'94 Loyale Rear Wheel Bearing
Yep - the idea is to not allow the heat to migrate into the "next layer" before you get a chance to start beating. Expand the outside, and pound on the still cool inside - the temperature DIFFERENCE is what is important, not that absolute application of heat. That's also why a BIG torch works best. It can throw down more heat at a faster rate. This allows you to get the hot part hotter, while the migration of heat to the next layer is still trying to catch up. A few well placed sharp blows from a chisel will also expand the hot metal and assist in this process. It does take a bit of experience to get this right most times. But it also depends on the size of torch. I can get to RED hot in about 10 seconds or less with the torch at work. I routinely take apart press fit pump impellers with our 10,000 lb shop press using it. Sometimes takes 20 or 30 minutes of continuous heating and pressure but those assemblies weigh around 100 lbs or more. GD
Sure - with the proper socket, and my 480 ft/lbs impact they come right off. Generally I don't even have to bend the tabs out. But the natives here don't know from rust. I saw some once while I was on vacation to Hawaii..... :-p GD
Broken timing belt 15,000 miles
He speaks from experience...... you don't even know. I've met him in person.... as in he was HERE on the west coast at the time. For a Subaru show of course. That was like WCSS4 I think.... Fox - you are sure are getting up there in the post count. I remember reading about your first trashwagon.... before you ever owned a Subaru. Good times man. Let us know what you are up to some time (in OT of course). GD
GCK half shafts
All manual turbo's are the same axle. A manual RX uses the same axle as a manual turbo wagon, or a manual turbo XT. I don't beleive there were 3AT RX's, so that's a non-issue. 4EAT RX's use the same axle as well - 25 spline inner joint EA82 shaft. So basically all RX axles are equal. And they are the same as all 4EAT (only came on the turbo) and Manual Turbo's. All used the 25 spline axle. The only turbo's that this doesn't apply to would be the 3AT turbo's. GD
Bucky needs a fuel pump?
Those pumps are pretty rugged. And they do make a whining noise that can be heard in the cabin. That's more of a function of the amount of sound insulation in the Loyale, and that the pump is outside the tank. Most pumps are audible under these circumstances. I can hear all of my Subaru's pumps with the possible exception of my Legacy. I can also hear the injection pump on the '72 VW Squareback - it is similarly located outside the tank under the car (but in the front). Get a fuel pressure guage and plumb it into the system. SPFI should be a constant pressure of 21 psi. If you get much less than that under any condition then you either have a filter problem, a pump problem, or a bad regulator on the side of the TB. Verify timing (both valve and ignition), fuel, and compression. One of those will explain your power loss. If it were me I would be pulling the outer covers and verifying valve timing, and taking a compression test after that. Followed by ignition timing and fuel delivery. If you still have issues run a D-Check to have the ECU diagnose the SPFI system. GD
This is the one: From here: http://shoptoolsshoptools.com/shopexd.asp?id=1156 GD
That *might* work. But it looks like it's too thin and would shear off.... the ones specifically for Subaru rear ring nuts are like 1/4" thick. It's worth a try, but as you have seen beating on it with a chisel - that ring nut is a seriously stuck bastard, and it's none too small or thin or wimpy either. I think it would eat that woosy socket for breakfast. GD
How did you break your first Subie??
First thing that ever broke on me was on my '84 wagon. Distributor shaft bushings. Classic failure, tach jumping, etc. Thought I was up a creek cause the cheapest I could find rebuilt was $165.... had it rebuilt at Philbin for $55. That was in 2002.... I still own the car, and the distributor is still in it . GD
Diagram for GL PS Pump?
Not worth fixing. Too cheap used. Also depends on the type of pump you have. Some have the pulley held on differently. GD
Nope. Probably. Belt longevity isn't why we run without covers. Belts are cheap, my time isn't. If it shortens the life of the belts by 10,000 miles that's fine - I would rather replace them every 40k and have it take 20 minutes than replace them every 50k and have it take 3 hours. GD
Sadly no one is going to carry that socket . It's very much specific to Subaru rear wheel bearings. Clean the area around the nut really well, and insure that you have bent back all of the locations that are bent into the notches in the ring nut. You CAN get it out. Remember that. First thing is to heat the control arm up AROUND the nut. Don't apply heat to the nut, but instead apply it to the outside of the control arm. Do it as quickly as you can so all the heat doesn't migrate to the nut. An oxy/acetelene torch is best, but a map gas hand torch will sometimes work. Once you have got it pretty hot, release the rust hold on the threads by making four notches around the outside of the bearing housing right over the ring nut threads with a sharp blow from a chisel. This will expand the metal and allow you to turn the ring nut out. Another alternative to replacing the rear bearing is to get a whole rear control arm with a good used bearing in it. I've swapped control arms many times as they are cheaper than the $50 that a bearing costs . GD
Having a problem going up hills
Fuel filters are your first step. GD
whats the difference
Right, but on all the rest the injectors are in the manifold. So that really only applies to those weird EA81T heads.... GD
fuel pump cutout thingy location?
The FSM's vary in what they refer to it as - depends on the year and the translation/translator I would assume. My point was that it's function is more complex than what is indicated by the term "rev sensor". For that matter it also "senses" the ignition switch posistion. And it does have logic - depending on it's input, it decides what to do. It's simple, and hard coded, yes. But it is "logic" - all that really applies to here is that the device controls it's output based on several inputs. It is boolean, and is only interested in true/false. GD
To clarify, this is not a simple "rev sensor" as folks lately have continued to call it. It is a "Fuel Pump Control Unit" and contains logic that runs the pump for a specified time interval when the ignition is switched to run then shuts it off if it doesn't see a tach signal. Additionally it supplys power to the pump when the key is in the "start" posistion and the engine is cranking. It is more than a simple rev sensor. GD
ea82 heater core replacement prices?
Yes - Skip's sugestion is a good one. Make sure the vacuum servo's are moving the flaps in your ducting. Also there are differences in the core's for EA82's. Later models are not the same as older models in the shape of the brass tubes comming off them in the rear. Make sure you order the correct one. GD
Not always. They are for EA's.... GD
Probably under the passenger seat. FPCU is under the dash. GD
96 Impreza
Imp = 110 HP GL = 90 HP Being that the Imp is lighter, and generally has a more advanced suspension design it's going to be faster and it's going to ride better. All around a better daily driver. But the GL would have the low range - which is nice for some environments. It's a toss-up as to what you want in a vehicle really. GD
What engine? (It matters a lot) GD
No, that is incorrect. As I said the pump should run only when the engine is cranking, or the tach signal is present (running). And for about 2 seconds when the key is first switched on. Otherwise is should NOT run. His 83 is nothing like your RX. The RX (being FI) would cycle the fuel pump if you connect the test mode connectors, otherwise it's behaviour would be the same as above. GD
It definately helps to have the pin-socket for the ring nut, but not neccesary. I used to do then with a chisel and a hammer before I bought one. An impact and the proper pin socket sure helps with not destroying the nut though. Pound out the axle stub shaft with a soft-faced (copper is my preference, but brass works, or a block of wood). Do this before you remove the ring nut, or you may find the stub has rust-welded itself to the old bearings. Remove the ring nut, drift out the bearing(s), and drift the new ones in. I use a brass punch tapered to only hit the race... The bearings come several ways - single-peice, three peice, and five peice. Subaru OEM started out with the single peice, and then switched to a three peice in the early EA82 era somtime. All of them fit the same, and the three peice depricated the part number for the single peice in the EA81's. It doesn't matter which you use. Personally I like the three peice as they are easier to install.... GD
Have you flushed directly through the core disconnecting both lines at the firewall? If not try that with high-pressure water. Flush both ways. Otherwise get a core and go to town - takes about 6 hours. Try rockauto.com, and the online dealerships - subarupartsforyou, etc. GD
radiator? overheating possible? goes down when heat on
Radiators.com I have used before. All EA81 radiators are two-core, so nothing really "special" here. An ordinary OEM spec replacement should do just fine. If you look around you should be able to get one for $120 or less. GD
Probably time for a new radiator. The cost to fix them is more than they are worth. Get a new one. GD
