25
Everything posted by nipper
I was on one of my infamous "i hate life i am running away from people" road trips. Blu threw a rod in a rather spectacular way in CA. I was so relaxed I really didnt care (thats what Mastercard is for). I had a choice of getting towed back to Ca or Reno. I chose CA. I was in such a centered place in my Id, I told them if I was going to do it I did not want to open my hood untill the next timing belt change (aside from fluid changes). Blu had 191,000 miles on him. I probably got some things I did not need, or could have gone till later, but I was one with the universe. I would have to look at the bill but it was a hair under 7,000 including towing and 10 day rental. I also had to pay for a new block as my old one had a rather spectacular hole in it. I got reinbursed on towing and rental, but i felt it was a fair bill. When the connecting rod went it spread shrapmetal through the radiator and oil runied the altenator. The dealer said that Blu was in excellant shape, so he flet it was a good investment to put a engine in him, as opposed to selling me a new car. See there are honest dealers. Yes I could have gone the independent shop route, but since I was someplace in the middle of nowhere, I decided to trust subaru and pay for the peace of mind. Also the dealer was located at the bottom of a long pass and siad he usually rebuilds 6-8 engines a year that blow on that pass (so he knew what he was doing). The tow truck said that he gets 2-3 vehicals a month that blow engines on that pass of various makes. I now have 50,000 miles on the sooby engine. Aside from a battery I have had zero issues with the Factory rebuild. It could have been done for about 5-5500 bucks or less if done in my own neighboorhood. nipper
Only if it is the one from the square state with a lot of big pointy mountains.... I have seen only three issues with them over the years, and each time they rectified the problem. You can't really ask for anything more. My best freind used a Nationwide rebuilder for a non-subaru vehical, and he got screwed. I used subaru for my rebuilt engine and never had a problem. I think you are in good hands. nipper
i like frameless windows. Europe is starting to buy more Automatics every year as their traffic gets worse. Sorry but living someplace with heavy traffic anyplace in the world makes an automatic a requirement. Not all of us are lazy some of us just cant dirve a stick anymore due to physical issues. Germany has just as many big guzzlers as the us (look under the hood of a Mercedes lately or jag? For the mosyt part american V-8s do not do badly compared to some of thier european counterparts. Also We have a much differnent country with much farther distances then any given country in europe. Some of the scleanest cars running today are much bigger engines then subarus. The lack of a temp gauge is actually important. It disapeared once and it came back, and will come back again. Rants are just useless and not very constructive, especially when you make the argument that we are lazy then knock us for because we want a freaking temp gauge. It has nothing to do with weather we are warm or not, but what the engine is doing and can we head off a major engine failure before it happens. There is precident for this in subarus and any other number of cars with a shady HG issue in its past. End counter rant. nipper
Remove all the drive belts and see if the noise goes away. 200,000 miles is a lot of mileage for a water pump on any car, but usually they leak first. I would suspect the ALT bearing or any idler/tensioner bearings on the drive belts (if any). nipper
If that is truly an oil leak, I would find it unexceptable. New engines do not leak, period. You may want to wash the engine, be anal retentive about filling the car with liruids, and see what happens in another 1000 miles. Also tripe check to make sure your PS pump is not the source of the leak. Also it is Easter weekend so I wouldnt be upset about not getting a call back. Use the car in the meantime. No need to be without a car for the weekend. nipper
Bumper skin really bothers me ( scratches, eh they happen. And the wheel bearing has to be done by the end of may. nipper
Blu paid the price for it. So anyone with a spare rear bumper skin? And a wheel bearing. nipper
The way some go offroading here in NJ some sort of floatation device may be in order too nipper
I'm tellin !
Ac is way more complicated then that. Please if you do not know what you are doing, take it to a shop. Its one of the few places under the hood where you can seriously hurt yourself (and not in a "here hold my beer" way). You need to take a low pressure and a high pressure reading with the PROPER gauges. It sounds like your low on refrigerant. You can build up pressure till the volume of gas you have goes through the expansion valve, then there is no more coolant to supply the compressor. You most likely have a leaking O ring too. nipper
Lest start with a tuneup. Plugs (factory recomended type) wires (OE) PCV valve, fuel and air filter. Then we have a baseline. Also can you spray the coil pack and ignition wires with water in the evening and look for sparklies? Before you do anything, remove the wires from the plugs and see if they are soekd in oil. No need to put new wires in soaked oil buckets. If they are wet, then you need valve cover gaskets and bucket gromits (OE). nipper
i like this one.
Why cant a 60 year old man run as fast as a 20 year old. Wear and tear. There are many moving parts the rub eachother and wear over time. If the car is not properly maintained (frequent oil changes) those parts can wear faster. The parts here are valves and more importatntly piston rings. they are required to make compression to make the car go (suck squish boom). The next one which you cna do something about is a tuneup. Then there is other things like performance tires, dragging brakes. nipper
