Everything posted by Mike104
ABS test won't make ABS light flash a code 1996 Impreza Outback AWD
Mike104 replied to navyhoosier's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBetter than hitting a moose!
"Ghost Walking"
Mike104 replied to ShawnW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had a similar issue on an 03 Forester the back end would move typically when I shifted gears. Eventually I found that the lateral link bolt had worn the hole in the wheel knuckle so that the wheel was free to move back and forth. Took a while to find it. The metal piece where the bolt goes through was oblong. This is a picture of a new lateral link bolt with after market lateral links but the wheel knuckle is the same.
How Do You Decode Transmission Numbers?
Mike104 replied to Camaro98's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAccording to parts.subaru.com that transmission number crosses to Subaru Part Number31000AD890 https://parts.subaru.com/a/Subaru__Forester-S-25L-AT/49239512__6021990/AT--TRANSMISSION-ASSEMBLY/S10-150-01.html It's used on Forester 1999, 2000 and 2001 https://parts.subaru.com/p/AUTOMATIC-TRANSMISSION-ASSEMBLY-TZ1A3ZC2AA/49239512/31000AD890.html you could check opposedforces.com to see if they give the Final Drive Ratio (I can't access it using company firewall). It may work on other vehicles but I don't have that information
coolant not returning from overflow.
Mike104 replied to whynot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAlso make sure the end of the overflow hose is cut at a 45 degree angle so it doesn't get sucked down to the bottom of the tank Rad cap likely suspect, make sure it's a Subaru one. Could also be a leaking connection of the hose at the radiator (I usually put a tyrap on the hose to make sure it doesn't loose vacuum.
2001 Outback H6 rpair manual
Mike104 replied to resaw's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdid you look here https://sl-i.net/FORUM/showthread.php?18087-Subaru-Factory-Service-Manuals-https://sl-i.net/FORUM/showthread.php?18087-Subaru-Factory-Service-Manuals-
1996 EJ22 MAF problem?
Mike104 replied to Ravenwoods's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOnly adjustment procedure in the FSM uses the Subaru Select Monitor. This is from the 99 Legacy Manual so hopefully it's the same. You can get an FSM for your year/model here https://sl-i.net/FORUM/showthread.php?18087-Subaru-Factory-Service-Manuals- MSA5TCD99L97.pdf
RPM Jump with heat on
Mike104 replied to Dyna's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe more I hear about the new vehicles, I am enjoying my 03 Forester with 5MT and 99 OBW with 4EAT
99 Outback. AT oil temp flashing. Please Help!
Mike104 replied to Nick6's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI expect with a 99 and the known issue of the intermittent speedometer the speedo/odometer has likely been changed
2002 Baja/Legacy Side vent fix
Mike104 replied to turbofiat124's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI know on my 03 Forester those vents just snap out. I use a plastic pry tool (Harbor Freight special) You can go here and download a shop manual for your car and verify if it shows how to get them out. https://sl-i.net/FORUM/showthread.php?18087-Subaru-Factory-Service-Manuals-
Inline Thermostat Mod
Mike104 replied to db*****'s topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFill the block first, thru the upper rad hose I have only worked on 4 Subaru's and I find that this method works for me. I know that the Subaru mech's at my local dealer use a special funnel but filling the block through the upper rad hose has always worked for me
08-09 Legacy and Outback hoods
Mike104 replied to iriejedi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGo to car-parts.com and check for interchangeable or go to parts.subaru.com and use the Where Used Tab to see if they are interchangeable
Engine mating up to trans, axle problems
Mike104 replied to 89Ru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX+1 on the HF Earthquake cordless impact, at least for us backyard DIY guys. Not sure if it would hold up to everyday use, but for the few times I need it, saves me lots of effort.
Gear Ratio Question
Mike104 replied to Mike104's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm OK with my 21 year old kid only doing 60 mph!
Timing Belt 1996 DOHC
Mike104 replied to YOWZA's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can get a specific FSM from here https://sl-i.net/FORUM/showthread.php?18087-Subaru-Factory-Service-Manuals-
Mike104 replied to YOWZA's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXStick to an Aisin kit or buy the individual parts from a known good Japanese vendor (NTK, Koyo NSF). Mitsuboshi Timing Belt. The crap made by other providers often have Chinese made bearings and they have been reported to fail earlier. Hash marks will be evident once you remove the timing belt cover and use a good light. The image below is from a SOHC 2.2L. The DOHC has different marks so verify if you have the EJ22 or EJ25 These are from the EJ25 DOHC
EJ25 overheating after rebuild
Mike104 replied to 98GT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTo make the above comment more obvious
Gear Ratio Question
Mike104 replied to Mike104's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks GD I knew you would know the answer!
Gear Ratio Question
I know that the transmission and rear differential must have same gear ratio to work properly. Car in question is an 08 Impreza WRX with 5MT. According to cars101.com this was supplied with a 3.90 gear ratio. Current ebay sellers are offering JDM transmissions with matching 4.44 rear differential. Question is what would be the difference in operation if the MT/Rear Diff with a 3.90 was replaced with a MT/Rear Diff with a 4.44 ratio?
Radio
Mike104 replied to opus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOP needs to change his Avatar
Radio
Mike104 replied to opus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHere is the pin out http://ae64.com/20-pin-pinout.htmhttp://ae64.com/20-pin-pinout.htm
Coolant leak coming from water pump? 2004 Forester
Mike104 replied to darsdoug's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX11044AA642 and 770 are the preferred MLS Turbo gasket for SOHC EJ25 engines
How does one adjust the Throttle Position Sensor
Mike104 replied to Ravenwoods's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI just answered his question. By the pants method could take just as long or longer. Either way do it the way you want.
Mike104 replied to Ravenwoods's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think its either on the passenger foot well or under the dash.
Mike104 replied to Ravenwoods's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPage 3 shows how to adjust the TPS. Remove ECU and check for voltage with the throttle closed (Connector & terminal / Specified voltage (B136) No. 15 — (B136) No. 17 / 0.45 — 0.55 V [Fully closed.] From my 99 FSM but should be similar. But check to make sure the adjustment procedure chosen is for your engine/California emissions etc. You can get an FSM for your vehicle here https://sl-i.net/FORUM/showthread.php?18087-Subaru-Factory-Service-Manuals- MSA5TCD99L94.pdf
2006 Tribeca HEAD GASKET JOB
Mike104 replied to subarusaver's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGo here for manuals https://sl-i.net/FORUM/showthread.php?18087-Subaru-Factory-Service-Manuals-
