Everything posted by subaru360
91 Legacy Diagnosis, MAF Fixed
subaru360 replied to Durania's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it uses the same solenoid as a '97 I have one for you.
Exhaust Mid Pipe Replacement Question
subaru360 replied to msmithmmx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat thing in the mid pipe is a resonator. I thought it was a cat as well the first time I ran across one. They started putting them on late 97's and all the 98's and 99's had it. No clue why.
97 outback questions
subaru360 replied to mdjdc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX96 EJ25 heads should work just fine on a 97 EJ25. Everything is the same except solid vs. hyd lifters and they use the same head gasket.
Are 96 and 99 Legacy seats interchangeable?
subaru360 replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAll 95-99 front seats are the same. The wagon has a different rear seat than the sedan. 95-99 door panels will interchange but the 98-99 switches mount slightly different. If you get the panel with switches or are creative it works.
Northeast folks Winter activities
I'll probably go to carlisle, it's not too far from me. I have the 360 looking halfway decent now, it's all one color and no more rust. It's not a show car but whatever.
tow hooks
subaru360 replied to pamike's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey seem really solid. I pull cars up onto my trailer by them and also use them to tie the cars down. I think they would hold up to pulling a car out of mud.
96 2.2 auto->manual,will it work
subaru360 replied to _Aramchek_'s topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt will work. The automatic engine will have EGR. Your manual won't. It shouldn't make a difference. You could just drop it in as is with the automatic intake manifold and the egr just won't work or plug the EGR hole in the head and use your old intake manifold.
How cold has your Subie been?
subaru360 replied to Sweet82's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell 69 subaru's don't have a dash thermometer:-\ It was 15 this morning and the 360 fired up on the first try.
Changed the battery and now all the turn signals are blinking. What gives?
subaru360 replied to Towel Rail's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTheres a big black box hanging under the drivers side of the dash for the keyless entry. The button is usually zip tied to the wiring for it.
Exhaust pipe repair 98 outback
subaru360 replied to blaze's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI get a lot of them where the flange at the back of the converter rusts away, I use a split flange on them. It's like $5 at autozone.
Documented: The 1970 FF-1 Project car...
I wonder if you could get some of those sleeve gaskets things made up in copper by one of the places that make race copper head gaskets?
98 obw replaced timing belt now pour idle
subaru360 replied to wayneb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou should check compression. That will tell you if you have bent valves. If you broke a belt on an EJ25 you most likely have bent valves, they are interference engines.
Exhaust Bolt Removal
subaru360 replied to msmithmmx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou need to cut it off on the side with the nut (not the side with the spring) Cut right through the nut flush with the flange. If you cut it in the middle the end with the nut will stay attached, it doesn't pull through, there is a step in the bolt. When I get them like that, I try to snap it off first, before I break out the sawzall.
1999 forester engine
subaru360 replied to Stupidru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLook at the mounting of the engine to the transmission. See if it's 4 bolts or 8. Does your engine have EGR? Is it DOHC or SOHC. This will help us determine what 2.2 is easiest to use. '99 was a transition year with lots of oddballs.
Is it bad to mix tire brands for awd?
subaru360 replied to ron2368's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's best to have matched tires, but IF they measure out the same (not likely) it's acceptable to have 2 different brands. I would hold out for 2 more of the same tires. Unless the dealer has a very small profit margin on the car (not likely) they will give you 2 tires to avoid losing the sale.
Will 90's OutBack Hood W/Scoop, fit GT's?
subaru360 replied to SubeeTed's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes it fits. All legacy hoods interchange 95-99
97 2.5 DOHC - able to assemble heads on motor?
subaru360 replied to davebugs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou want to put the cams in with everything in the position that you install the timing belt at. Then just put belt on and nothing interferes.
subaru360 replied to davebugs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou're doing it right. Make sure to line up the mark on crank before you put the cams in. When you put the cams in, get them close to lined up and you won't have any interference problems. If you aren't sure put the pulley on and the double marks go towards each other.
the electric fe coupe
I have an extra 360 sedan sitting around. I thought of putting an electric motor in it. Somebody has already done a 360 van and it came out good. But the sedan is so small, nowhere for the batteries. Maybe someday there will be tiny lightweight batteries.
axle change, need a wise man
subaru360 replied to yohy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt keeps rocks and dirt from getting into the seal.
subaru360 replied to yohy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think you could switch them if the diameter of where they press on is the same. I bet it is.
96 Legacy 2.2L Oil Leak PLEASE HELP
subaru360 replied to stonecloser's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTake it to a car wash and use some spray degreaser and the high pressure hose to clean the bottom of the engine. Then drive it a few days and the leak should be easy to find. Whith what you've done so far it seems like it might be the seperator plate on the back of the engine under the flywheel.
98 impreza
subaru360 replied to subaruguru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would pay up to $1000 for a '98 Impreza with a bad engine. Mileage and condition weren't mentioned, which is a big deciding factor in what to pay. I use the NADA guide for pricing.
1998 Legacy GT sedan, Ltd. Common mechanical problems?
subaru360 replied to D Love's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat's low mileage for you? If I can find some LGT's that need work like head gaskets, engine, trans etc, I think I could sell you one in that price range no problem. I have 4 U-pull yards in the area and get parts dirt cheap. I'll keep you in mind since I have no luck selling sedans or leg wagons around here, everyone seems to want an Outback so that's what I've been doing. We've totally jacked the OP's thread now...
subaru360 replied to D Love's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey were Outbacks and really nice ones. Here in PA Outbacks are what everyone seems to want. Even on a lot 5200 is a lot to pay for a 98 LGT. Most of the lots around here advertise them for around 4500 or so. You can usually get a nice one off the 'bay in the 4,000 range. I'd be willing to bet the car in question could be talked down at least 500-1000, especially this time of year. Sales are always slow around the holidays and lots will be desperate for a sale.
