Everything posted by GLCraig
Hitch Wiring Question
GLCraig replied to hohieu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi haven't noticed any moisture but you could always seal the whole in the gromet with a little silicon
GLCraig replied to hohieu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen I wired up my legacy I cut a whole in the gromet the sits in the bottom of the spare tire carrier and ran the wires through it. Your forester my have a gromet in that area too.
Suspension travel is much improved(daylight pics)
So what's like when you take a clover leaf freeway ramp in it?
A new look for my Legacy (warning to 56k people big picture)
GLCraig replied to GLCraig's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXno limit on the bandwidth usage to the best of my knowlege but I am limited to nly 25MB of online storage.
New 2.5 Head Gasket theory?!
GLCraig replied to SubeeTed's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAbout a year and a half ago i was having a conversation with one of the mechanics that I worked with at a Subaru only Shop. At the time he was doing a HG job on a EJ25 phase 1. He told me that the gaskets he was putting in were the second redesign that he's seen in the gaskets that SOA sells. About a month ago we were talking again about headgaskets and he was telling me that basically none of the Subarus that he'd did a headgasket job with those gaskets have come back in with blown headgaskets. So maybe SOA has fixxed the problem, but it'll probably take another year or two to know for sure.
I finally got My WRX wheels mounted on my Legacy. The Tires are Toyo Proxes 4s and their size is 205/55/16. What a difference compaired to the cheap 14s I had on there.
I would like to get a FSM, where?
Your best bet is Ebay or a good used book store like Powel's
XT6 Power Steering not working.....help!
If i remember right there is a XT6 message board out there. you might want to try looking it up ans asking your questions there.
1.8L Ignition timing? - PLEASE Help!
hey that's what the FSM says
Rear Diff seals maybe wrong part?
Looks like they just gave you a generic seal,
Okay here it goes Carbureted 8 degs SPFI 20 degs MPFI 6 degs MPFI Turbo 25 degs Oh did you get a long block with the same compression ratio because carb and SPFI use different CRs
4 spd 4wd tranny disassembly
To get the transfer case off you need to 1. Take off the inspection cover and remove the 4wd shift fork, this part can be really tricky so be careful. This should allow you to get the tail housing off. 2. with the tail housing away you will need to remove the locknut that holds the 4wd, drive gear to the main output shaft of the transmission. On EA81 and EA82 transmissions this requires a very thin wall socket, Subaru sell one but usually people buy a regular 6 point socket and either grind it down of turn it on a lathe. 3. once you get that gear off, the transfer case should come off.
WCSS6 headcount
I'll be there, an friend of mine who's not on the board will be there too.
Organ Donor
It can be done that way but it still will be heavy. you would want a few helpers to lift it or maybe a fork lift.
swapping pully system
I would hold off on all of the pulley swappin until you know for sure that you can't read the marks on the flywheel with the different intake. One possible stumbling point could be with the A/C compressor. I'm pretty sure that XT's only came with the Hitachi A/C system. If your GL has one of the Panasonic systems or Nippondenso system, you may not be able to find a compressor or compressor pulley that will work with the different belts. The power steering and water pump pulleys should swap, I’m not sure if you can swap the alternator pulley hand have the correct alignment.
sharp turns in 4WD
You could find a S/R or D/R Full time 4wd tranny.
Roll call for Seattle RallyX this SUNDAY ((RESULTS are up))
Yeah that track did deteriorate quickly; i'm lucky that production got to run first. By my last run, the course was trashed. I hit a couple of ruts that just tossed my back end around and i had t back off on the gas. Atleast back in February the ground was moist enough that things didn't get bad until the afternoon. And what was up with the water truck, They only sprayed enough down to settle the dust for 2 or 3 cars.
EA81 tranny Qs
they will bolt up but it still requires the right combination of flywheel, clutch disk and pressure plate to work.
just a simple reminder, don't forget your skid plate(s)
Sealed Beam In 86 Wagon?
The only sealed beams for an 86 wagon are for the quad setup that came with the DL models
EA81 tranny Qs
The only ea81s that came with a 5 speed were 2wd. All of the 4wd models were 4 speeds. Most of those were dual range. Some people here have done the swap from D/R 4 speed to D/R 5 speed. Now Going from an automatic 4wd to D/R 4 speed has been done too. So it's fair to say that going from 4wd automatic to D/R 5 speed could probably be done too.
Dead Horn
Try testing the horn itself, they do go bad
i'll try to be there. Production is running morning session right? So I'll have to leave my place at about 5:00 a.m.
Incredible! Official results are up for yesterday's rallycross; pics too.
Okay I made my pictures smaller so there are now in my album, I would also like to thank superrallyroo for taking pictures while i was making my laps. http://www.ultimatesubaru.org/photos/showgallery.php?cat=546 if anyone wants me to email them larger pictures please let me know which ones you want and what size. they were taken at 1280x960 so that size or smaller would be best.
Portland, OR Mechanics??
GLCraig replied to Travelinandy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI use to work at a place in oregon city called Mt. Tech. the owner and head mechanic both have over 25 years of subaru only experience
