Numbchux
    109
Everything posted by Numbchux
  1. Agreed! But TP leaving doesn't change that. In fact, quite to the contrary...with Pastrana, Block, and L'estage officially not competing next year, there's a real chance that someone "new" is going to win it. That was a big reason why we were trying to make a push for nationals.....although we weren't able to come up with enough sponsor dollars to make it happen. maybe next year. Maybe a Super Production car? Also, I don't know anything about him, but it seems that David Higgins (SRTUSAs second driver for next year) has the credentials to do very well. Not to mention the 2WDs. Dillon van Way and Chris Duplessis both have new cars. Chris Greenhouse is always a hoot to watch in that poor old Neon. And I'm anxious to see who (if anyone ) tries to compete in the Fiesta cup. Unfortunately, I'm sure the loss of those big names will lead to the loss of a lot of spectators, which makes these events financially even more difficult. We don't need Pastrana to have fun in the woods.
  2. speedometer is mechanical, and was for much of the '90s. So no, the VSS wasn't for the gauge. You'll probably have issues if it's an OBD II ECU if you don't have a VSS. some EA81s (don't ask me which ones....I don't know...) already have the VSS in the cluster though, just a matter of hooking up the signal wire.
  3. EA81 rod ends work just fine. and are shorter than the EJ/ER stuff so you can get your alignment correct.
  4. ?? only in the front, and only if you've got a 5-lug swap. AFAIK, Noah is the only person who's done it, and he had issues.
  5. Doesn't sound like a mechanical thing. More like a misfire under load. Could be caused by a lot of things, but an ignition problem would be most likely. start by checking the ignition timing. Then inspect and replace as necessary: plugs, wires, cap, and rotor.
  6. stock turbo compression, and stock boost on an EA82t does not require high octane. The biggest factor is ignition timing. Higher octane fuel burns slower. so if you're tuned for 87, and run 91, it'll burn later, which can be a problem (and vice versa). So no, do not just run the "best" available. Use what it's designed to use. As far as I know, stock timing is designed for low octane, but I'm not 100% sure. The FSM has separate specifications for all engine types that year (SPFI, MPFI, MPFI Turbo), but only one section for fuel, where it says 87.
  7. Really? This was COMPLETELY predictable. I mean seriously, he gave up the National Championship last year to go to Australia with the Nitro Circus crew. Pastrana wasn't getting much competition here in the US. Really, there was a point last year where his speed factor was like 104, which theoretically isn't even possible. He is not a die-hard rally guy, he's a motorsports guy. And his life is sponsored by Red Bull. Let's assume he's not going to leave them, so what's the next step? WRC? Red-bull already has Sebastian Loeb. Dakar? Carlos Sainz. And Subaru isn't in WRC at all....so he'd have to completely change teams, only to play backup to a much more famous (and possibly better...) driver. The NASCAR redbull teams are not doing that great. Pastrana has said he's dreamed of driving for NASCAR his whole life. Also, driving for NASCAR is a totally different thing than watching a bit on TV. it may only be left turns, but at 200mph.....yea. I even have a greater respect for it just playing a bit on GT5. I was kind of expecting him to do some Monster Jam racing. But apparently his dabbling in that over the last couple years didn't spark his interest.
  8. yes, the angle of the control arms will create a problem with alignment. But, the CV angle, will make for very quick axle destruction. Anything beyond 2" is a recipe for problems there.
  9. yes, whatever height blocks you have on the front xmember will need to be installed in the rear xmember.
  10. the rpm thing doesn't really make sense. but Subaru Speedo's tend to read high....so that might be it. if you didn't have to swap axles, it's definitely a turbo transmission. And the only combination of turbo, PT4WD, and D/R was the '85-'86 RX. So yea, it's a 3.7. Also, that means it's a 1.19:1 low range and not the 1.59 of the non-turbo cars.
  11. It's a project, but even then, I think my first one only took a couple hours. The last time I swapped transmission internals (way more than just diff stubs), it was only like 45 minutes. some pictures. My thread, talks more about mixing and matching internals. But a few pictures of the transmission apart: http://www.ultimatesubaru.org/forum/showthread.php?t=106668 and The Beast I Drive started making a hybrid trans awhile ago. I don't know if anything ever came of it, but he's got some great pictures of the teardown. The tailhousings will be different, but the XT6 one (FT4WD, single range) will be closest to the EJ design. You can't see it in any of the pictures, but on the shifter rod inside the tailhousing, there's a 10mm set-bolt that has to be removed first. Otherwise you'll have a hell of a time getting it all apart. http://www.ultimatesubaru.org/forum/showthread.php?t=106140
  12. well, using a gear calculator. A 3.7 (turbo, .871 5th gear) trans with 24.65" tires would be turning about 3100 rpm at 70, whereas the 3.9 (non-turbo, .780 5th) would be turning 2900. But, if you're binding with a 3.9 diff, and not a 3.7, than I'd say you got a 3.7 trans. And if it's a PT4WD D/R. Than it's an '85-'86 RX trans. How did the axles work out for you? Your turbo wagon would have already had 25-spline axles, and if your donor trans had been a 3.9, it would require 23-spline axles.
  13. yep, it's been released for awhile. And they've announced his replacement (whose name I don't know.....but he's got the credentials....)
  14. Yea, you'd have to convert to a longitudinal engine configuration. Which I HIGHLY doubt there's enough room in a fiero engine bay to do. Keeping it mid engined, would mean the entire engine would be in front of the rear axle, which would mean you'd be cutting into the cockpit/seats I bet. Not practical. or....convert it to rear-engined And even if you were successful at either of those options....you've still got fiero suspension and electronics. bleh. There are dozens of V6 and V8 options that work great in the fiero. Just stick with that, or get a 914 for you mid-engined Subaru option (My uncle has a '74 that I've been trying to get him to sell to me......one of these days....).
  15. Gary is close. you don't have to actually swap the front diff, but you have to get to it. the stubs are held in with a snapring on the inside of the diff. AFAIK (I've never taken apart a 23-spline transmission, so I'm not 100% sure), the splines on the diff-side of the stub are the same, so once you get it all apart, they should be a direct swap. Taking apart the transmission isn't toooo bad. But it's not easy. You have to pull the center diff housing off (don't forget to pull the access panel so you can remove the set-bolt from the shifter so you can get enough play in it to get everything loose). And then all the bolts to seperate the transmission case. there are a few sources for the XT6 FSM online, they have some diagrams about how it all goes together, as well as torque specs/sequence for re-assembly. Let's just say, I'm VERY glad that the first transmission I pulled apart was junk already....
  16. I thought GSP sounded familiar. Like someone had just posted a rant about them being junk. so I searched....yep. It was you. You know they're bad. you were told they were bad. now you've posted a second thread about it hinting that it might be the bearings, and when we gave you other ideas, you are sure it's the axle. Get a decent axle!! thread I was referring to, for those that don't know: http://www.ultimatesubaru.org/forum/showthread.php?t=118721
  17. no, no spacers. this picture pretty much tells all: fender lip is rolled. plenty of clearance. I had ~400lb/in springs on it then, so there was very little travel. Shortly after that, I switched to the G-C setup (275 lb/in in the rear), and the static ride height went up about a 1/2" to give some extra room for travel.
  18. I have used Redline synth, Amsoil synth, "Scotty's Cocktail", Valvoline w/Rislone, Castrol HypoyC w/rislone, Straight HypoyC. Extra-S blows them all out of the water. I'll never use anything else in any Subaru MT.
  19. axles will be just fine. driveshaft will have to be modified (shortened?) IMHO, with an EA82 flywheel/transmission, and an EJ22 in front of it. Best bang for the buck clutch option is a Beck/Arnley clutch kit for an XT6/EA82t (#0619130). I've bought and run 3 of these over the years (2 with EJ swaps, one in an XT6), and am very impressed with the quality, and price (RockAuto has 'em for less than $200).
  20. define "brand new axle assemblies". They are definitely not all created equal
  21. get your hands on a hydraulic EJ pedal box. it'll all make sense then.
  22. Hard to say, but I would bet 3" would be pushing it. Especially with the multilink rear end, I think you'd encounter some alignment and travel issues if you spaced the shocks more than a couple inches.
  23. yea, should be just fine. In fact, using the EJ compressor would definitely be the way to go. Custom lines is not uncommon. Just go in with all 4 lines (2 from each donor car) and tell them what you want, and they'll crimp 'em together how you need it. If your EJ donor is new enough, you MIGHT run into issues using a compressor designed for r134a with the r12 system. But I think the biggest concern in the conversion is proper oiling for the compressor, so it might be better.... btw, the r134a conversion wasn't until the late '90s sometime, so there are lots of EJ cars designed for r12.
  24. '92 Loyale RX transmission (25-spline axle stubs) XT-turbo rear trailing arms (sway bar mounts) XT6 sway bars, rear hubs/rotors/plates/caliper brackets, front control arms '92 FWD Legacy front knuckles, hubs, axles and struts. Also ebrake handle/cables '88 Nissan 200SX rear calipers '02 2.5RS front brakes Moog EA81 tie rod ends '02 Miata rear shocks Ground-Control coilover sleeve springs, 250 lb/in front, 275 rear Superpro poly bushings for the front sway bar and leading rods 17x8 +48 Rota Torques with 215/45r17 Kumho Ecsta ASTs
  25. Yep. Sounds like what I was thinking. Seems like he could just use his existing TC and flexplate (from the 2.2) on the 2.5, and be golden. But I'm no expert, I rarely re-install ATs .
