Everything posted by GLCraig
bogging acceleration after adding weber
it sounds like you just need to do some tuning. The weber experts will be able to point you in the right direction.
What is this exhaust thing on my EA-81??
that's a part of your air injection system for emission control and yes it should be there. In fact there should be one on each head for 84 and later EA81s with 4wd.
Southern Oregon Campout/4x4 run
I drove by that park a couple of times when I was going to OIT. Too bad there's a rally cross that same weekend.
Clutches?
All of the 2wd EA82s have the same SOA part number, for the clutch kit, the last time I checked.
OK. Let's talk about this picture.
I have no plans for the weekend. I could come up and take pics
oh, really??? http://usmb.net/gallery/album118/wcss5_11
Are those cutouts in the hood that I see?
why is there spark knock?
You may want to refer to this thread http://www.ultimatesubaru.org/forum/showthread.php?t=15208&page=2&pp=10
smoke out exhaust after adding transmission fluid
You are aware that the filter is nothing more then a wire mesh screen?
Horns on EA-81 vs EA-82
I just looked at my FSM. The other horn should be next to the Evap canister
The 2 horns should be right next to each other.
Which horn is not working, the high pitch one, the low pitch one or both? Are you getting +12v to them? Remember on and EA81 and maybe the EA82 too, the horn gets a constant +12v and they are grounded when you push the horn button. If your electrics are working correctly, then try adjusting the pitch screw before you go and replace the horn. The pitch screw is located on the back and has a lock nut. Loosen the locknut, turn the screw and then test the horn. also the horns should be the same or close enough between the EA81 and EA82.
piston sizing issue
Someone with an EA82 FSM is going to neet to answer that one for you.
The Modulator just unscrews from the transmission case.
It sounds like you have a bad vacuum module on the Transmission and what's happening is transmission fluid is being sucked into the intake. This is a fairly know problem but a simple fix. To make sure that the module is really the problem, pull the vacuum hose of the module which is located near the back of the transmission, on the right side above the pan. If fluid dips out then it's the module and you need to replace the.
Changes made, see other post by me.
I thought you had a Turbo Legacy? Which comes with a VLSD if I remember right.
Where is the thermostat on 1999 Forester?
GLCraig replied to jstnvndn's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's at the end of the lower Radiator hose.
Legacy turbo
GLCraig replied to legacy353's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXtry here www.rallitek.com but before bolting on more horse power you might want to improve your handling and braking first.
ngk bpr6es 11?
The BPR6ES is what Subaru's came with from the factory before NGK started producing the BPR6ES-11.
Central Oregon meet & greet May22nd***
I can't make it after all. I forgot about the 22nd being my dad's birthday
EA82 -Fuel tank & Alternator Q's
The lights comming is sometimes a loose ground wire for the instrument cluster. Check that firs before dropping the money on and Alt
Smells Bad
GLCraig replied to Slegacy96's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX:headbang: :headbang:
EA82T compression problem(before pic of head added)
What color paint is on the valve springs? Early EA82s would sometimes develope a lifter pump-up problem that would prevent the valves from fully closing. They switched to a heavier spring that was painted green one end. The early springs were painted red.
Smells Bad
GLCraig replied to Slegacy96's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck for a torn CV Boot
quick, what do I grab from an 83 wagon?!
Electrical items 1. Fuel pump control unit 2. Turn signal Flasher, 83 and later EA81 dose not use a generic unit. Whole sale at a dealer is still almost $100 for one. Most parts stores can't get them. 3. Blower motor, the resister packs aren't easy to find. 4. If it has A/C get the second radiator fan. 5. Relays and pigtails, A good stock pile of 22amp relays is nice to have. If the drivers seat is in good shape, grab it. Get the y-pipe too An extra hill holder is a good thing to have too.
