Everything posted by The Scooby
Reusing a burned engine?
The Scooby replied to dave833's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi would not use it simply because the heat under the hood like that can effect the strength of the aluminum, case in point, i work in a subaru wrecking yard, kid had a 06 2.5i impreza, rolled it and the engine caught fire. we pulled the engine and tore it apart to see if anything was good for a rebuild to sell. even the valves where brittle, it had made the intake manifold and water cross over pipe so weak that they crumbled in your hands.
H Braces
The Scooby replied to rpiereck's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif yours is turbo it should.
Unidentified switch on gen2 leg
The Scooby replied to Ross's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwindshield washer warmer, your car has the cold weather package basically, i bet this is a 95-99 legacy, or newer, but some of the 90-94 legacy's had them as well which i believe was the alpine edition.
Would a 98 subaru 2.2liter drop into a 1999 legacy sus?
^^this guy knows his stuff^^ i only add that the flexplate for the 2.5 is different from a 2.2, so you need to reuse your 2.5 flexplate. and only auto 2.2 cars have the EGR until 98 when most of them have them.
What to put in my 2.5 GT?
The Scooby replied to dave833's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif you want something that is reliable, and is a drop in go in a few hours then go 2.2. if you want to spend months wiring everything and goofing around then do something else. ive put MANY 2.2's into outbacks honestly you dont notice the difference.
Subaru repairs
The Scooby replied to jackandrew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX+10000000 +10000
what to do...
The Scooby replied to toganet's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXget the car, worst case you replace the tank and lines, on the FWD its CAKE work. get the car and enjoy. or since you will have to drop the tank ether way change it to AWD.
Subaru repairs
The Scooby replied to jackandrew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi can do a tune up on a DOHC 2.5 in 30 minutes, you just need to learn the short cuts or tricks to make your life easier. honda timing belts are a ***************, oil changes are a pain on lowered ones, etc. anyways i have worked on cars for over a decade now, and by far i rather do a tune up/timing belt on a DOHC 2.5 then a honda anyday.
Pug Wheels
im running 30's, and i agree with monsteru, my car is not a hardcore trail rig or rock crawler. its just for some light trails, and mud pits.
My 1986 Brat
na im putting a EJ22 into my lifted wagon right now, as well as just finished my custom rear bumper. im keeping it, but wouldn't mind a brat, trying to find a GEN1 mostly though.
Pug Wheels
i have the same ones, they stick out a little, not too bad, maybe 1.5inches or so with my 215/75/15's wild cat A/T's
need 15" rims
The Scooby replied to ibiltit's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyep on MY00 they when to the 11.4 brake rotor size, same as the WRX on the front. you will need 16inch or larger. why not just get some snow tires and have them put on your stock wheels, then when snow is gone remount your old all seasons or whatever.
I need AWD
The Scooby replied to Subaru_dude's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXswap it to AWD just need the tranny, rear suspension cradle, and AWD gas tank. a weekend and you got AWD.
Question
The Scooby replied to android25ua's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdont try to turbo yours, you will be limited to around 5-6PSI which might make another 40HP, but for $2000+ for the turbo kit its not worth it. you also have to look at the resale value, you will NOT be able to get anywhere near the money you put into it back. i suggest to wait, save your money and keep the reliable car you have now. when your done with school and such get a newer turbo legacy and enjoy that. im 22 years old, have had 19 cars, and thus far my 96 impreza has all suspension done, you can enjoy suspension every day, alot of power you cant use most of the time.
1997 Impreza/1999 Subaru legacy - fenders/bumper/hood
The Scooby replied to duallegacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX90-98 2.2 will work, only difference is in 96 they switched to single port exhaust, so if you buy a older engine just get the front y-pipe from the place you get the engine from. +100 yes
Subaru repairs
The Scooby replied to jackandrew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsoobie's are alot cheaper then honda's, i know that first hand. find a 90-99 legacy with a 2.2 engine, do the oil changes, and timing belt when needed and they will last for ever.
My 1986 Brat
intrested, post some pictures and ill let you know
Roll Call for Offroad Rigs 2008
is that a 2inch lift or 4inch^^
85 psi then 0
or the wire came off the sender.
need date of wcss11 meet
ill be there ether in my lifted wagon thats getting a EJ22, and/or my 96 impreza that i took down last year.
WTB: Right rear strut
The Scooby replied to SoobieKoralli's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXstrut is bent, as well as the lower control arms, ill put money on it. i see ALOT of bent struts on the cars that come into my work, subaru wrecking yard. if you find out what you need for sure i have it all in stock so PM me.
EJ22 Turbo 2 non turbo
The Scooby replied to Mugs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou can use a turbo crossmember with a N/A engine, but not vice versa, you will need a whole new exhaust, the 2 wiring harnesses. reason i say both is that one goes from 1 ecu plug out over the drivers fender and to the intake manifold, also to the alt, fluse block, headlights, horns, fans, and ABS pump. then the second harness hooks 2 plugs to the ECU, then to the fuse block and chassis harness, then to part of the dash, behind the heater box, and out into the engine bay between the heater hoses. hooks to tranny and the map sensor and boost solnoid on the passenger strut tower, grounds and FWD fuse, also over to cruse control, A/C, and by the brake booster. those are different because of the boost solnoid as well as the other sensors and such, you will need to change ALL that to do it properly as well as the ECU and/TCU if it is auto. better off putting the car up for sale and let a enthusist put it back together and finding yourself another non-turbo gen1 legacy.
Wheel PCD of Leone/Loyale III?
bolt pattern or lug pattern is what ive always known it as.
the recued 83 GL wagon pics thread
very nice, hey uhh if you ever want to sell the rack let me know ill but it for sure.
Winter storm damage to the XT! No's!
i have the rear glass pulled already in great shape, and if you want to make an appointment i can have it installed as well PM me if intrested.
