Everything posted by ivans imports
Ideal carburettor for EJ25?
650 holly 4 barrel into a big turbo into intake have seen a ea82 na with 4 barrel rx7 carb worked well reved to 8500 was neat trick
- car smokes
The if we see the same problem on more than 4 cars thread
Thought this might be a good diagnostic thread if any techs see same problem on the same type of car post it here. If i come axross the problem on more than 4 cars will post it . This can be a good start Had 4 01- 03 outbacks five speeds all expanded center diffs. Fix was to install the awd center diff from 95-99 five speed. Is stronger awd unit. Heres one more had 4 97-99 imprezas with broken coged idler and bent valves fix 16 valves and coged idler /timing belt. Had 4 -8 99-03 outbacks with leading rear trailing arm front bushing hamered out fix press in new bushing. And so on the more imput the better
Its buggy time agian
Now it sits at home tarped and lonly waiting dreaming of a deep mud hole somwere or cruiseing on a beach. But no rest for the wicked got it some 33x1400 paddle bogers. Will put them on and see thats 2 inch more height right of the bat and biger foot print axles well there in for it. I had priced out geting crome molly rear axle shafts made 500 $ each just for the shafts wow was just to mutch so keep using the same old ones till I have non left. Anyone have any extra 80-84 rear axle shafts not cvs have lots of those a'm iso of any i can find
symptoms of dead or dying ecu / ecm - 1984 ea81t
The single most important wire on that harness is the small shielded one that gos to - side of coil this is tach signal to ecu tell it what to do
2003 Forester EJ251 Engine swap into a 2000 OBS
ivans imports replied to mrjim's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave been there man but its ushaly comeing from a shop on a tow truck we putt the motor in now it wont start but the old one ran !
I still have 2 of that ecu left
'77 2-door sedan parts needed
Have a extra grill for that one
Is the hood the same as 77 wagon ?
- uses fuel pumps
Buggy worked great thiss weekend got its 5 fastest passes ever pervius best time was a 5.07 set in 05 all are passes this weekend were under 5 seconds And matt pulled a 4.48 witch is the new record for buggy have been trying to beat 5 second barier for 12 years and we got it. Mind you everyone had fast times so we placed 4rth out of 5 but we were 100 % consistant and buggy never missed a beat. Heres the funny part I raced my 79 wagon in street has a 09 sti motor and 235-75 bfgs on it it pulled a 5.01 time In a 79 wagon with 5 speed droped the clutch at 7500 rpms and let here rip it was 4rth outa 31 trucks not to bad for its first race ever. Was good to end the season on a good note. Also did some tuff truck corse to in buggy was some hudge air and kinda rosted the crowd opps but buggy did good came in 3rd even with a DQ on first pass.
EA81 SPFI MAF details
Is it a hydro cam or a soilid cam engine ? soilid cam 80-83 hydro cam 84-89 ea81s you could take the valve covers off and check the lift height of valves with dial indacator make shure the lift is all the same on all valves. The mass air flow try making the inlet of senser a bitt smaller were it sizes down a plastic ring or cone it could be that the ea81 cant move enuff air to make it get into range a smaller inlet to mass will speed up the air putting ecu back into range
My 2001 H6 Outback engine started to overheat - should I repair it or send it to scrap?
ivans imports replied to jvopal's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo worrys a'm thinking if I have 3 broken ones they are hard to find good ones. I replaced a piston in one was over 200 bolts crazy engine to pull apart
overheating mystery
They sell a addjustabble temp switch for fan realys but the stock realys should run those fans
EJ22T after swap problems. Fuel cut at 3 to 5 lbs of boost.
When i a'm trying to tune a turbo car i set the wastegate in default setting by hooking the line striat up to housing this is to rule out any overboost problems or sensers that dont like to mutch boost is just to give you a consistant boost preshure to help diagnostics. I make shure its working 100% before i turn up boost
Subaru Coolant conditioner
ivans imports replied to igammie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnope makes a mess
ivans imports replied to jvopal's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAlso pull the center out of thermostat and try runing with out it blocking flow will make it so can at least move it around
ivans imports replied to jvopal's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave 3 parts 3.0 engines 4 good heads ect if you know what parts you need
Try removing the boost controler and hookup wastegate line direct to turbo and see how it works this should make 7 psi just to test.
Cracked oil pump causing milky tan oil?
Headgaskets or frost plug seeping
Baja with coolant in oil...need help!
ivans imports replied to mbrown1000's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXonly leak when they get hot or under load as they heat up the block and heads expand opening up any small leaks still think headgasket
How do i retard spark timing on an ej without reflashing the computer or going to megasquirt?
The engine is about 8.5 -1 comp ratio gessing the stock ej251 pulls 200psi comp test mine pulls 150 psi so 1/4 less than stock uses a sti turbo piston
Side marker lights won't go off
100 times a year fore me i get asked that ?
Newbie switch lol
The engine is a 2.51 with 2.5 turbo rods has reground cams but block height and head height is stock for ej2.51 but a.m unshure if the 2.2 mangment and 2.51 management is same distance between the cam / crank senser as the 2.2 so mabee is a difference there. Have tryed the 2.2 turbo mangment but was unreliabble and cut out at any boost over 8 psi and add nos total shutdown to mutch turbo ecu controls.
