86subaru
Everything posted by 86subaru
well i almost got my dl d/r wagon running pretty good, except when the car is sitting running it surges , while driving it is fine , another problem is that the fuel gauge is off ,or i am getting 10 mpg , any suggestions ?
VALUE of a 5 SPEED TRANNY???
86subaru replied to Petersubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
125 around here depends also on milage , if you can find them , make sure you get the shift linkage, console -
Overpriced Parts? $500+ for a heater core
86subaru replied to NorthWet's topic in Old Gen.: 80's GL/DL/XT/Loyales...
here is 1 , i found an 87 d/r wagon needing a clutch , the owner says it will cost 800 bucks for the job , [ labor / parts] to fix it -
i have had tires blow out on me before , trailer or drives , sounds like a shoot gun, i few years back i had a younger guy fall asleep and side swap the drive tires and then, along the trailer ,and i was hauling hazard material [ glow in the dark stuff] , to be honest i was safer in my truck than in my car , his car blew out 1 of my trailer tires .
it is high, i am looking at a gl d/r 87 carb ,231,000mi for alot cheaper than that , some rust
2 types ,which one would be better ?
so would it be better it put it on the oil pan or top or bottom of the oil filter ? and where could you get them at ?how strong ?
Michigan, Ohio, Indiana Meet and Greet
86subaru replied to NoahDL88's topic in Meet n' Greet. Your USMB Welcome Center
email me and i will tell you what is going on , pwood@bright.net -
ok, just what the receipt said , thanks again
i know there is a way to read somewhere on the heads if they are gen 3? , he paid like 670 bucks for the pair , thanks
i have a set of turbo heads from a xt , it had a blown headgasket , so i have clue how the heads are , but only 40,000mi on them what are they worth ? thinking about selling them ?
buy a new 1 from napa about 50 bucks
another common place is the front of the timming belt , , oil pump seals, crank seals, just my ..2$
anyone use these ? any comments , ? do they work ? , they are pretty cheap on ebay
i use castrol dura blend, i put it a 86 fwd a/t spfi sedan , also a 88 turbo a/t full time 4wd wagon , and the 86 gets 1 mpg more ,and it runs better , the turbo's mpg is about the same but it also runs better , i change them every 6,000mi ,by the way eveyone is talking all oil is the same , well think what you want to think , in my opinion they are not
buy it and fix it up or sell parts off of it , any pics? how bads the rust ? interior? rear seats?
85 GL leaking coolent from somewhere
86subaru replied to mschafe's topic in Old Gen.: 80's GL/DL/XT/Loyales...
check the heater hoses , because they can leak on the bottom of the hoses and can be hard to see , right below the spare tire, 2 hoses -
well there could be a very bad oil leak, from the cam cover seals, leaking onto the exhaust or rear main, or 1/2 in hose underneith the turbo leaking coolant , look under oil cap, look in radiator , pull dipstick for water , if your going to buy it , also look at the drive axles, any past records , look for any rust , all depends on price
Timing belt/chain on EA-71
86subaru replied to Mattrav's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i to have done searches and have found nothing , and i am not a new member -
if i was closer i would come over and help
let me look at what i have ,i think i have 1
xt6 pulsating, and very low, to no idle
86subaru replied to archemitis's topic in Old Gen.: 80's GL/DL/XT/Loyales...
not to jack another post, my 88 dl d/r 5sp wagon does just the opposite , starts up good but will die 5sec later , after it warms up it , it will idle ok, ecu code coolant temp sensor , i replaced the coolant temp sensor , still does the same thing, new fuel filter. acell coil, ngk plugs , k-n filter, new cap, rotor , it is also a spfi motor
