Everything posted by Numbchux
EJ20H swapped Gen3 Brat build Continues Tear down time.
Yea, I wonder if anyone's every done that before
xt6 urethane suspension bushings.
You'll have to find a US distributor of SuperPro. When I bought mine, it was kind of a pain. I believe I went through Modern Automotive Performance here in MN ( http://www.MAPerformance.com ). Sway bars on mine were all 20mm. Although they don't make bushings that will fit under the stock rear straps.
Front axle woes on 5 lug swap
Hmmm........my EJ donor car was a '92 FWD 4EAT Legacy. I've used those axles in a few EA/ER cars with zero length problems. Maybe they are shorter! BTW, the inner wheel bearing seal is a different size between XT6 and EJ knuckles. So if you are going to mix and match axles, you will need a different seal, otherwise the axle won't seat correctly and your wheel bearing will come apart. Separating the outer CV Joint from the shaft.....I give you, the pipe trick:
Swapping the 4.3Runner....IT RUNS!
spent some quality time on a '95 FZJ-80 at one of the UPull yards in the twin cities yesterday. Got full-floating hubs, disc brakes, and a factory selectable locker for about $150. The calipers will have to be ground a bit to fit under 15" wheels.... The axles don't support any weight, and can be removed with the wheel still on
Swap Heads 90 2.2 to a 96 legacy Block?
I thought the EGR port was on the head. So, just to clarify, you're just talking about dropping the '96 shortblock in a '90? Using the '90 heads, intake manifold, wiring, etc. etc. The EGR thing is the only thing I can think of that you might have in issue with. I thought it was on the head, but if not, just block it off.
alright, I'll say what I've been thinking the whole time. Cinder blocks...safety last, huh. Also, I'm glad to hear you only had to drill 2 holes to swap the XT6 crossmember. that must be a lot simpler than drilling 2 holes to use the EA82 crossmember and just the XT6 control arms.
5 lug swap questions/help!!!!
Yep, the XT6 is front handbrake. EJ stuff offers much better brake and suspension options. The tab on the knuckle for the tie rod end is in a slightly different place, which helps with the bump-steer and roll center. I ran without a handbrake for a long time, didn't really bother me. But I also swapped to Nissan 200SX calipers in the rear. You can also re-drill EJ rear backing plates to use the EJ drum-in-disc parking brakes and calipers. This means you only need the XT6 hubs, and almost any EJ brake combination. Or, there's some combination of early EJ 2-pot caliper brackets (turbo legacy, or ver. 1 WRX, I believe) that will allow you to put the XT6 caliper on the EJ knuckle. This means you still have the single-pot calipers, but the larger 276mm rotors.
86 3door: to ER27 or not to ER27?
getting a belt short to run without the A/C isn't difficult. the better wrap on the pulleys without the compressor, and reduced load makes a 4-rib work just fine. I believe the one I used was for a honda of some sort. I have a thread about it on subaruxt do it! You'll have to find somewhere to put all that wiring...but other than that it'll be fairly straightforward
RE: thread un USMB repair manual: transmission, axles, brakes section
What do you want to know? Here's the code from that EJ D/R that I had for awhile: The "X" is for Dual-range 5MT The last 4 are pretty hard to decode. But by substituting the "X" for a "V", I found an archived NASIOC post by gruppe-s listing this info: "-Push Type 5 Speed -1st 3.545, 2nd 1.947, 3rd 1.366, 4th 0.972, 5th 0.738, Final 3.9"
EJ Swap - Brakes?
I would not daily drive an EA82 with oversized tires and drum brakes, regardless of the engine.
More tinkering. Shifter cable is attached to the trans and routed. gas tank and exhaust hangers are all cut off. While it's a cool gadget, I really don't have any use for the altimeter. Soo.....I pulled it out and installed the trans temp gauge in it's place before: after: This gauge assembly is fairly sought-after, so I didn't modify anything crucial to it. also....there's a land-cruiser at upull......
'82 Brat, EJ22T Swap, Which Transmission?
the 4MT is.....not ideal. Depends what you're doing with the car. If you plan to lift it and put big oversized tires on it, you're going to want to sacrifice the street traction for the 1.59:1 low range of an EA82 part-time 4WD 5MT. But for every other use, EA82 5MTs leave a bit to be desired as well. IMO the only upside is PT4WD is great for a DD, as you still have 4WD for when it gets nasty, but you have FWD for mpg. BUT, with the torque of even a non-turbo EJ in there, combined with EA front suspension geometry, means you will have wheelspin in FWD. Even if you're not really hammering on it. If you're going for a turbo motor, you're obviously ready to sacrifice some mileage for performance. Which IMO is a waste unless you can put it to the ground effectively. The EJ trans will be a bit harder to install in an EA81, but not much more than an EA82 5MT. But it'll all be worth it. You will need a custom crossmember to hold it up, modified shift linkage, modified driveshaft (just for length, the slip yoke splines are the same for all subaru transmissions). Look for a '96-'99 Legacy L (2.2l) transmission. It will be a 3.9:1 axle ratio, so you won't need to change your rear diff, and cable-operated clutch, so you won't have to worry about converting to hydraulic. (Imprezas of similar vintage might have that gearing as well, there's a serial number on the bellhousing near the starter. throw that into google to know for sure)
Question about rear calipers
yep, only 6-cyl XTs were 5-lug. But either way, the calipers are the same. When I did the 5-lug swap on my wagon, I kept the GL-10 calipers from the 4-lug disc setup. The loaded calipers will bolt right up, and make the project quite a bit simpler. But reman'd calipers can be trouble. I bought one for the wagon (lifetime warranty), and I would have to replace it about once a year. IMO, youd be much better off rebuilding the caliper you have yourself, save yourself some money now, and some headache later.
"You know, I think something went wrong
Man, that sucks for Jimmy. AblePlanet pulled out of their rally sponsoring after last year, so he had to look for a new sponsor. He had his rear diff blow up at 100AW, and now this. Damn good driver having some crappy luck this year.
running lights stay on even if click button off?
Yep, it's the correct use of the indicator lights. And I'm pretty sure, the law.
Godzirra! 90 legacy project!
How's the project coming? I've been working on the shift linkage for my 700r4 into my toyota 4runner lately. And thought of you. I don't know if you have a plan, but my goal was to use the stock toyota shifter (my truck was an auto) to control the gm transmission. after some experimenting in trying to make my own linkage (could have worked.....but there would have been a lot of experimenting to get the lever arms the right length, and there isn't much room to work with for experimenting), I decided to go cable, and buy off-the-shelf. I picked up a B&M 80740 cable from summit racing, and a B&M 35498 "GM Bracket & Lever Kit". These are pre-formed brackets to mount that cable to the GM trans. the bracket mounts to 2 of the transmission oil pan bolts, and the lever arm doesn't protrude beyond the bottom of the pan. It's a pretty good way to simplify the fabrication, and only about $50 for both from summit racing.
I MUCH prefer this setup. As it allows the regular headlight/parking light switch to be automatically turned off with the ignition. I am in the process of modifying both my Toyotas to function the same way.
"New" RX.. uh oh..
Agreed!
Now for it to start nickel-and-dime-ing me to death..... compression fitting to hose-barb adapters. I will use these for all the steel lines (left to right. 3/8 pair for Transmission cooler, 1/2 pair for oil cooler, and 3 5/16s for fuel lines. The return line on the tank is the right size, also, the 3/8 compression to 1/4 female NPT for the last one is backordered) Also, transmission temperature gauge. Also got a drain plug kit and installed it and the sender in the pan. And a B&M shifter cable. This should drastically simplify my linkage situation. And a 6-position fuse block and one of the neat little rocker switches for my electrical systems (Rad fan override, on-board air, and 3 sets of lights). Also, since the tank is out, I'm working on moving it to the other side. Since I was planning on re-doing the mounts to lift it to match the body lift, it won't be hard just put them on the other side. Only things in the way on the other side would be exhaust (custom anyway...), and the shock (getting relocated anyway). Only extra work for this will be lengthening the level sender wires, and extending the filler pipe and vent (leaving the filler where it is....). This will allow me to put a mid-'90s Land Cruiser rear axle in it, hopefully next winter. There are a few of these on car-part.com complete for around $500. Which would mean 9.5" ring gear (should go well with my 7.5" front :blackeye: ), full-floating hubs, disc brakes, drum-in-disc parking brakes, factory electronically selectable locker, and the same width as the long travel IFS. Challenge is the diff is 4" offset from center......but only problem there is the gas tank. Also, the FJ80s are linked and coil-sprung. So some bracketry would have to be cut off and spring perches welded on.....doable.
W series Toyota trans adaptors
toyota tcase shifter pattern: you could use a twin stick setup, and then you'd only need movement in one dimension
EJ25D block swap to EJ257 block
Yea, depending on the condition and seller, even 1300 isn't really an awesome deal. The 2.2 is definitely an option. There are a ton of different combinations that are possible for that combo. You could use your 2.5 heads/intake, which would simplify the wiring (a slight drop in compression, so a bit less power than the stock 2.2, but not much). Or use most of the 2.2 like you mentioned. You can either drill and tap the engine block, tap threads in the transmission bellhousing so it's like the 4-bolt transmissions (with a stud in the transmission for that lower starter mount), or even just run one bolt on the starter. I don't think this is an issue. I know that a Legacy EJ25D ECU (like yours) will plug in, and run, a '96 EJ22 in an impreza with no mods. And I don't think the sensors are different between the '95 impreza 2.2 and the '96 (the pinout at the ECU was different for the '95, but as far as I know, that's the end of the difference).
Voltage Spikes/Drops after EJ Swap
History on the engine? Do you know you have a good alternator? What model/year did it all come out of, as the wiring of the alternator changed many times over the length of the EJ production. need more background info
a 2006 WRX would have an EJ255, only the STi had the 257. The only difference in the shortblock is the pistons though. Either way, these are turbo motors. Which means the compression ratio will be lowered substantially. So you'll loose a bunch of power and torque. Mechanically it would work, and it'll be drivable, but not ideal. Honestly, unless you plan to turbo it, I would look for something else. If the motor you're looking at (be it a 255 or 257) is a great deal, you could probably flip it for a decent profit, as they have more than a little value. And grab a non-turbo 2.5 shortblock (25D, 251, 253, would all work fine).
Rear suspension rotted out
I've heard of that piece breaking before. I've also replaced it. Not for the same reason, for a 4WD conversion, but similar project. I'm assuming this is a FWD car? When you mention jacking from the crossmember, I assume there isn't a rear diff there. If that's the case, this won't be too bad of a project. One bolt on either side to disconnect the shock from the trailing arm. Disconnect the brake line. A bolt on the back side of the crossmember on the passenger side that clamps the fuel line down (don't forget this one!). And then 4 bolts per-side actually hold that crossmember to the body. Now, separating the trailing arms from the crossmember can be challenging. The bolts that the trailing arms pivot on tend to be very tight, very difficult to access on the car. The outer bolt has a captive nut, so it's a bit easier on the car. The inner one has a loose nut on the back side, so you'll have to use 2 wrenches, in which case, off the car works pretty well. Rust on these bolts can be a problem. I've disassembled a few of them, and had them fight me, even had 2 break (see the first 4 pictures below). If the bolt is seized into the bushing, you'll have a project on your hands. If the outer bolt gives you trouble, there are 3 bolts between that outer piece of the arm and the rest of the trailing arm, but beware, this is where the alignment is adjusted. You say you have parts to replace it. If you can leave the crossmember and trailing arms as an assembly, I wouldn't hesitate to swap things over. If you need to swap your trailing arms over, I would give it some thought, and give the car a major inspection before doing the work. If it's 4WD. You'll have to drop the rear diff too. At which point, you'll have some extra work to do. The axles are probably the only thing that'll give you trouble there. 4 bolts at the driveshaft, 1 bolt for the front hanger, and 2 to the rear hanger. Then pop a spring pin, and separate the axle from one end or the other (I'd pull them out with the diff). Here's some pictures of EA82 rear suspension assemblies that Ive taken over the years. These are all 4WD, and a few are turbo (sway bar mounts).
The Official Camber Plate Thread
Camber plates: Replaces the strut top. EJ tops will work in an EA82 car by slightly opening up the 3 holes in the strut towers. Stock EJ strut on my '89 XT6. You can see how close the bolt pattern is. 5-lug swap will allow camber adjustment at the knuckle, plenty to solve that dreadful EA82 handling. Camber plates AND a 5-lug swap really only necessary for dedicated track use.
