Everything posted by GLCraig
No Low RPM Vacuum, Problem Solved
Have you double checked the Cam timing?
Incredible! Official results are up for yesterday's rallycross; pics too.
I have my internet back and pics to share but my album is limited to 20MB and for this event alone I've got 35MB worth of picture after resising them
Need help with Installing Thermostat
Try truning the bolt back and forth, that will get it to free up most of the time
white smoke
You probably have a bad vacuum modulator on your transmission. When they go bad, they allow transmission fluid to be sucked into the engine's intake.
'78 Brat carb problems
Did you make sure the float was set right when you put everything back together
IT PASSED!!! emissions...
Looking good. I do see that Washington let's you get away with a bit higher CO2 then Oregon Dose
attn: anyone in portland OR!
yeah around 82 is pretty bad, but my aunts live more in inner SE and it's not too bad. Outer SE around 122nd isn't bad either. The west side is a fair bit more expensive unless you live south of town like in Wilsonville
Inexpencive parts for a 1988 Subaru Gl
i have only one thing to say. You get what you pay for
Where does one get paint for these old school cars?
No not maaco, Look in your yellow pages for a local store that sells autobody paint and supplies.
Just goto your local Autobody Paint shop and give them the paint code for your car. They should be able to supply you with more then enough for doing touch-ups. It won't be a perfect match to what's on your car but close enough for what you need.
More emissions problems
did you take it for a long enough of a dive to get the cat good and hot before taking the test?
Next RallyCross on June 27th, Hillsboro, OR. Volunteers needed
With luck I'll be there. Too bad my class is running in the afternoon when the track will be all torn up
EA81 SPFI conversion and more horsepower/torque??
No
EA82 seats in a brat??
Since you have height adjustment it become more of a challenge since they mount to the seat rails completely then the non adjustable seats.
CV axle help please ASAP
with a press and bearing holder.
Running rich and need a fix
Well for starters, if you have a 84 4x4 you don't have an O2 sensor or any computer control unless it's got Cal emmisions. If you do have Cal. Emmisions then you should check for trouble codes and go from there. If you don't have Cal. emmisions then there is an idle mixture adjustment. Also check your float level. And when did you give it a tune up last
RallyX results from 5/30 (update posted)
It looks like I didn't do too bad. 7th out of 13 in production and the #3 Subaru in that class.
how tough is your tranny ?
I had one of those fall out of an EA71 4wd tranny. After that I had to make a sharp left turn before it would go into 4th
Haha It Runs!!!
so what happened to that turbo EA81
putting EJ22 into the 86 wagon
You'll probably have to adapt your existing AC compressor to the EJ engine, because the compressor off of the EJ engine will likely be incompatible with the rest of your AC system.
help me ID engine & tranny
your transmission appears to be the run of the mill ea82 d/r 5 speed
A picture speaks a thousand words and would make it much easier for us to I.D. your parts.
Cam snaped in 1/2
I've seen that a couple of times. Let me guess, it was the longer of the 2 cams, the one that drives the distributor.
Head Gasket Failure or what? Can anyone explain this? *update - fixed*
A friend of mine had similar symptoms with his 84 hatch. It turned out that he had a crack in the block; in one of the water jackets that run next to a cylinder sleeve. The sleeve also rotated about 30 degrees and chewed-up the piston skirt. I hope your problem isn't as terminal.
URGENT! 1987 4WD GL Wgn. Disty questions
I think flowmaster needs to spend time in a gym and build up some mucles. All I had to do is pull straight up and the rotor slid right off.
