25
Everything posted by nipper
I only use synthetis because during the winter i do a lot of short trips (2 blocks- 2 miles) and the oil never gets to heat up. 80% of us really can be covered by Heavy duty intervals. The long intervals started in the 90's to show how low cost maint was on cars. The trade off is the longevity of vehicals (spark plugs are a different story).
So your differential was run dry and now it is whinning? thats not good. How often did you have the diff fluid serviced (bet I know this answer). On a noisey rear diff that had the oil properly maintaned you can drive on it for years that way. pOn your it was run dry, so damage was done. It is still leaking (aparently bad enough to notice as they never leak that badly). Replace the rear diff, otherwise it fail when your in the middle of no where with your car full of crap. Have the front diff checked too. nipper
My 2 cents. Subaru itself admitted that the 2.5 (when it first came out) was pushed to the design limits. Since then they have beefed them up. I have found that a 2.5 that suffered from over heating and had not had the oil changed when the condition was corrected was asking for trouble. Personally I think the 7500 mile oil change interval is just too long and needs to be reduced to 5000 miles if you want to give the car to your children someday. Very few people change thier oil early, and most change it later then they should. Also any engine which has a reduced oil capacity (less then 5 qts) really should have more frequent oil changes. The more power increases on a small engine, the harder it has to work, the more frequesnt the oil changes should be. And yes i had one throw a rod on me too, rather spectacularly. Mine was due to the owner chaining the oil once a year "whether the car nedded it or not". nipper
car quit on me
nipper replied to s'ko's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Pistons are tough, its the valves that get bent. nipper -
Have you actually checked to see if the blower motor works? If there is 12 volts at high speed to the motor and it doesnt spin, its the motor. get out the old volt meter and start going backwards from the blower motor. nipper
car quit on me
Car doesnt start as far as the ECU is concerned there are no codes to read, otherwise every time the car cranks it would throw codes. the code reader is just a tool, NOT the answer to all questions. You still have to do good old fashioned diagnoses to troubleshoot. Check the timing marks before you try to crank the engine again. You can make a bad situation worse. nipper -
Sheesh have patience with my 20 questions. Sounds like one of the door motors are broken. You can look under the dash and see them i think. As you go through the different selectors the motors should move. Sounds like you have a dead one. And if no one else has had this issue i'm your best shot nipper
car quit on me
Did you replace the tensioners and idlers on the timing belt? A code reader is sort of useless unless the engine starts. nipper -
What the hell?
nipper replied to Uberoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
All I buy are diehards. nipper -
What the hell?
I shopped optoimas. I chose a regular battery as they seemed to be longer rated. If you do any deep discharge stuff then an optima is best. Folks, he said he is in college, no reason to recomend a pricey battery when a regular battery which is easier on the wallet would perform equally well. nipper -
car quit on me
How many miles on this engine? Who rebuilt the engine? What was replaced at the front of the engine when it was rebuilt? nipper
