Everything posted by EVOthis
How to turn off car alarm?
EVOthis replied to ryanw's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif you have the key....try cycling the key on and off 4 or 5 times.......(dont crank engine or start car) just between off and on/accessory.....
Well I finally made it..
EVOthis replied to FSRBIKER's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWOW! in all luck i will hit that mark in about 5,000 miles.....
Best tire shop? Where do you go?
EVOthis replied to soobtank's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.Tirerack.com ......got my Kumhos from them......great service and great prices.....
Swish swish swish taking hard left turns
EVOthis replied to andrew_j's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXglad to hear it was something simple.....
Urgency of bearing replacement?
EVOthis replied to tjxtreme's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXon this topic......the other day i got a car from a customer who complained about a horrid grinding/squealing noise......got the car in the air and wouldnt you know i found a rock between the backing plate and the rotor.....
1...maybe 2 exhaust leaks
EVOthis replied to LosDiosDeVerde86's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXreally? JB weld can withstand that kind of heat?.....thanks for that tip rooster it may come in handy in the future......
EVOthis replied to andrew_j's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnot saying that it cant happen from a flat tire....but are you sure the noise wasnt there before you had your flat? its not like a humming sound is it? if you have the means definately do a through visual inspection of the car before anything else......how many miles are on this wrx? automatic? manual?
Thoughts/comments/suggestions 2003 Impreza RS
EVOthis replied to yohy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXfrom what it seems all subarus have had wheel bearing problems......especially the newer legacys and outbacks....we get them all the time at work.....i think the svx was also prone to wheel bearing failures.....anyways yes i would def. check the wheel bearings.....
Tire Rotation
EVOthis replied to PaulMidi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXive heard before that people do it every other oil change (6k-8k miles)....
EVOthis replied to andrew_j's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhow exactly was the tire fixed? they didnt put that green slime in it did they? patch/ plug? are you sure its most acurately defined as a "swish"?....
EVOthis replied to andrew_j's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXalso.....take a look at your pinch welds....there are very small water drain slits that run all the way down the pinch weld.....it is pretty common that those get clogged up over time....you could just take a flat blade screwdriver and hammer and make sure they are opened up all the way.....
Trailer Hitch Install and Frame Weld Nuts
EVOthis replied to StructEngineer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXis this the new 09 forester?
01 Forester, Anything Else To Look For?
EVOthis replied to subsince77's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXtake it for a cruise and drive it in some tight circles and make sure it feels smooth (no vibration)....not to sure if torque bind is common in this year but in my 96 it was....
ABS Light 1995 Legacy Outback - Checking Codes - Pics!
EVOthis replied to joeo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmy ABS diag. pins were a pain to find also.......they had them woud up in elec. tape...
haynes repair manuals
EVOthis replied to greenleg88's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi think they are excellant.i have one for my 96 Legacy L..the first time i did my clutch i went entirely by the haynes repair manual and only ran across 1 minor glitch in the steps....
Crankpulley grinding timeing cover
EVOthis replied to gbb1277's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXjust another suggestion...take a look at the pulley with the engine running and the bolt tight...does it wobble?......when i bought my 96 legacy my crank pulley was actually bent....
Good Substitute for Subaru Coolant
EVOthis replied to ergo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXah yes we just recieved that coolant were i work.....i couldnt believe they said the change interval was 11 years.......well def. loose some work there....
96 Legacy Brake Rotor
EVOthis replied to guidance1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthere was a very informative post a while ago here by a guy i believe by the name jamal......anyways according to his post your rotors should be the 260x22mm size.... also not sure if you have NAPA out there but i buy alot of parts from them and so far they have held up pretty well.....
98 OBW Starts Dry!
EVOthis replied to Subeast-EA81's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwe used 5-30 at the Subie dealer were i work for all Subarus...however i felt it was always better to use a little heavier weight when you have a high mileage car.....i put 10-30 in my legacy......PCV is only a few bucks and a few turns of a 19mm so i would throw one on (cant hurt at that mileage)
98 Legacy L
EVOthis replied to greenleg88's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcheck out this http://www.streetsideauto.com/productlist.asp?brand=BBWQ&lsbYear=1998&lsbMakes=SUBARU&lsbModels=LEGACY&lsbSubModels=L&LookupType=YMM&ParentID=7&SubID=7&ptid=4555 :)
Strange Transmission noise
EVOthis replied to powderhound's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXradiator is pretty simple to replace.....drain system....pop off brackets.....hoses.....fans.......it kind off just pulls right out.......it shouldnt take more than maybe and hour or two...while your doing it you might want to consider also changing the upper and lower rad. hoses......it def. cant hurt to change the gear oil at this point.....besides you will get to see how much metal from your gears is on your drain plug.......
EVOthis replied to powderhound's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX-QUOTE-now i gotta find out why my 92 doesn't like 4th gear,almost feels like it's kicking it out of gear..to the point where i gotta hold it in gear.of course it doesn't do it with a load on trans,only if i let off gas..(gotta get under it one of these days and check trans mounts)-QUOTE- subie 94- my 96 had the exact same problem with 4th gear a few miles back....i checked all my mounts and they were all ok.....but eventually when i tried to hold it in gear it would grind its ars off...and eventually i lost 4th gear.....plus i needed a new viscous coupler....i ended up just replacing the trans with one with like 93,000 miles on it.....than again the origional held up good until like 190,000 miles.......anyways just thought i would share.....
99 Outback Rumble During Sharp Turns
EVOthis replied to njvitek's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXautomatic or manual trans?....sometimes it is possible for it to "repair" its self (mostly in automatics i believe) with repeated flushes or changes of the transmission fluid and using an additive/conditioner do a search on the forum or take a look down at the bottom for the "related threads" on this topic....there is tons of info out there..... by the way welcome to the forum....
Easy Transmission Front Seal Replacement
EVOthis replied to Gloyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwow....very informative..... thanks for the great write-up!
