davebugs
2
Everything posted by davebugs
	Those tanny's are the issue. Hard to get past 200-250k with one. The 2.0 engines are pretty bullet proof. Reverse to that tranny is what HG's are to a Suby 2.5 DOHC. As an idea. That tranny used costs me 700. I can get that 2.0 engine delivered (minus distributor) for under 100.00 with a 6 month warranty. Under 150.00 with a distributor.
	Usually it's reverse on those tranny's. Around here they go for about 700 used. When reverse fails it's only like 60.00 in parts but a whole lotta labor since VW German overengineer everything. I have a tranny shop do it. Only ones I've had get stuck in forward gears was the linkage being a problem. I happen to have a car with that tranny setting here that I haven't gotten to. A 97 Golf GTI 2.0 5 speed. It's a running/driving car that needs some work. I'm more likely to part it but shipping would be killer. Good luck with the internals of a VW trans. If you do go used try and verify reverse first. They all make a bit of a "whine" in reverse - it's a VW thing.
	I always pull the engine is similar situations - clutch jobs and such. My reasoning is that I'm usually doing HG's and other work and it's simply easier to work on the engine out of the car. All the major maintenance stuff. If you can't find a flex plate local drop me a note. I know I have some 2.2's but I'd have to see if I have a 2.5 already hanging on the wall.
	97 should have valve shims to adjust the valves. But if it got hot before the HG's were done it could easily be rod bearings. Perhaps others here will have more positive suggestions than rob knock/rod bearings. I usually listen to the area behind cyl#3 - closest the firewall on the pass side while standing at the front of the car. I pay particular attention to the noise when coming down from reving the engine. Good luck. Please give WNC a little more meaning - like a city/state. Someone here may be able to listen to it for you as a second opinion.
	Used many of their kits without issues. I source my own WP and belts. I know many sets I've installed have gone 100k. I use their idlers and sometimes new style tensioners. Haven't been doing many Suby's lately thought. Bearings used to be "GMB" which are very acceptable. my experience has been very good.
	Here's what I do. I have a local exhaust place that bends pipe. They will put a new section welded in there for 40.00. Probably less than I'd have in 2 of those flange clamps and the tapered donut gasket and fancy spring setup. And was less time consuming and better in my opinion. As GG has pointed out I get a good price because they do a lot of these for me. And you can't take it apart there without cutting it in the future - but usually I've just done a complete reseal and engine swap or HG job so who cares for quite a while. Fixing that is a real pain. And I was never happy with my fix. So it may be worth a few calls.
Hey Skip where R you??
davebugs replied to biffanyus's topic in Historic Subaru Forum: 50's thru 70's
Skip isn't online much anymore. Drop me a PM if you'd like more info. -
	Good luck as a fellow VW fan. I try not to get too exotic with any car. I stick mostly to TDI's but just bought a 2002 VR6 GTI that needs engine work - fella didn't have the tensioners checked. Needs an engine at 90k. Bet that 4 motion will fly. A note. I usually do the 95-99's. Only 2.5 SOHC I have done was a nightmare. Several engines to get a good one. The GF's 2006 Impreza seems to be doing well but she doesn't do the miles she used to (not having a job will do that). Pushing 80k? with no issues yet. Too bad about the luck you had. But I'd try a Suabru again if the opportunity arrises. In the meantime have fun with the VW.
	GG, PM me for info or (now I forget - Borla) replacements local to me. The Audi's get pretty expensive to fix pretty quickly. That's why I stay with the VW's. I hope to be around next week and may know some folks who know some Audi folks..... But I'd need to know specifically what was needed.
	There was actually a thread about this in the last year. Don't think it ever came to a real conclusion. Which probably means that aftermarket is o.k. Often I have agood used one - but am starting run a bit low. I use OEM myself when I need a new one. Not enough of a price difference to gamble for me.
	Which place did you buy it from. I'm about ready to start a few LED experiments and am electrically challenged. I did however invest in CREE some time ago and it's been a VERY good ride. I'd expect it to slow down soon for a bit though. I have a few LED's at the house, and have seen them used in cars. Much better light. City's and College's switching to LED's all over the globe.
