Everything posted by nipper
New Jersey Devil Chase
and just as i thought, so far the LISC people are wussing out. nipper
Help Identify these Trans Solenoid PIC
nipper replied to 2000impreza's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhow big is your mailbox?
96 ABS Relay Location?
nipper replied to Steggy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIts on the ABS pump itself. nipper
nipper replied to 2000impreza's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat was easy to find. 76 is the 2-4 brake timing solenoid. It is detecting either an opne or a short circuit. FOund it resistamce is 10-16 Ohms. Signal from the TCU should be higher then 9 volts. The proper way to test the output requires getting the car up to 40 mph. It seems like something straight forward to check as far as no surprises in the circuit. nipper
nipper replied to 2000impreza's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFor that i have to send you the manual, as they speak of voltages and it is sort of spread out all over the manual.
OH COME ON! It's tradition now, someone is going to teach thier sooby how to swim, it's just a quesion of whom. It's tradition! nipper
Drive Shaft U-Joints Gone South
nipper replied to Sonicfrog's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBut thats over on the mainland. i am on a long skinny island (and would never take a sick car to the bronx). nipper
nipper replied to Sonicfrog's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had mine rebuilt locally by a drive shaft shop since junkyards are few and far between here. nipper
nipper replied to 2000impreza's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe thing on the end of the brown plug.
i need a link for directions so I can post it on the LISC site. Lets see if any of them want to get thier riceburners dirty . nipper
OBS lift Question
Ah ok. Outback spring rates are based on the Legacy, outback sport based on the imprezza. One car is much heavier then the other. I would stick with same weight class, There may even be physical size differnces. nipper
OBS lift Question
Not quite sure what you are asking nipper
Unable to reset/clean ECU codes....
nipper replied to dakos's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf the O2 sensor is shorted out you wont be able to clear the codes, and it may not even show up as a code either. I went through that with Blu, but hes on PBDII. Just a thought. nipper
Leak behind oil pump wall help
nipper replied to CMohan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXresealinbg the oil pump with the proper sealant gets done at either 105,000 oe 120,000 miles depending upon the timing belt interval (60,000 x 2). And i am surprised no one has said it yet.. PEPBOYS BAD! nipper
nipper replied to 2000impreza's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX1- Lock Up Duty 2- Line Pressure 3- Low Clucth Timing 4- Shift Solenoid 2 5- Shift Solenoid 1 6- 2-4 Brake Timing Solenoid 7- 2-4 Brake Duty Solenoid
nipper replied to 2000impreza's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAcn you handle a 14,000 KB email, I have a manual form a 2002 Imprezza if that would help.
Well i have to post a date on the LI sooby list as some of those folks want to come. nipper
SO there is a firm date then. nipper
More on Torque Bind
nipper replied to steamin53's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXa fool and his money. Sometime you have to pay a professional to repair what you can't, there is nothing foolish or wasteful about it. All i said was to diagnose it. nothing about fixing it. And actually its about 850.00. The logic behind the age of the car is silly. Is fomeone said you needed four tires at 500-600 bucks do you junk the car? Good luck whatever you choose to do. nipper
More on Torque Bind
nipper replied to steamin53's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt can be touchy and doesnt always work. Sometimes you have to surrender and take it to a dealer and have them read it. nipper
fuel sending units????
nipper replied to mike97's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm surrounded by wierdos. When i had mine out of blue and the silver legacy (98 and 97) the gaskest were fine. I reused mine. I reused the ones in Blu several times. nipper
More on Torque Bind
nipper replied to steamin53's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcall an online dealer and they will know exaclty what your talking about. https://www.subarugenuineparts.com/oe_parts_cat.html www.1stsubaru.com
You drive me up a wall
http://www.metacafe.com/watch/2546622/4x4_cooooooool/ Has an entire new meaning.
help getting hill holder to work
nipper replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi am sneaky, stealthy and one with the universe, as i am the wind MUHAHAHAHA that and i have the hidden box thingy set in my profile.
nipper replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLook at a neighbors http://www.bikewebsite.com/bicycle-bra2.htm look at the second picture and see how the barrel of the cable sits in the hole. nipper
