Everything posted by GLCraig
No Low RPM Vacuum, Problem Solved
GLCraig replied to Dr. RX's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Have you double checked the Cam timing? -
Need help with Installing Thermostat
GLCraig replied to lepetitprince's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Try truning the bolt back and forth, that will get it to free up most of the time -
You probably have a bad vacuum modulator on your transmission. When they go bad, they allow transmission fluid to be sucked into the engine's intake.
Did you make sure the float was set right when you put everything back together
IT PASSED!!! emissions...
GLCraig replied to SuperRallyRoo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Looking good. I do see that Washington let's you get away with a bit higher CO2 then Oregon Dose -
attn: anyone in portland OR!
GLCraig replied to subaru_styles's topic in Meet n' Greet. Your USMB Welcome Center
yeah around 82 is pretty bad, but my aunts live more in inner SE and it's not too bad. Outer SE around 122nd isn't bad either. The west side is a fair bit more expensive unless you live south of town like in Wilsonville -
Inexpencive parts for a 1988 Subaru Gl
GLCraig replied to danman9y's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i have only one thing to say. You get what you pay for -
More emissions problems
did you take it for a long enough of a dive to get the cat good and hot before taking the test? -
EA81 SPFI conversion and more horsepower/torque??
GLCraig replied to greggbrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
No -
EA82 seats in a brat??
GLCraig replied to Flowmastered87GL's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Since you have height adjustment it become more of a challenge since they mount to the seat rails completely then the non adjustable seats. -
with a press and bearing holder.
Running rich and need a fix
GLCraig replied to dave+Sub=trouble's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Well for starters, if you have a 84 4x4 you don't have an O2 sensor or any computer control unless it's got Cal emmisions. If you do have Cal. Emmisions then you should check for trouble codes and go from there. If you don't have Cal. emmisions then there is an idle mixture adjustment. Also check your float level. And when did you give it a tune up last -
RallyX results from 5/30 (update posted)
GLCraig replied to edrach's topic in Meet n' Greet. Your USMB Welcome Center
It looks like I didn't do too bad. 7th out of 13 in production and the #3 Subaru in that class. -
I had one of those fall out of an EA71 4wd tranny. After that I had to make a sharp left turn before it would go into 4th
so what happened to that turbo EA81
putting EJ22 into the 86 wagon
GLCraig replied to The Scooby's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You'll probably have to adapt your existing AC compressor to the EJ engine, because the compressor off of the EJ engine will likely be incompatible with the rest of your AC system. -
help me ID engine & tranny
GLCraig replied to on3letsgo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
your transmission appears to be the run of the mill ea82 d/r 5 speed -
A picture speaks a thousand words and would make it much easier for us to I.D. your parts. -
I've seen that a couple of times. Let me guess, it was the longer of the 2 cams, the one that drives the distributor.
URGENT! 1987 4WD GL Wgn. Disty questions
I think flowmaster needs to spend time in a gym and build up some mucles. All I had to do is pull straight up and the rotor slid right off.
