13
Everything posted by Mike104
Could be a blocked heater core that is preventing the thermostat from opening. Try taking the hoses off the heater core and connecting them with a pipe fitting. Then run the car. The heater circuit feeds the back side of the thermostat letting it open. No flow to back side and thermostat won't open.
- 41 replies
- thermostat
- sensor
(and 8 more)
Tagged with:
The P0335 and not starting issue are not related. Edit. The P0335 code is a symptom not the cause. GD explains it well in a later post. The point I was trying to make is that the P0335 code was not the problem and was not causing your no crank issue. Having experienced this issue myself (and replacing a number of parts) I stumbled upon the relay mod and once installed addressed the intermittent no crank issue. Need to use a large enough wire (12 Ga) and a fuse from the battery post for safety.
If starter clicks but doesn't spin common issue is contacts in the solenoid. http://beergarage.com/subystarter.aspx I had to do the start signal bypass relay mod on my 99 to get it to start consistently. http://www.subaru-svx.net/forum/showpost.php?p=602710&postcount=4 Could also be the start inhibit relay if your car is equipped with one. Crankshaft Position Sensor resistance range is between 1 and 4 kΩ?
Bearing quality and installation technique probably have more impact on bearing life than the grease. Although since some Foresters seem to have more failures on the right rear bearing I did clean and repack that bearing with Lucas Red and Tacky, I don't know if that will have any effect but didn't think it would hurt anything. I have only changed a handful of bearings on Subaru's so GD's experience with changing hundreds is certainly more valid.
Timing Belt
Mike104 replied to mikec03's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Another option is to buy items separately (NTN, Koyo, NSK) are all good Japanese components. Misuboshi belt is good too.
