112
Everything posted by Numbchux
If it's the cast aluminum cover, with the philips-head screws, I might not mess with it. I've had the aluminum get brittle around the bolt holes, and the force of getting those loose (usually with an impact driver) will break it. If it's the stamped steel one, with the allen bolts, I would definitely pull it apart and reseal. Meh, the throwout clips may not be necessary, but they're cheap enough (30539AA000, MSRP $2.58 each). Definitely inspect the clutch fork around the pivot. I have seen them fatigue and crack/break. Make sure the pivot ball isn't scored, and smear some grease on there at the very least, if not replace the whole thing.
Easy answer. Pinion shaft and center diff have to match. Locking non-LSD center only came with a 3.7 or 3.9 (in the US for sure, but I think that's true for the rest of the world). The rest of the details depend on the rest of your details. If you're serious, start a new thread with some background information, and we can try to help you.
I just assume that EA82s like to eat timing belts. I had 3 or 4 of them that I put a lot of miles on, and I never went anywhere without spare belts, pullies, and the tools to do them.
My dad had a '94 Legacy with some finicky synchros in second gear when we bought it. It would usually stick out of second gear, but one day I went for a hard 1-2 (what can I say....I was 19), and it wouldn't come out of second. Per the recommendation of one of the folks at CCR Engines posted here, I changed the gear oil, and added a quart of Rislone Engine Treatment (yep, you heard that right), and drove the car around the block (country block, it was a few miles total), by the time I got home, I could shift it again. About a year later, we changed the fluid to "Uncle Scotty's Cocktail", and then several months later, again to straight gear oil. That car never had shifting problems again, but about 100k miles later (at almost 250k), a transmission bearing seized. I wish I had pulled that trans apart...
I have seen several internally-failed head gaskets mitigated for quite some time with the original Blue Devil product (nothing else, and not the "pour and go"). I admit, none were on a Subaru, and only one of them was a car/owner I was in contact with for more than a few months (that one was an MR2 which was beat like the proverbial red-headed stepchild for years). But internal failure (overheating and such) is exactly what it is designed to combat. Just make sure you do it correctly, it's a fairly in-depth procedure. If the car is that nice, though, you really should fix it correctly.
- 38 replies
My website, anyone still use it?
Numbchux replied to Numbchux's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It's official, I just changed it to not renew. So it'll be done on or after December 5th -
Wouldn't hurt to test the rad cap, but I doubt it. I know that our local AutoZone loans the block tester tool for a down payment, and you just have to buy the fluid. Ditto with a pressure tester.
- 38 replies
Head gaskets on those are typically internal, so air pressure from the engine gets pushed into the coolant. The air in place of the coolant cannot be pumped by a water pump, so the engine gets hot, but doesn't circulate that heat to the radiator and heater core. Engine basically has to come out to do head gaskets on that one. Getting the heads off a SOHC car isn't too bad in the car, but on a DOHC, the cams have to come out to get at the head bolts... I have heard of cases where the steel impeller in the water pump can rust away, and with the condition of the coolant in yours it's possible that that may have happened, but as mentioned, even if that's the cause, it's probably ruined the head gaskets by now. If it were me, I would probably pull the engine, and plan on doing head gaskets, timing belt, oil separator plate, thermostat, and inspect the water pump. Flush the heater core and radiator, possibly replace the radiator depending on it's condition. If you want to try to see if you can get away with less, start with flushing the heater core and radiator, pull the thermostat and look up in the water pump housing (I'm not sure if you'll be able to see the impeller without pulling the pump, but through the thermostat hole, you might be able to get an idea of what kind of sludge is living in there). Then use a new thermostat, and put new antifreeze in, making sure the system is adequately burped and see how things are. If it does overheat, you can chemically test the coolant system for combustion gases, fantastic informational/how-to video on that process: If you're looking for a cheap band-aid, Blue devil makes a decent mechanic-in-a-bottle for head gaskets. Here's the same guy testing that product: Dig through the comments on that second video, and the poster follows up several times, that the head gasket issue did eventually come back, but he managed to buy a couple more years of use out of the car.
- 38 replies
"need" It's definitely calibrated differently, and it's definitely the correct way to do it. But I've done it many times without and almost never noticed an issue (one time on a fast autocross course it felt like the rears locked before the fronts in my FrankenWagon and the car tried to get away from me, but that was with R compound racing tires, so there was a lot more weight transfer than ever intended).
I'd bet cash money it's head gaskets. Do you get heat coming out of the vents? Radiator get hot? Hoses? It's possible that the coolant was so bad from lack of use (average of about 4500 miles a year) that the water pump impeller rusted out, and the complete lack of circulation is causing the coolant in the block to get hot and expand.
- 38 replies
- 1
Tips / tools for removing RX LSD?
Numbchux replied to JLow03's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You'll need a 12mm wrench to separate the driveshaft from the pinion flange. No room for a socket on these bolts. The Ujoint yoke should bottom out against one side of the hex on one side, so theoretically you can remove them with just a tool on the other side, but you may want a second 12mm if things are rusty. IIRC 19mm and 14mm for the bolt and nut respectively, that hold the front hanger to the crossmember. And then 14? for the 2 rear studs. 3/16" punch and hammer to pound the roll pins that hold the axles to the stubs on the diff. But, if it were me, I probably wouldn't bother removing the axles from the stubs in a junkyard. I'd disassemble the axles and leave the inner DOJ cups on the diff. Slice the boot all the way around, or the larger clamp on the DOJ cup. Then pop the circlip out of the groove in the inside of the DOJ cup. I did a write-up on a front CV rebuild, and took a couple good pictures of that circlip: [DSCF0672 by Numbchux, on Flickr Once that clip is out of there, the axle joint will come apart as you lower the diff out, and you can worry about separating the axle cup from the diff later (if they're particularly tough, there's a cap in the bottom of the axle cup that can be removed, and then you can access the E10 torx bolt that holds the stub into the diff, and then you can really apply some force). -
Do you want to run fuel injection? All Subarus since 1988 are Fuel injected (in the US), so you'll need the ECU and most of the wiring from the donor car (which should be gone through and removed the unnecessary stuff). The early EJ22s can be converted to carb. Stay away from the EA82/ER27s. Neither will give you the power you want. They are not simpler than the newer stuff, and parts are much harder to come by. My recommendation would be an EG33 or early (2001-2004) EZ30. EJ22 is a fantastically simple and reliable engine, but you probably won't get 160hp without sacrificing the reliability. The EJ25s (either DOHC or SOHC) are rated for that kind of power, but high maintenance. And typical junkyard prices for known-good ones are pretty rediculous ($1500+). There are a couple recipes for high compression engines, some using a mix of stock parts, and of course aftermarket. That may be worth looking into depending on your specific situation, but involves considerably more research, sometimes buying multiple engines, etc. I've seen many excellent engine donor Subaru SVXs go for $500 or so. EZ30 donors (an option on 2001-2004 Outbacks) are a little less common, but they exist, and typically the parts you wouldn't be using are much easier to sell to recoup the costs (I bought my crashed fully-loaded 2004 for $1700, and only needed about $700 in parts to fix). Externally, the EG33 is about 6 or 8" longer than an EJ 4-cylinder, whereas the EZ is only about an inch bigger. These are both fantastically reliable engines, they are more of a pain to work on in the car engine bay since they're kind of shoe-horned in there, but that all changes in a boat. They both make about 220hp, so considerably more than you were looking for.
About the same as a 4WD. The hubs, and maybe the backing plates, are unique to FWD, so it's best to have a FWD donor car. If you want the sway bar, you'll need the whole suspension arm. You could actually grab the whole trailing arm, bearing and brake assembly from a 4WD car. But then you'd need the 4WD shock.
It would help to know what car you have.... But on almost all cars with the cold weather package, they got heated seats, mirrors, and windshield. As mentioned, it is not the whole windshield that is heated, just a strip under where the wipers park. It is absolutely possible that the windshield was replaced with one without the heating element. I had a 99 Outback SUS that fit that description. On newer cars (my mom's 2012 Impreza Premium for sure), the heated windshield is present, but does not have a separate switch, it is activated with the rear window defrost system.
+1 Generally speaking, excellent engines. Head gasket problems are not unheard-of, but don't seem common to me. Worth taking on a longer test drive though. Make sure you get the car up to temperature and speed. I think it boils down to this, they don't fail as often, but working on them is harder and generally more expensive. I think it's worth it, I love our '04 VDC.
Musing a full '93-'99MY Impreza to EJ251/EJ253 conversion
Numbchux replied to janas19's topic in Subaru Retrofitting
To clarify. EJ25D in an Impreza/Forester chassis was 1998 only, 1996-99 in the Legacy. EJ251s started in 1999 in the Imprezas and Foresters, and 2000 in the Legacies. And went through mid-year 2005. I know that all 1995-1999 Legacies use the same ECU connector (although 1995 was pinned differently). I know the EJ22 Imprezas through '99 were the same, I do not know about the 2.5 cars. Manual transmission stuff is easy. If it doesn't plug-in, splice the connectors, it's only a handful of wires. Starter interlock is on the clutch pedal for a manual. Only thing to be aware of, is as of about 1995-96, they switched from a cable speedometer to electric. If you're running an electric speedo cluster with a transmission that was originally a cable, you can un-thread the cable from the transmission case, and thread in a sensor from a late-'90s car. Off the top of my head, I think they are 3 wire, 12v+, ground, and signal, so you'll want to grab the connector from a yard or your donor car. -
You said you'd be using a '99-'02 RS harness. Those are EJ251 cars. -
FYI, your car originally came with either a 340 or 356 CCA battery. We don't have too much trouble with those up here (Duluth, MN) unless you're using a remote start system on the car. So it may be fine, but that's probably going to be your weak link. The Subaru replacement batteries that you'd get through a dealer are 590 CCA, and most aftermarket batteries for it would be similar. There are a myriad of little lithium-ion jump boxes available now for $50-$100. These could be a life saver, much like having a spare battery, but very easy to leave plugged in and keep charged. As mentioned, the 0W20 that's in it is fine for cold weather. The car will offer little more protection than a tent for camping. I don't recommend sleeping in it for long periods of time.
Something wrong with your other thread on the same subject? -
Phase II EJ251 into 95-98 Legacy questions
Sort of... After engine #2213362 (manufacture date sometime in 03/98, which would primarily be '99s, maybe a few '98s), the OE catalog shows the #5 thrust bearing. The '99 SUS I had, definitely had a phase 2 style timing belt tensioner. But, all '97+ 25Ds show the same part number for pistons and all 25Ds with the same head gaskets. Which is why the compression isn't higher. -
Good luck! Most junkyards, up here anyway, want more like $1500-2k for a good one. There are exceptions, of course, and other sources, but that would be a steal. -
I disagree with this. The EJ251s are not very robust. The DOHC heads are extremely tough, almost impossible to warp. As much as I do prefer the phase 2 bottom end, the DOHC heads are WAY better than the SOHC. Timing belt cost difference is about $20 (we get Gates kits on Amazon, that's my source). Meh. That's a drop in the bucket when you're talking about an engine swap. Yes, cams would be more expensive when there are 4 of them, but the DOHC heads flow much better than the SOHC, so you'd probably end up with more power. At the end of the day, I go out of my way to avoid either engine. I have owned several examples of them, but my current Subarus are either H6's (XT6 and '04 OBK VDC), or EJ22e's ('97 Legacy and swap-in-progress Brat). -
It's weird, as in, uncommon. Don't think I'm not familiar with the "bigger engines into lighter vehicles" concept. I've been involved in probably a dozen EG33 swaps into '90s Imprezas and Legacies. Not to mention EJ22s into EA82s. And a handful of EJ22s into VWs, and a few WRX swaps. When I'm bored and want to wish I had stupid amounts of disposable income, I research 2GR (3.5l VVT All-aluminum 290-some-hp V6) swaps, and dream of putting one in my Celica. Or a 1UZ into an older Celica. Or a 1MZ engine with Rav4 5-speed transmission in an AWD Pontiac Vibe Each to their own, and I'll certainly offer the knowledge I have that might help make it happen. But it just seems like a lot of work/money for a mediocre engine. The EJ25D is a much simpler option, for the same power. Typically people try to go for more power, or at least more reliability. EG33 or pre-VVT EZ30 would be a much better option. Or building a high-compression 4-cylinder (several recipes for that, some with a mix of OE parts, some with aftermarket). -
Weird. So you're looking to buy a 2.2 car, specifically to swap a 251 into? I think these cases are almost always someone that happens to have a 251 and a phase 1 car that needs an engine. Up here, at least, a good 251 is worth more than a running-driving 2.2 car. FYI, a '95 2.2 ECU is pinned differently, a 25D or '96-'99 22E ECU will plug in, but will not run.
