Everything posted by subaru_styles
Collapsed suspension?
woah..have you taken off your hubcaps and removed the rim? take the rear brakes and see how much they wobble, check the mounting bolts on the rear swing arm. and that red thing is your bumpstop
incredibly high idle in the rx
check your coolant temp sensor
Anyone with an 87+ fsm, I got a quick Q
wait, i don't need to know?:-\ noah it should be in the 87, if not at least 88+. most of the gl-10's came with factory fogs. sad thing is right now all the FSM's i have are XT & XT6 ones
i need a pinout on an 87+ ea82 foglight switch.. i need to know: ground 12v illumination 12v in from headlights 12v out to relay/fogs many thanks
Northwest Washington Meet
sorry to hijack, but have you shipped the cargo cover yet???
my RX is sick
have you pulled codes yet? that would be a good start. just to make sure your temp sensor, purge selenoid, etc are all working properly. also get fresh gas
My RXTurbo says Goodbye
sorry to hear of another RX's demise..
EJ20g into GL10 Wagon almost done ~EDIT DONE~
nice dave!!! ..now there will be 2 wagons with ej20g's this year at wcss ..
RX or XT which is better
chuck, i left you a VM
upgraded replacement headlamp assembly for an RX?
i would recomend some some better 9004 bulbs (not blue ones) and alos add a relay for the headlights.. other than that the only other source would be to get some EDM headlights, they have a better glass/reflector pattern and use h4 bulbs..however i still havent been able to track down a set for my own:banghead:
underneath they're all swapable, same length..caboob is right, the xt is more areo dynamic, but i believe it is also heavier
EJ Tranny --> EA81
Noah....Are you saying you want to run the Awd trans behind the 2.2 in the Ea-81 car..? This is John ( aka ) mudrat79 at Brads House..on his computer If so it is very doable... Also, I can stick A custom set of 23 spline axle stubs into the AWD trans so you can run stock axles as well..... Call me on it I have a Trans at the house right now if you don't already have one....and if you do I can do the work to this one then just trade you out for tranny later...? Chat soon, John
Sexy flywheel pics
guess who drove today:grin: ?? cars is back on the road and holly ish! with the combination of new HG's and a re=seal..i am loving my upgrades so far..i lost just a teeny tiny amount of tourqe at startup, but i'm definitly loving 2k+ definitly revs and makes boost more quickly
Sexy flywheel pics
coupe should be driving tomorrow, so i will give results. it's being paired with a xt6 clutch & lighter crank pully too
VLSD Finally Installed!
cool!..i got the same vlsd waiting to go in my wagon..curious to see how its drives/differs from a lsd
Sexy flywheel pics
all i had was my camera phone so i took some pics of it. went in the coupe tonight, so now it will be hidden forever ... you can tell where most of the weight was removed from , hence the need for me timing marks *update* pg2
Wife's Christmas present ... the other shoe must drop.
subaru_styles replied to mtsmiths's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhave you seen this? http://cgi.ebay.com/BULLDOG-SECURITY-SUB-2-Subaru-T-Harness_W0QQitemZ5846206498QQcategoryZ60203QQssPageNameZWD1VQQrdZ1QQcmdZViewItem
5 LUG help....
just take off the rear disks/hub w/ the rear swing arms. doing so you will have mounting points to add a rear swaybar;)
dirtiest suby job ever
this week it was cleaning the motor that was in my coupe..just completely covered in oil mud
new strut bar and torque strut on RX. (pics)
nice russ! any noticable difference?
How many have you meet and greeted.
hmmm... harpua boosted84wagon zap Subarujunkie Richierich Bratsrus1 Subarutex nomica Bajavwnsoobnut hondasucks jibs qman dr. RX Flowmastered87GL Adam NDJ ratty2austin glcraiggt hti-johnson steveman09 boostedballs danbob MTSfabman lauralthequeen yukonart lagwagon turbone oddcomp garner mudrat79 noahdl88 stewnar northwet nvzeno suberdave xsnrg all talk caboobaroo chim Carfreak critical max nells general disorder:rolleyes: i know there's about 5 people im missing
ea82 non-turbo?
been there, done that. more work than its worth. not to be harsh, but just buy a turbo car.
who's red turbo loyale?
so any locals wanna take a pic? i wanna see how those vents look on an ea82
Hit the DYNO for the First Time Today!
- Just Installed Honda Accord springs
yeah the eibach's are they way to go, as you can get whatever size/# you want. for my coupe i actually bought some eibachs that are 2"shorter, but stiffer than stock..just waiting for new shocks before i install them. - Just Installed Honda Accord springs
