows the xl with many good pics
  21. to lighten the pedal weight, drill holes in it to reduce the force, you "could" 1. add a pulley system for mechanical advantage, or 2. use a different clutch setup that changes the configuration of springs involving angles and rates to lighten the rotating mass of the clutch, you "could" use a ceramic 3 or 4 pad disc
  22. before I read and looked at the rest, accelerator pump linkage, anti-dieseling solenoid, and air box didn't seem "right"
  23. depending on where the car was "intended" to be sold california 84 had feedback and 4x4
