Everything posted by subaru_styles
alternator charging oddities
subaru_styles replied to mcbrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
hey Mcbrat, when I bought my coupe it was doing the exact same thing.....1 week later the alternator took a crap on me. -
i got a used set of Bomz for a civic.
or you go to the junkyard and get some 2wd xt struts for $20:banana: and score coilovers off ebay for $8..*double:banana: * and yes im slamming the coupe. pics next week
when i get back to portland i'll email you the vin for the rx that went bye-bye...i saved the doorjam plaque off of it
theheadlights were probably were painted or had that film attached..take a pic and post them
DOH!!! i just moved back to bend for a month...and one of the few RX's has already been snached up.... let me know if you might end up selling it:brow:
ummmm i gave him directions to remove just the trim by his problem vent. he doesn't need to remove the dash.
well you do not have to take out the dash for this...under you steering wheel there will be 2 pieces of plastic panels( where the fuse panel is)..you should have access to the cable for the vent. if you need to get in deeper> the plastic arount the gauge cluster and the driver vent is all one piece.. screws are: behind the dummy plate near the rear drefost switch behind the buttons in th e heater control(defrost and off) behinf the hazzard and fan dial "in" the cluster hole under neath the top part there will be like 2 screws under neath the where the power mirror switch is if you look up from underneath you sill see them anyone add if im missing anything
Its back on ebay again...
subaru_styles replied to WJM's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It sold for $1,606 american dollars -
short shifter and better bushings in the rx
subaru_styles replied to subyrally's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i believe for the short shift you have to cut and re-wel the fulcrum(sp?) point higher up on the stick -
hey mike..i will be getting steering wheel adaptors for the EA82 come late december..if you need any tips with the rack, my whole system is yakima...
The Quest for rear E-brake...
subaru_styles replied to PoorManzImpreza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
so does anyone have a breakdown of exactly what years and models (nissan) this rear caliper will work.. -
Where to tee in for a boost gauge?
subaru_styles replied to DrKrazy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
if you look on the intake manifold there will be a couple "dummy" threaded holes that have a block off bolt wiht a square head on it....unscre it and screw in you fitting there.. i too have an autometer, and it's not bouncy -
awesome... i have AOL IM it's subaruRXwagon my email is subaru_styles@yahoo.com -
conections are fine...i don't have a multimeter to check values on any sensors
well after tinkering with the coupe I am only getting codes for EGR and purge (34 & 35) would a bad EGR Solenoid casue the compuer to think the purge solenoid was bad too, even if it was ok??...mostly what im geting at is.. should i replace hte EGR and see if i can get away just doing that?
well come the forst of the year when i have some more money i wouldn't mind dishing out the shipping to get theese parts: here's the EA82 "euro" List: headlights corner lights 15" bbs rims thoose bumpers i found another pic of a car with the rims <clik me> -
lukas...yae finally someone near it....hey i got a real big favor to ask you...can you find out what the deal is with the bumpers..if they were aftermarket(who makes them) or something from the factory..also how hard is it to find EA82's in junkyards...I wouyld love to get some euro-spec parts. -Brad -
hey dude long time no see...i'll be living in bend in dec. so will have to go rally it up since i have the coupe now
