nipper
    25
Everything posted by nipper
  1. Unplugged O2 sensor might affect mileage and performance, might not, wont hurt anything. Driving in fail-safe mode dramatically reduces performance. O2 sensors get old and lazy, and wont throw a code always till they get really bad. nipper
  2. WTF? It sounds like autozone just did not want to it. I have seen scanners that will only pull the codes for the illuminated CEL, and nothing more, not the other way around. Or they just do not know how to use thier scanner. Its sort of like having an xray machine that wont pick up broken bones. nipper
  3. Fouled plugs, weak wires, and a poor fuel mix due to malfunctioing maf or a clooged filter, they can all be connected. Upi need air spark and fuel to make the car go, of course they can all be connected, because without one the others dont work. nipper
  4. COuld have been a bad tank of gas..... indigestion. When was the last time the car had a tune up? Can you get a fuel pressure gauge on the car? nipper
  5. You need to put a mechanical gauge on the car to find out, and also check the quality of the oil. When was the lats time you changed a pcv valve How is your bas mileage What is your oil change interval Nipper
  6. Yes i hate to admit it, but sometimes you do need to read the instruction manual. :cool:
  7. Justies were 3 doors and 5 doors, about the same size, but never a notchback. Tercels (toyo) were notchbacks. nipper
  8. and do a wet and dry test. That will tell us alot more too. Right now those numbers show tired rings, but i think your numbers may be wrong, as the car should be down some power too. nipper
  9. Since no one has really answered you, there are a few things to be aware of. Inspect the coolant in the radiator. Dont go soley by the over flow tank (as no one cleans those nor flushes them). Look for contamination. Always take a sooby to a parking lot (or any awd vehical) and do figure 8's. The car should do it smoothly with little or no throttle. With TB or mis matched tires, the car will struggle and lurch, and may even stall. If its an auto, check the FWD fuse holder to make sure there is no fuse in it. Make sure all the tires match. Tmoing belts are every 106,000 miles. And yes that car is over priced. good luck. nipper
  10. Any AWD vehical has the tire issues, and they always have, ever since audi made its fulltime awd quattro (before that subarus were good old fashined 4wd). The coolant thing is over blown. If you just add coolant the way they taught people how to do it for the last 50 years or so there is no issue. There are other cars out there that have the cooling system "issue" that really just comes down to procedure. The only truth is that they are fussy about some aftermarket parts, because the aftermarket parts in question are made cheaply. They arent the only car outh there that are picky. nipper
  11. Some easy numbers to know while in the USA 30 mph is 48 kmph 40 mph is 64 kmph 50 mph is 80 kmph 55 mph is 88 kmph 65 mph is 104 kmph 75 mph is 120 kmph that should cover you nipper
  12. Step 1, throw away the universal O2 sensor, and get a OE O2 sensor, that may be part if not all of your problem. Yes an incorrectly wired sensor can even blow the ecu depending how poorly its wired. There are reasons it has three wires. The front sensor should always be OE, the rear can be universal. Step 2, Stop breaking things. nipper
  13. All AWD soobies: Tires must be equally worn Tires should be properly infalted Tires should all match. If they are all ok On automatics: Transmission flush On Manual: Nothing else to do. It sounds like your at a stage where a fluid change or proper tires will correct it. Manuals are 1200.00 repair, automatics 800-900 if you take it to a dealer (less if its just a bad solenoid). I always say go with a dealer on this one as a tranny shop will try to sell you a tranny when you dont need it. Welcome to the board. nipper
  14. your life (or some one elses) is worth far more then a tank of diesel, or even 30.00 worth of fuel. Take the truck, we like having you around. nipper
  15. Yes that would help. Due to my handicap, a power seat would make life sooooooooo much better for me, but not if i will have mis matched seats (yes some ways im anal). nipper
  16. Didnt you have some modifications to do? How heavy were the seats. Can the seat be removed from the track? nipper
  17. Does this have a circuit breaker on the light circuit? It's been a long time i dont remember. Usually the dash lights are on a branch thats seperate from the head lamps, with a commonality at the switch. I would look for a problem before the switch. Or a bad ground. nipper
  18. Has anyone taken the power seat from a newer sooby and retrofit it into say, a 1997? nipper
  19. Technically the may need replacing anywhere from 60,000 miles up, but sooby's they start to share failure around 150K or better I recomned KYB GR-2's. They are cheaper then factory, a little bit on the stiff side (at this point anything you put in there is going to feel stiff) when cold, but great struts. nipper PS have you ever replaced the PCV valve?
  20. You are overdue for struts. Blu did the same thing at 190,000 miles, a front one was blown and a rear one broken. I thought the rear noise was the exhaust system, but new struts made it go away. nipper
  21. im guessing a blown strut or broken strut. Thats about the only place where you can bounce the car and make a noise. Next would be a borken exhaust hanger. Then finally a suspension bushing. nipper
