idosubaru
  1. Helped a neighbor tonight. 97 EJ22 OBS, idled poorly yesterday with no codes, then today No start, fuel good, timing marks good. Cam sensor code, the sensor connector and wiring look good. I’ll look it up, I think the FSM has a test for the cam sensor How far apart are the timing tensioner set holes once the pin is pulled? Does anyone have a picture of EJ timing tensioner hold down pin hole on a good engine? The tensioner hydraulic pin shaft had about a 3 mm clean metal ring like the tensioner may be moving or are they all like that? The belt seems a little tiny bit loose but maybe I’m grasping for straws… 1997 EJ22 - I could stick a drill bit into the tensioner hold down and pin holes. They’re only off by a little bit. Seems like they should be further apart but I don’t have any in the garage to compare too.
  2. I had new one break in a couple thousand miles that was in contact with a lot of oil from a leaking crank seal. Luckily a non interference engine, and it seemed obviously caused by chemical contamination. Though the picture you posted doesn't show any wetness, so I'm guessing it was clean? You haven't mentioned timing pulleys - were any low on grease or seized? If nothing else is obvious, Aftermarket parts are like that - it's not like they all fail, but I'd expect 1-3 early failures in 15 years from aftermarket timing belts.
  3. I’ve installed JDM. H6s and replaced H6 HG for the reasons you stated. I’d rather have new gaskets than another unknown engine. But it’s a beastly job and given you just bought this car I would hesitate to do it because you don’t know how badly it’s been overheated before you got it.
  4. Aftermarket belt is most likely culprit. Use Subaru or OEM supplier onlyfor belt and pulleys Check rotation of all timing pulleys for grease filled bearings and crank/cam shafts Id replace the lower cogged idler at a minimum.
  5. Ask your local Subaru service department where they get their machine shop work done. The ones I know mostly avoid machine shop work entirely but they still always have a job or 5 they need something done for by a machine shop.
  6. Piston slap can be fixed with the heads off with new pistons or if you have a shop that will knurl the pistons for you. With heads off, unscrew the piston pin access hole, pop the pins out and the pistons come up through the bore where the heads were. What larry said. I wouldn't worry about normal piston slap. And I'd wonder if it was reasonably maintained, and how much oil it was consuming.
  7. Looks original and old. If you’re not seeing losses or leaks then it’s not leaking externally. The only failures I’m aware of are external leaks, damaged necks preventing the cap from sealing, and interval clogs. I’ve never heard of internal leaks but failure of the plastic is no surprise on 10+ year old radiators and yours is 20 yo. If you have tractor or equipment repair shops or one of the few remaining radiator repair shops around they can test the radiator. But for the time you can just buy a new one. Ebay is the go to radiator source. They’re very inexpensive and aftermarket is a surprisingly decent option for Subaru radiators. I’ve seen H6 Subaru radiators for under $70.
  8. It's probably not the struts. I've never seen even horrific struts cause ghost walking like you're describing, why replace them? It's probably the springs, not the struts.
  9. Yes. I have one. Liberally grease all the threads, they're under a lot of stress, don't run them dry.
  10. Lots of great shops in CO, as the previous reply indicates. Both those guys that replied to you 100% know what they're talking about. You just received top notch advice. Good luck!
  11. I don't know CA laws but if the car is going to be registered in CA I think it's not going to pass their sniff tests. Don't they check to see if the engine is original?
  12. The spring has failed. I've pulled out failed springs like this and compared them to others - and there's no visual difference. They are the same length, no cracks, I assume the materials are degraded and not offering the right spring rate characteristics. So I don't know of any tests that can be done to confirm diagnosis. But if it happens due to bumps while driving straight, that's a failed spring in a Subaru IME. That's true, his is happening only due to bumps, not while cornering, which is typically a failed spring. Although at this age and condition, it probably doesn't matter and both new struts and springs are on the menu.
  13. Ensure all your leaks and filter is sealed with no air sneaking around? If the intake is still stock, try another filter for just one oil change?
  14. I think they used to be cast such that the left and right heads were identical parts. only need to cast one part for both heads. Which just requires the cam support be cast into both ends, just plug the unused one as needed. I worked in manufacturing engineering early in my career and this type of move was very common. Having one type of cast product that could be finished as needed for multiple applications was more efficient than having two different casts, particularly for low volume products or initial development. So my guess would be the ones without plugs are later models.
  15. I’d drive it and shut it off before it overheats so much it bubbles out, but after it gets warmer than normal. Do that a few times and see if there’s coolant loss/air in the radiator and reservoir. What happens: 1. Levels all normal? 2. Radiator is low? 3. Radiator and coolant reservoir are low? 4. Or is it overheating so badly and quick that test isn’t possible? Good, sounds like head gaskets but glad it’s not. Those engines run fine on pure water, it will not overheat because it has pure water in it. cool lower hose is indicative of air in the system which prevents coolant flow under certain conditions. aftermarket thermostats and water pumps aren’t known to be be high quality. But those don’t explain your symptoms
  16. Yes. That’s the rear of the camshaft right? assemble and install the plastic caps that go there. Camshaft plugs they might be called.
  17. It runs fine without a thermostat? How long was it driven without one? How do you know it ran fine before all the work? Is this someone else’s car who told you that or you’ve been driving it for years? You seem adamant it’s not, but this is the classic start of a case that ends up being headgasket.
  18. I’d suggest getting 16” Forester turbo wheels and if you must stick with those vulnerable 17” stock wheels - If I had to guess the BFGs will be a strong candidate. Generally, for what you’re looking for - you get what you pay for. Cheaper tires tend to reduce side wall strength and chemicals that mitigate UV/oxygen degradation for longevity. average consumers aren’t good purveyors of those traits. So companies can easily cut expense there. Have you considered getting larger sidewall tires? You could use the lid time standard Outback 16” wheels. The 16” Forester turbo (and maybe some non turbos) are super sharp wheels The 2005+ trend to increase wheel diameter and lessen the tire side wall makes them more vulnerable. I live in an area where gravel roads are common. I see tons of 2005+ Subarus with busted side walls and those bumps on the side walls (do they have a name)? My 2009 legacy has a large protruding bump now. It’s so common I’m just leaving it. I’m tired of replacing them, this set will be replaced soon, these are otherwise great tires, and this car isn’t that critical. Tire companies change brands all the time for marketing purposes so it’s hard to see good quality long time reviews and consumers in aggregate aren’t great reviewers for a huge number of reasons. Example: general Altimax tires are a very common tire here that performs well and is priced well. But they have weak side walls and I see them fail all the time here. The online reviews don’t mention this. So reviews aren’t great but: Id still look at reviews to see what they say.
  19. Check the timing belt and tensioner. Have you tried spraying starter fluid into the intake when it's stumbling and see if that smooths it out? What happens if you prop the idle open by hand or drive with partial throttle like 10 mph - does it stumble then? Or just at idle? If it's happening just at idle I'd swap in another idle control valve. Is the fuel pump aftermarket? Pressure looks good but I don't trust aftermarket subaru pumps/alternators/starters - they're routinely garbage and fail or work poorly.
  20. I might have a 96-98 legacy cat - you want me to check?
  21. They’re solid vehicles. Prices seem to be subsiding. If you can wait a few more months, don’t buy now tax returns still in play. Economy will continue to stall and people will be spending on summer travel houses pools land scaping and cars are second fiddle.
  22. If you mean “new” I’d get the extended 120k warranty and buy whatever you want. I avoid warranties generally, and haven’t priced them recently but they were a very reasonable deal a year or two ago when acquaintenances/friends were getting them Ascent for space Crosstek for resale Outback for interior space usability As others have stated the Rav 4 and Toyotas in general are impeccable for reliability.
