Everything posted by GLCraig
Well the axle is intended to be a light press fit through the bearings in the spindle. Some people tap on the joint to get it through. Some people will take the hub off the rotor and use stack of washers and the nut to pull it through. As for me and a couple of other , we'll us a puller that similar to the one made by Subaru. Here's a pic of mine.http://usmb.net/gallery/album117/tool
Saab-aroo
GLCraig replied to f15xxx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Here are a press releases about it http://www.fhi.co.jp/english/news/press/2004/04_03_15e.htm Aslo GM dosen't own 20% of Subaru they own 20% of Fuji Heavy Industries; the parent company of Subaru http://www.fhi.co.jp/english/news/press/1210news/12_10gm_news.htm -
RX Chassis+302/C6 combo and RWD.
GLCraig replied to WJM's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Well this Is what I would do different. Instead of a C6 I would go with a C4, the are smaller, lighter, and can be built to handle that much horsepower. For the rear diff, replace the R160 with a R200 from a 300ZX. You might blow one of them up but it would be an instant meltdown like it would be with a R160. Also don't be surprised if you end up twisting the Unibody even if you welded a ton of steel to the existing chasis. -
EA81 SPFI conversion and more horsepower/torque??
GLCraig replied to greggbrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
rguyver has done this swap already, but he isn't very active on this board. -
Central Oregon meet & greet May22nd***
GLCraig replied to subaru_styles's topic in Meet n' Greet. Your USMB Welcome Center
Bend's not that far of a trip, Maybe I'll show up -
Suggestions on rear brake adjustments
GLCraig replied to goatman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
what works pretty good for an adjuster tool is to take a 1/4in Drive 3/8 six point socket stick the square end over the adjuster and use a 3/8 allen wrench to turn the adjuster. -
About to start my disc conversion: help
GLCraig replied to Geck512's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I just check my FSM, it dosn't show a proportioning valve anywhere in the brake system. Another thing that everyone needs to keep in mind is that the brake circuits are not split front and rear. The split is Left front Right rear and Right front left rear. -
disty vac advance, on mpfi cars
GLCraig replied to archemitis's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Are you sure that both connections on the dist. cause it to advance? Typically the inner is for retard and the outer is for advance. -
Attn:SubieGal or someone who knows her
GLCraig replied to moosens's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I think Ratty2Austin still works with her at Carter Subaru in Seattle. You might want to send him an email or maybe even call up Carter in the morning and ask for her there. -
if your computer won't open it you probably need to install acrobat reader http://www.adobe.com/products/acrobat/readstep2.html
Working towards a flush
GLCraig replied to Adam N.D.J.'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
I think you have a straight going not a flush, unless all of your subs are the same color then it's a straight flush. Still that rocks -
GRR, how many times must I post this? Here's a link to my copy of the TSB. http://home.comcast.net/~c.moe/heads.pdf Also on Turbo heads, the crack to be worried about is the one that forms where the exhaust runners meet in the exhaust port. When the crack opens enough, it exposes a water jacket.
It sounds like the retainer ring that holds the guts of the DOJ in its cup failed, or maybe even it was never put in in the first place.
is there a gasket for the asv
GLCraig replied to subiemech85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I think you're confusing the EA81 with the EA82. The ASV tubes bold to the side of the heads on EA82s -
CEL in a 93 Loyale...?!?!?
GLCraig replied to Ryan1003's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Here's a good place to start http://usmb.net/repair/?CurrentDirectory=FOLDER_3f29b58f4430b8.49200047/&FileType=Article&File=ARTICLE_3f2c055f4862e9.39782181.art -
since that's a pretty small gasket, you might try going to the parts store and getting some exhaust gasket material and make your own gasket. -
Wife's Newer Vehicle (pics added)
GLCraig replied to richierich's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have a feeling that it's not an OBW but it could be a Legacy GT sedan. -
My local Subaru actually has a very experienced parts department, well at least 2 of the people do. Here's a link http://www.lithiasubaruoregoncity.com/index.cfm?action=parts
Richie, you didn't buy an Outback Sedan did you? -
brat seats/headroom vs topper... & axles
GLCraig replied to baccaruda's topic in Old Gen.: 80's GL/DL/XT/Loyales...
All of the high toppers i've seen sit level with the cab for about a foot before rising up. -
if it's a 5 hole then it's either a legacy, Impreza, or it's had a 5-lug swap using parts from an xt6. If it's a legacy or an impreza you'll need to find wheels with a 5x100mm pattern with the correct offset.
problems shifting while running
GLCraig replied to The Scooby's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Have you tried adjusting the clutch cable yet? Also inspect your tranny mounts and linkage.
