Everything posted by The Scooby
svx seats in brat!!!
so it took the same work it took me 4years ago when i put inpreza seats into my 86 GL wagon, swap rails, bolt up the fronts redrill rear's and put some bolts, nuts and lock washers. those look very nice in there.
"whoomp whoomp whoomp" up front.
we have them in stock at Aaron's subaru only wrecking yard in seattle. and wont be a problem to ship it to you VIA UPS. give us a call if your intrested 800-541-7271 or 206-243-4665
new bumper
ya i just checked harbor freight and they have the 3000lbs for like $100. ill have to go get that today so i can mock it up on my bumper before its done.
new bumper
also what minimum weight for a winch you would recomend. found one locally for $100, 2,000 pound pull. i was thinking with a snatch block and a few pullies it would be fine to pull my car around right? or should i save up and get like a warn or ramsey 4-6Klbs winch? Thanks, Shean
How many have you meet and greeted.
zap... thats it until the WCSS
July 13th TSF *I broke it and can't go*
well that sucks, but just to let you know, the stubs comming out of the front diff are soposted to have a little movement. all subies are like that even on the new ones. check your drive line, you could have lost a weight or the joints are going bad. pull it out and move it around. if it feels crunchy, wack the side of the u-joint where its pressed in with a hammer and re check. i had the same problem with the wife's outback, hit it with a hammer and its good as new. little trick i learned while working on cars for the last few years.
new bumper
well ive been wanting to make a new bumper for a while now, and now that i got a welder today i can build something simple with light mounts, and beefy enough to be able to pull my car with. started with some 3X6 tube steel, and got some steel pipe thats 2.5inch OD and made a grill protector. still have to add some light tabs for mounts, maybe some headlight protectors, finish weld the bumper brackets, and make up a skid plate. so hopfully tomarrow if i get time after golfing i can bolt it into place to check everything then finish weld the mounts. if you have any recomendation or ideas please feel free to toss them out. ill get some pictures uploaded in an hour or so.
Walker run Saturday July 19th.
ill have to pass this time, rather save money for gas, spare tires, tool kit, etc. for WCSS
how long of a drive is it from seattle? if not too far i would be down to go.
swaybar delete? let's hear the good/bad/ugly for sway bar removal...
why not fashion up some sway bar quick disconnects and have best of both worlds. takes about 1 hour to make a set for the front and back, have them in when on road, pull them in a few seconds when ready to wheel. im making a set right now for my wagon.
couple pics of my brat on the beach
nice looking brat :cool:
Check out what I got yesterday (a new lifted Brat)
ya you do have too many, you need to sell my that brat now for $1200.
WCSS Astoria , wheres the trails , lets do a run during that weekend
im down for anything, dunes sound good, i was planning on going to the beach anyways with the wife, i know she will have fun no matter what we do since we are getting out of the house. i hope to have my 2inch lift by then and maybe a welded rear diff.
Saturday the 5th Walker Valley anyone?
what size lift and tires are you guys runnin? if my plans are good enough for me to be able to make it ill be down to go anytime.
imp offroad vid
that looks like fun. can't wait to build some safari doors for my GL wagon and get out onto some trails.
justy issue
ok looking for a wiring diagram on the just tranny's. the one im working on is a 1990, injected pushbutton 4wd. put a JDM tranny in it, problem is is that the old trans had 2 sensors, JDM has 3, no matter how you hook up the two ether 4wd light stays on or stays off but 4wd doesn't work. any help
How should I get rid of my old '92 Loyale?
lift it, and put some mud tires on her, have the whole car sprayed in truck bedliner, then have fun in the trails.
legacy stereo into loyale
anyone done it? we have many stock cd player stereo's from legacy's at work and i wanted to see if it will go in. Thanks, Shean
lift size
awsome thanks for the info. now i just need to find someone who has the weekend off to help. ill bring some cash and your favorite 6'er
lift size
no the front im leaving alone, rears are at the highest, and when i do the lift ill do 2inch in the front and drop the sub-frame 1inch, and the rear 2inch and drop the rear diff 2inches. i think ill be fine with that settup
ever do this?
let see, was offroading with a buddy in his chevy luv that was on 33's, went slow through a small pond about half way up the tires, water hit the coil and it dies there. got a replacement from the wife after 2 hours. and ive done the 4wd thing a few times wondering why it was so hard to go anywhere.
quick question
i like power tools so i have no problem cutting the crap out of the fenders to get it to fit.
lift size
well if there is anyone in the sound area of seattle and willing to help me build one i am very willing to pay for your help. i was gonna build it myself but i have to get my welder fixed and stuff. i was thinking of 2inch suspension, 1inch front subframe, 2inch rear shocks and 2inch at the diff would be fine for a trail rig and daily driver. im not wanting something hardcore just a fun trailrig i can use to go hunting, and play in some mud here and there.
lift size
ya i clear in the front fine just on full lock it rubs while driving. rear rubs on large bumps and on full compression of the rear suspension. i tried 2wd rear shocks and they are the same size as my 85 4wd ajustables at the tallest notch. i think i should be fine after i roll the fenders and the 2inch lift. i measured the tires and they are 26.5's so with the 2 i hope to be fine, if not then they rub a little.
lift size
im running 215/75/15's on stock 85 suspensino and offroading on full compression they do rub in the back alittle. i was gonna pick up the SJR 2inch lift kit but i want to make sure i will not rub, i dont mind the occaisional rub but not all the time. ive searched but found nothing, Thanks, Shean
