25
Everything posted by nipper
Anyone have a on-line source for Gates belts or better? Blu just passed inspection (amazes me at 256,000 miles sometimes) and the dealer on the invoice recomended belts. Metric Subaru doesnt try to sell you anything verbally which is cool. I've noticed my belts squeel a but and i did replace one with a crappy autochain part store chineese junk one since it was about to break. It lasted all of three months (the belt was junk, so its not Blu's fault). The stores around here seem to sell junk belts. nipper
STOP THE PRESSES! DUAL RANGE? You get stuck in neutral in the dual range? Here i thought it was in the forward gears. Next tiem this happens try jacking up one wheel of the car off the ground. This relieves driveline stresses (torque bind) and should fix the issues. Do not use 4wd on this car on pavement or packed dry surfaces. nipper
Its been done before, conversion is a bit pricey but very doable. I would stick with FWD for range. If you do AWD you will loose range. Googel EV World or EV conversions or electric car conversions. Lots of info out there. nipper
The TV show on scyfy channel. Aparently they are still doing the heavy product placement thing, but they only had one in this last episode. Since this was TIVO'd, all i know is that it is this seasons episode. Aparently Subaru bought alot of placement time. The only thing they didnt work into the episode was "symetrical All Wheel Drive". They even managed to work in the 0-60 time. The car was a WRX police car. nipper
Different kind of rust repair.
nipper replied to hardtail_pride's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Diamond plate always looks cool, even the aluminum stuff. nipper -
There are two ways valves can get bent, one is from hitting each other, the other is to have them hit the piston. Lets try a cheap test. An engine is a big air pump. Air should get sucked in the intake, and blown out the exhaust. Either us a peice of paper or your hand over the intake and feel which way the air is flowing. A compression test will tell us if the valve timing is off on one head, and a dry/wet test will tell us if the valves are not sealing. nipper
If its a bad steering angle sensor they should just fix it. Is your steering wheel off center? And i dont agree with your conclusion about the dealers, but hey, thats me. I have seen subaru come to bat for things that are out of warrenty before, but to me, this is just one of those things that break. Call a subaru area rep and sweet talk them. i dont know what the paramiters are for the fault codes and tolerances are for the steering angle sensor, so I cant say if this will fix it or not. If they are saying the car thinks its always going to the left when the wheel sensors are saying its going straight, i can see how the puter would give up trying to figure it out and throw a code. The real question is, is something bent in the front end? If your wheel is straight, car goes straight, then its just a bad sensor. nipper
I need a Subie mechanic near Edison New Jersey.
nipper replied to santiael's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ask NJdrSubaru he lives around there. As far as what to do next? How many miles on the engine. How long has it been over heating. What has been done to diagnose it? What recent service has been done to it? Has the car been driven with the engine temp gauge pegged. nipper
