Everything posted by GLCraig
missing brake part on 74 1400 dl
GLCraig replied to kiwi subbie's topic in Historic Subaru Forum: 50's thru 70's
I think that part is the same for all Subarus with manually adjusted rear drum brakes. -
Snow rallycross in Spokane this weekend
GLCraig replied to edrach's topic in Meet n' Greet. Your USMB Welcome Center
Quit trying to tempt me into going next time. -
Snow over tarmac race - Spokane Sat/Sun
GLCraig replied to dirtydrifter's topic in Meet n' Greet. Your USMB Welcome Center
looks like fun but 6.5 hours of driving each way is a bit much for a rallyx is a bit much this time of year. -
new project for Suberdave
GLCraig replied to suberdave's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It's probably out of your budget but a turbo EZ30 in a XT6 along with a 6-speed and DDC would be quite the project. -
From what I remember reading about the chevelle shock, you need to drill the holes out and rotate the top mount in the bushing. I don't think you can simply re drill holes either. Behind the stock holes there are a couple of weld nuts that you would need to account for if you re drill and I don't think you can get behind that piece of sheet metal with new nuts. Also didn't someone come across a Ranch shock for the Jeep TJ that will work?
Subiefest Rally X thread. Got pix or stories?
GLCraig replied to ezapar's topic in Meet n' Greet. Your USMB Welcome Center
The only mod is an accell coil and I've been using it all season. -
There were a couple of AutoXs there in a 84 wagon that they picked up just before the event. Also my 7th run time is not posted for some reason. I had a 1:23.35 on that run. -
They don't even have all of my runs listed. -
The relays should be mounted next to the fuse box, under the dash and to the Right.
I'm planning on leaving PDX around 7 a.m. which should get me there around 9:30 a.m. If the class shop gets the leak in the GL's new windshield fixed; I'm bringing it and I plan on some RallyX fun. If I end up driving the Legacy I'll probably settle for some right seat fun and help out. Oh I'm not too sure which way would be faster, taking I-5 to Hwy-18 or taking I-5 to Hwy-512 to Hwy-167 then to Hwy-18?
Download the Rally America rule book and read through the section on roll cages. This should give you some good Ideas on what you can do with your hatch.
If water is pumping out of the PVC hoses then it's also being pumped right through the oil return passages and into the oil pan.
Last PRG rallycross of 2006---Oct. 15th.
I emailed Paul Eklund aobut the RallyX at Subiefest. Tech starts at 8:45 and first car out will be about 9:30. -
Mark your calendars: SubieFest 06
GLCraig replied to ricochet's topic in Meet n' Greet. Your USMB Welcome Center
I may come up for the rallyX then head back on Saturday. -
87 GL-10s did not come with ABS
SEMA Las Vegas All Subaru Events
GLCraig replied to YUJI's topic in Meet n' Greet. Your USMB Welcome Center
Too many things to do, not enough vacation time available. -
The 4wd is engage by a syncro just like the rest of the gears. The only prolonged problem I see would be premature wear of the rear main-shaft bearing due to uneven loading. The Datsun 510 and 240z use the same rear diff without any problems.
